DatsunZman04 Posted August 9, 2013 Share Posted August 9, 2013 I am running out of room in my 240z to put aftermarket gauges, and I was wanting to fabricate a 3 tier pillar pod and mount this in my car. The problem is theres not much room between the windshield and the driverside door frame. I know this has been done before because I have seen YOUTUBE videos with Datsun Z's having them. If anyone has any information/ Pics/ Instructions that would be help full. I'am wanting to add a fuel pressure, Air to Fuel Ratio, and exhaust temp using 52mm or 2 1/16 gauges Thanks again, Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted August 9, 2013 Share Posted August 9, 2013 Its more than likely custom, as the A pillar is super thin. I doubt there is an off the shelf one that will fit. Quote Link to comment Share on other sites More sharing options...
DatsunZman04 Posted August 12, 2013 Author Share Posted August 12, 2013 I figured I would have to custom make one, I just thought somone on here would have some pics of one on there car to see how it turned out. Quote Link to comment Share on other sites More sharing options...
Dat260Z Posted August 30, 2013 Share Posted August 30, 2013 Zforceproductions makes a 3 gauge pod that mounts where the center air vents mount in the dash..I have seen an A pillar gauge pod around somewhere but I can't recall who sells it Quote Link to comment Share on other sites More sharing options...
Sam280Z Posted August 30, 2013 Share Posted August 30, 2013 miata 2 gauge pod on my 77: https://plus.google.com/u/0/photos/110595327894846974778/albums/5847680414105477217/5850522264572523234?pid=5850522264572523234&oid=110595327894846974778 Used zip ties to close up the back a bit and then used a heatgun to relax the plastic so it would stay that way. Attached to the stock trim piece with 2 small zipties around the back and through a hole drilled in the pod. It wraps around the a-pillar from the glass all the way around the door weatherstrip attachment. Sam Quote Link to comment Share on other sites More sharing options...
ZT-R Posted August 30, 2013 Share Posted August 30, 2013 Here is mine. I made it, pretty simple. Quote Link to comment Share on other sites More sharing options...
R3VO 3VOM Posted August 31, 2013 Share Posted August 31, 2013 (edited) I assume you've already done a radio delete. I don't a picture currently, but I put my A/F gauge in between the 2 main gauges in a small pod mounted to the plastic steering column cover. If you don't have AC anymore, you can mod the AC duct vents (the round ones on the outer edges of the dash. Or the center ones too I suppose) and put one in there as well. Its a little low, but with some creativity I bet you could angle it up towards you. Edited August 31, 2013 by R3VO 3VOM Quote Link to comment Share on other sites More sharing options...
DatsunZman04 Posted September 13, 2013 Author Share Posted September 13, 2013 Yeah, I kept the radio but already deleated my center vents and switches, All I have is fan on/off for defrost if I need it. I was just trying to see what make and model everyone was using to modify pillar pods to make them work. Cheap as they are I guess I can buy one and start molding it to the shape I want. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
AlbatrossCafe Posted November 1, 2017 Share Posted November 1, 2017 (edited) On 8/30/2013 at 1:22 PM, ZT-R said: Here is mine. I made it, pretty simple. I actually really like the "industrial" look of this. Anyone have a link to the kind of mounts used or know what to search for? I can only find full-pillar pod styles. Edited November 1, 2017 by AlbatrossCafe Quote Link to comment Share on other sites More sharing options...
Chickenman Posted November 3, 2017 Share Posted November 3, 2017 A 2nd Gen RX7 gauge Pod fits pretty darned close. Similar to the Miata Pod. A friend of mine installed the RX7 pod and it fits slick with just a bit of edge trimming and shaping with a Heat gun. Autometer Part # 20670. Fits 1986 - 1989 RX7. Quote Link to comment Share on other sites More sharing options...
