erratic fuel air ratio readings
Just installed a AEM wideband I welded the bung right after the msa 6-1 header flange. I have tripple 40dcoe webers they are basically stock except for the 29mm chokes. timing at around 16*, idle is stable at 900-800 rpm. Now my air/fuel gauge at idle is not stable it jumps around between 11-14. Could a vacuum leak at the intake manifold gasket cause this.
