Triple carb fuel pump PSI
luvemfast
4.5 pump would get pressure drop from tank to carbs though? And with a return line, that would work ok wouldn't it?
You will want to get the regulator and a good fuel pressure gauge. My Webers like to live best at 3psi. without the regulator I had drivability issues.
You can run the current EFI pump using a return line (equal in size to feed) and an inline pressure regulator.
A friend of mine tried this solution when he switched his ZX with Carbs. He ended up being lean because of fuel delivery.
It seems that pressure regulation is reducing flow rate as well making the pump running out of fuel. He ended up removing his EFI fuel pump for carb specific pump. For $100, I wouldn't skip this step.
Carter 4070, Mallory 4070lp, Facet Red Top, etc. All would run 70gph at around 4 psi, good enough for 250whp.
Edited by Lazeum
He did something VERY WRONG then! The stock EFI fuel pump will fuel triples using a backpressure regulator to well over 300HP! The flow rate of the stock Bosch-Licensed pump goes through the roof at 3psi. I ran (and still do) this system to 375HP in turbocharged form and with a simple jet or regulator setting change immediately flood the engine to the point of sinking the floats and fuel pouring out the carburettor throats!
If someone "ran lean" using mere triples and the stock EFI pump---then either the pump was shot to begin with, or they did something VERY WRONG in setting up the system---first thought to mind by the way it was phrased was 'pressure regulation is reducing flow' meaning he DID NOT use the REQUIRED backpressure regulator. And FYI: the EXACT same thing will happen to a carb pump if you use that style regulator!
A backpressure regulator ALWAYS has full pump capacity available to deliver fuel to the carbs or injectors. Any regulator placed between the pump and the fuel delivery source is ALWAYS going to be a potential bottleneck in delivery through orifice size or malfunction.
Yes, it's clear he did something totally wrong. The EFI pumps are designed to flow at high pressures. As you go down in pressure on the pump curve, the flow rate will increase. There is no way you should run lean with a properly regulated EFI pump, pouring rich maybe but not lean.
I would have agreed with you. I even advised him to go this route but facts have proven that EFI was running low on fuel with regulator. It has been observed on dyno with AFR reading. Car was running great on 1st, 2nd & 3rd gear but not anymore (= super lean) on 4th & 5th. So now, I don't advise it anymore.
Luvemfast,
Get a regulator, run the car with EFI pump & report on results. Worst case scenario you'll buy a low pressure pump later on ;)
Edited by Lazeum
Luvemfast,
Then he either set it up wrong, or something went amiss. There is no reason that a properly working, properly regulated EFI pump should not be able to supply enough fuel at low pressure. We are talking physics here, not anecdotal evidence.
