Zmanj87 Posted March 24, 2014 Share Posted March 24, 2014 So I'm finally replacing out the suspension I'm going to go with Full Tokico Illuminta and Spring Kit.. Extra's I'm going to get is Rear spindle pins Replacement Boots already have urethane Bumpstops ready Rear Spacers I was told I should get these if I'm going to get larger wheels in the future Bump-Steer Spacers, 15" & Larger Wheels, 70-78 240Z-260Z-280Z http://www.thezstore.com/page/TZS/PROD/PSDC11/23-4186 Now with those do I need them for all 4 wheels I'm guessing? Other then that is there anything else I'm missing or should be suggested? Quote Link to comment Share on other sites More sharing options...
NCchris Posted March 24, 2014 Share Posted March 24, 2014 You might want to check the availability of the Illuminas! Has been a lot of chatter on this board about them not being available and/or on indefinate backorder. chris Quote Link to comment Share on other sites More sharing options...
Zmanj87 Posted March 24, 2014 Author Share Posted March 24, 2014 Ya what's the deal with that? I know Tokico had some supplier issue? But Tokico website has pretty much disappeared and it's some Hitachi website.. Ya I'll have to look into it Quote Link to comment Share on other sites More sharing options...
ritrebor Posted March 25, 2014 Share Posted March 25, 2014 Steer spacers is just for the front. Ritrebor Quote Link to comment Share on other sites More sharing options...
yhlz Posted March 25, 2014 Share Posted March 25, 2014 Tokicos are no longer available. Just FYI. Quote Link to comment Share on other sites More sharing options...
Phantom Posted March 26, 2014 Share Posted March 26, 2014 How far are you really wanting to go with your suspension mods? Check out Techno toy Tuning and also go to the Arizona Z Car website to find things to drool over. Then make the tough decision. Quote Link to comment Share on other sites More sharing options...
JPN_Garage Posted March 26, 2014 Share Posted March 26, 2014 Or you can also get on our BC coilover list Quote Link to comment Share on other sites More sharing options...
Zmanj87 Posted March 26, 2014 Author Share Posted March 26, 2014 How far are you really wanting to go with your suspension mods? Check out Techno toy Tuning and also go to the Arizona Z Car website to find things to drool over. Then make the tough decision. I'll check it out.. Or you can also get on our BC coilover list lol only thing I'm worried about coil overs is with welding them in.. If one of them goes out your kinda Fcked right? Quote Link to comment Share on other sites More sharing options...
Zmanj87 Posted March 26, 2014 Author Share Posted March 26, 2014 Also only reason I'm going with Tokico is because I've read that theyre the only ones that will handle lowering springs. I've heard terrible things about KYB with lowering springs Quote Link to comment Share on other sites More sharing options...
yhlz Posted March 26, 2014 Share Posted March 26, 2014 I'll check it out.. lol only thing I'm worried about coil overs is with welding them in.. If one of them goes out your kinda Fcked right? The only part that you are welding is the threaded collar. Quote Link to comment Share on other sites More sharing options...
johnc Posted March 26, 2014 Share Posted March 26, 2014 Tokicos will also fail with lowering springs. You have to install new bump stops with the KYBs and Tokicos to keep from bottoming the shocks internally. Do that a couple times and the foot valve or piston gets damaged. Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted March 26, 2014 Share Posted March 26, 2014 I'll check it out.. lol only thing I'm worried about coil overs is with welding them in.. If one of them goes out your kinda Fcked right? Looks like you have some reading to do before making a purchase. All coilover options for the S30 require welding in some regard, not sure what you mean by "if one of them goes out". Bump steer spacers correct control arm angle when lowered, front only, and as mentioned, Tokico is NLA. Quote Link to comment Share on other sites More sharing options...
Phantom Posted March 26, 2014 Share Posted March 26, 2014 Welding only required if you also install adjustable top mounts if you want camber adjustment. Coilovers by themselves are bolt in. Quote Link to comment Share on other sites More sharing options...
Rob L Posted March 26, 2014 Share Posted March 26, 2014 (edited) I would go with techno toy tuning if I were you it's a complete bolt in option comes with koni shocks eibach springs and is pure car porn ....if you want zero welding top there coilover kit with dp camber plates and then just add TTT rear and front LCAs with there gorgeous tension control rods and you will have a complete bolt in sick and gorgeous suspension setup and on top of that you will get probably the best one on one with owner customer service experience ....also throw there bump steer spacers in there ....and your suspension is now TOP NOTCH! Edited March 26, 2014 by theatriks Quote Link to comment Share on other sites More sharing options...
NewZed Posted March 26, 2014 Share Posted March 26, 2014 Looks like you had it pretty close in Post #1. Just replace Tokico Illuminta and Spring Kit with KYB and Eibach lowering springs. You had new urethane bump stops on your list already. Then beware of bumps, either large or hitting at high speed. That's the intermediate cost option. Even cheaper would be to cut your stock springs. The assumption is that you're replacing to get the car lower for street driving, not go racing. Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted March 27, 2014 Share Posted March 27, 2014 Welding only required if you also install adjustable top mounts if you want camber adjustment. Coilovers by themselves are bolt in. Well whether it's done upon arrival or by the vendor, all S30 coilovers either require a retaining ring welded to the strut housing, or a strut housing welded to a threaded tube. No regularly attainable coilovers are made with new spindles. Quote Link to comment Share on other sites More sharing options...
Phantom Posted March 27, 2014 Share Posted March 27, 2014 I stand corrected. I bought the Techno Toy Tuning suspension kit that Theatriks talked about above. Other than the normal hassles of dealing with a 36 year old car it bolted right in. The "normal hassles" however, added about 2 weeks to the job due to getting incorrect wheel bearings and having to replace other parts that were damaged when the suspicion was disassembled. Visited the TTT website and started drooling over the LCA's and Tension Rods. I'm going to end up with about $4k in my suspension if I don't improve my impulse control. Quote Link to comment Share on other sites More sharing options...
Zmanj87 Posted March 31, 2014 Author Share Posted March 31, 2014 I stand corrected. I bought the Techno Toy Tuning suspension kit that Theatriks talked about above. Other than the normal hassles of dealing with a 36 year old car it bolted right in. The "normal hassles" however, added about 2 weeks to the job due to getting incorrect wheel bearings and having to replace other parts that were damaged when the suspicion was disassembled. Visited the TTT website and started drooling over the LCA's and Tension Rods. I'm going to end up with about $4k in my suspension if I don't improve my impulse control. ya I like those coilover's just going to hold off on them I guess and get the KYB and springs for now...don't track the car and I won't be driving it as much anymore since I have my Ruckus up and running again. Those TEnsion Rods tho are pretty sick Quote Link to comment Share on other sites More sharing options...
