Bigfat280z Posted April 17, 2013 Share Posted April 17, 2013 Hello I'm pretty new to the forums, having a couple problems with my Z I just purchased a couple weeks back. the first problem seems to be transmission or clutch related- 5 speed it makes a weird noise like two metal plates scratching together intermittently in 1st through 3rd gear at low speeds it also makes a weird metallic noise sometimes when switching gears from the shifter. I'm thinking that it is possible it may be low transmission oil/fluid or something similar anybody have any ideas what this could be? the second problem just started within the last two days and maybe fuel related or related to the first problem where the gear may be slipping when accelerating the throttle response is acting strangely don't know how to explain it exactly except that it's basically not there unless you get on it. doesn't look like I'm leaking fuel anywhere, but I did start getting a strong fuel/exhaust smell today my eyes even starting watering on the way home from work today. the previous owner told me the car had an exhaust leak in between the downpipe and the catalytic converter could this be the problem? any help would be appreciated greatly thanks Quote Link to comment Share on other sites More sharing options...
helghast7 Posted April 17, 2013 Share Posted April 17, 2013 (edited) Your best bet, honestly, is to pick the car up and have a good look at everything. These are old cars and things fail with age. Most importantly its extremely hard to diagnose a problem over the internet when you haven't even removed the basics from the equation. Start with going under the car and checking the transmission fluid, check the driveshaft u-joints, check the differential fluid, check the axles and check the wheel bearings. Make sure no fluids smell burnt. While your under there it would be a good time to check for leaks of an kind, exhaust and fuel. Im just going to take a guess here and say your burning your clutch since your saying theres a slipping. Edited April 17, 2013 by helghast7 Quote Link to comment Share on other sites More sharing options...
daddydonuts Posted April 17, 2013 Share Posted April 17, 2013 Fuel issue could be rotten hoses around the tank, my brothers Z did that, replaced hoses and ran fine. No clue on the tranny noise, not enough information Quote Link to comment Share on other sites More sharing options...
NewZed Posted April 17, 2013 Share Posted April 17, 2013 On 4/17/2013 at 1:03 AM, Bigfat280z said: related to the first problem where the gear may be slipping On 4/17/2013 at 1:03 AM, Bigfat280z said: when accelerating the throttle response is acting strangely don't know how to explain it exactly except that it's basically not there unless you get on it. On 4/17/2013 at 1:03 AM, Bigfat280z said: the previous owner told me the car had an exhaust leak in between the downpipe and the catalytic converter could this be the problem? You should study up on the basics of how engines, transmissions, and clutches work. You have a ways to go. The Factory Service Manual is actually very good as an educational book, it's worth reading. Quote Link to comment Share on other sites More sharing options...
Bigfat280z Posted April 17, 2013 Author Share Posted April 17, 2013 Thanks for the replys I'm going to check everything out that you guys sugested this weekend when I can get it put on a lift Quote Link to comment Share on other sites More sharing options...
WreZ Posted April 22, 2013 Share Posted April 22, 2013 One other thing to check is the front tranny seal (around the shaft) sometimes if a car has been sitting for a while they'll throw a tantrum but if its something that NEVER goes away its best to have a proffesional crack the cases for you Quote Link to comment Share on other sites More sharing options...
col10see Posted April 30, 2013 Share Posted April 30, 2013 (edited) Drain the tranny fluid. Look for metal or shiny stuff in the fluid. If nothing I say fill it up again.... make sure you can loosen the fill plug first though or else you are screwed.... Is it possible the clutch may be slipping? They have rivets in them that will sound maetalic and it could also be causing the slippyness under hard accel Edited April 30, 2013 by col10see Quote Link to comment Share on other sites More sharing options...
