280 z spec
Guest Anonymous
Guest Anonymous
g'day
i race a 240z with l28 here in Australia F54 etc I want to build a 280z for historic racing but we did not ever get the American Version only 280zx. can some members give me info on the factory spec 280? Also as i have to run relatively un modified is it possible to streamline and improve factory EFI ?
thanks Steve
Guest bastaad525
heheh I love it when guys quote the earlier GROSS hp ratings of 170hp.... man we all WISH the L28 was pumping out 170hp bonk.gif
GROSS, guys.... that 170 was GROSS, 135-145 NET was what the L28 was actually putting out when it was in the car with all accessories connected... this came out to about 110hp at the wheels, by the way...
Guest silverbullet
  Quote
Why not use flywheel power ratings? It seems that is all everyone else is using nowadays for bragging rights.
And which measurement method would we used?
Horsepower is basically an imaginary number derived via torque with this calculation:
bhp = torque x rpm/5252
Being an imaginary number there are various methods of calculating it, with some methods more precise then others.
Until 1972 most US auto manufacturers used an old SAE standard method develop to the so-called "gross" horsepower numbers. This standard was designed to measure the horsepower output of the basic block, cylinder head, and internals. The standard did not specify intake, exhuast, and accessory configurations.
In 1972 the state of California, as part of their Clean Air act implementation, required all auto manufacturers to specify horsepower ratings using the SAE J245 (now SAE J1349 and J1995) standard. Somewhere the term "net" was thrown in by the automotive marketing folks, but there's nothing "net" about that standard. It measures crank horsepower with the engine as configured in the car including complete exhaust and intake systems.
Recently a lot of people have been quoting "Wheel" horsepower numbers. These numbers are even more imprecise then the old "Gross" horsepower numbers from years ago because there is no set, agreed upon standard for their measurement. Each of the chassis dyno companies (Mustang, Dyno-Jet, etc.) appear to generate horsepower numbers based on their own, proprietary process and algorithms.
Guest Anonymous
My old silver Z has 200 flamedevil.gif stock horsepower despite what the factory cuss.gif claims. 200 bonk.gif is an easy number to remember. I shifty.gif arrived at the hail.gif 200 figure by the seat of my pants after I polished the valve cover / removed the air filter burnout.gif LOL Remember, historically horsepower was based upon how much a four legged horse could pull.( and I have 200 of em chomping at the bit under that silver hood0.
You tell'em Tomahawk! :D
I can confirm the accuracy of that statement. As long as you remember to include the "WOW" factor. For example HP increases after a car wash or wax job! 2thumbs.gif
On a serious note;
BPH@RPM 149@5,600
Torque @ RPM 163 @ 4,400
6/75 Road and Track:
0-60 MPH 9.4 sec.
1/4 mile 17.3 sec.
top speed 119
fuel economy 19.5
curb weight 2,875
wheelbase 90.7
Len
OK, wait a minute here. According to those Specs the 280Z is actually HEAVIER than the 280ZX. I always thought the ZX was a 3000lb car and the 280Z was a 2700lb car. Is that really correct? If it is I am not happy about that. Although I stripped a ton of weight of my 280Z when I got rid of the bumpers. ;)
Pete
I know sounds wrong but I got it out of "Datsun/Nissan sports car buyers guide" by John Matras. On pg. 49 On pg 58 it says 79 280zx curb weight 2825 lbs.
wheelbase 91.3
BPH @RPM 135 @ 5,200
Torque @rpm 144 @ 4,400rpm
0-60 mph 9.2 sec
1/4 mile 17.2 sec.
top speed 121 mph
fuel enconomy 22mpg
so according to road and track magizine (what he got the information from the zx is 50lbs lighter than the 280z.
But also it says on pg. 60. The 1981 280zx Turbo weight was 2,995
BPH 180 @ 5,600rpm
0-60 mph 7.4 sec.
1/4 mile 15.6 sec.
top speed 129
fuel enconomy 20 mpg
There are also 2 different 280z too if you want to get technical. 75-76 with heavy chrome bumper and 77-78 with lighter bumpers and lighter bumper shocks. (they are still heavy) 77-78 also had a bigger gas tank too I think so the wet curb weight, it'll be little bit heavier than dry weight.
  Quote
Lack of standards = more accurate? Or was that a typo.
Guest bastaad525
Yes it's true some 280z's did weigh more than some 280zx's. I always love the reaction I got when I told people my 'big fat' 280zx was probably a couple hundred pounds lighter than their 'light little' 280z :-P
Oh well. Like I said I took off the bumpers of my '77 280Z so that should save some weight. I just like th look of the Z more than the ZX. The Z's suspension is a better design, too, and that will mean alot to me when I do track days. 2thumbs.gif I'll have to take it to a grainery and get it weighed when I am done.
