My 280Z "Rustoration"
Yea the new hardware really makes a difference.
Do you have a list or excel file of the bolt sizes and hardware you purchased, and what parts they are for?
I've seen some vendors online sell complete 'kits' for the Z but not any zinc bolts
Hello, Im back. It ended up being an expensive weekend for me. I just bought my first brand new vehicle, a '14 Jeep Grand Cherokee. I really like it so far.
Ok back to the Z....
I also purchased this bad boy.
A 5 speed close ratio out of an 80 ZX. Now all I need is a new rear diff with some 3.90 gears and I'll be good to go. I may run the original diff for awhile but I think the gearing will make it sluggish on the low end. Maybe the torque of the 3.1 might make up for it, we will have to wait and see. I couldn't pass up the deal on craigslist for the tranny.
I also installed my firewall insulator I got from Black Dragon. Its good quality material but the fit isnt the greatest. It required some trimming.
I then spent most of my weekend rebuilding my heater box. The entire box was disassembled and cleaned. Replaced heater core, hoses, blower motor, foam seals, and re-greased all moving parts. It should work like new now.
This was nasty.
Clean blower fan and new blower motor.
New heater core on the right.
Hoses were brittle and leaking.
New hoses and reassembled.
Then I went to work on the wiring harness. Just scrubbed it down with degreaser and re-wrapped it with new harness tape. It turned out really good.
Edited by MattMatthewZ
Just finished a few more things on the list.
Installed the vinyl trim on my pillars and did my headliner. I followed this link from Blue and worked great. Only difference is I bought the kit from Motorsport
http://www.classiczc...stallation.html
The glue they send with their headliner kit is garbage, throw it away or give it to your wife to do crafts and stuff.
I went to Autozone and bought this:
Its pricey ($25 a can) but its the real deal. This is the same stuff they use at Automotive upholstery shops. (I used to work at an upholstery shop).
I also put in the dash and finished most of the wiring.
  • 4 weeks later...
I took my gas tank to a local radiator shop and had them hot tank and seal it. They also painted it black for me.
Installed new rubber insulators on the straps
Cleaned up the filler hose and installed it.
And finally got my tank in.
Now I just need to figure out where all of these fuel lines go :ermm:
Also bought a new side mirror from a 240Z
Holes dont line up so I had to drill a new hole and make the other one larger
And installed pic
Much better than the plastic 280Z mirrors I think.
Started assembling my door glass. Polished them up a little to take some of the fine scratches out.
Smooth as.... well, glass.
Freshly plated hardware
Now I need to source some new window regulators because I had mine plated and it destroyed the plastic rollers and the crank mechanism in the process :disappoin
On a happier note I talked to Dave Rebello and he told me my motor was finished and he just needs to do the dyno testing on it. So if all goes well it should be shipping out soon!
