RPS30.Drvr Posted May 20, 2016 Share Posted May 20, 2016 I thought I would share some of the progress on my project RoninZ. Awhile back I wanted to do something different but still make my s30 handle better. Also wanted to find parts easily (cheaply). I asked and search for anyone that had done an s13 IRS swap into the s30 and found some old posts here in HZ and other forums. well I pulled the trigger and canibalized my s13 and put as much parts into the s30. The engine was going in also (sr20det) but that changed which is another topic. Anyway the IRS went in, a lot easier than I thought but, because of engine choice I couldn't use the s13 front suspension, and the z suspension was pitched. So, this brings me to this topic. I did some research and decided that I wanted to do the Double Wishbone/A-Arm suspension. I went with CA Chassishttps://www.cachassisworks.com/p-1556-a-arm-suspension-4x2-crossmember-custom-fit-factory-welded-crossmember-only.aspx Here is the crossmember with the disc before install on frame Here is the top view after install and fenders refabbed. Here is the A-Arms from underneath It included a manual rack and pinion The kit included double adjustable Coilovers and 13"Wilwood brakes (overkill?) Still at the shop and has not been on the road yet. I am hoping to go on Road courses with this car this summer. Thanks guys Quote Link to comment Share on other sites More sharing options...
clarkspeed Posted May 21, 2016 Share Posted May 21, 2016 Interesting. Is that Mustang II based? Quote Link to comment Share on other sites More sharing options...
260DET Posted May 21, 2016 Share Posted May 21, 2016 Like it, if the design is as good as they say then it should be great around a circuit. Just do me a favour though and weld those patches that look like they are just riveted. Quote Link to comment Share on other sites More sharing options...
jpndave Posted May 30, 2016 Share Posted May 30, 2016 Nice! I am planning to A-arm my car as well. I'll be interested how this turns out. Quote Link to comment Share on other sites More sharing options...
MREDDLE Posted June 14, 2016 Share Posted June 14, 2016 sub Quote Link to comment Share on other sites More sharing options...
