NewZed Posted November 24, 2012 Share Posted November 24, 2012 Your exhaust sounds very loud considering it's going through a turbine. Is there any exhaust pipe at all after the turbo? The backfiring reminds me of what a couple of V8s I've had in the past sounded like when they had a flattened cam lobe. You said that it ran for a month. Did it run well? And is the problem exactly the same as before? Has it always backfired like that? You should summarize the last month or two to give a better picture. It doesn't sound good right now, seems like bigger problems than just won't stay running. Quote Link to comment Share on other sites More sharing options...
xShodaimex Posted November 24, 2012 Author Share Posted November 24, 2012 There's a 2.5 in. Down pipe from msa. It ran really well a month ago, and that was with a weak fuel pump pushing 25 psi. I got it to run after doing a chevy hei module swap since my ignition module was bad. This was about 1-2 months ago. It just started backfiring 2-3 weeks ago after running fine for a month. I now have a walbro on it but I have yet to check the actual pressure. It definitely sounds bad. Quote Link to comment Share on other sites More sharing options...
xShodaimex Posted November 24, 2012 Author Share Posted November 24, 2012 I'm going to read the fsm tonight to see what next to do. Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted December 5, 2012 Share Posted December 5, 2012 That actually sounds like when I first got my car running with just headers on. Turned out I had routed the fuel lines wrong and was starving the engine of gas (I think). I had it run from the pump, to the FPR then to the fuel rail with a dead end. Not sure if that's flooding or starving the engine of gas Quote Link to comment Share on other sites More sharing options...
rags Posted December 5, 2012 Share Posted December 5, 2012 Sure sounds like you burned an exhaust valve from running a too lean mixture caused by low fuel pressure. Stupid question but did you ever change the fuel filter? You have to address the fuel pressure problem before going anywhere else. Joe Quote Link to comment Share on other sites More sharing options...
motomanmike Posted January 4, 2013 Share Posted January 4, 2013 What do your plugs look / smell like after this initial fire up and it shutting off? Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted February 16, 2013 Share Posted February 16, 2013 Are you saying the cat is ready to ship to this guy and that will fix his problem? Quote Link to comment Share on other sites More sharing options...
