DuoWing 10 Posted June 11, 2016 Share Posted June 11, 2016 So I ordered the T3 Rear Lower Control Arms to put on my 280z forever project. Anyway I got them installed loosely, and I didn't tighten down the bolt and nut because the car is currently not going anywhere, but I see how I have a lot of space between the rod ends and the mounting point at the bottom of the strut. Is there an additional bushing that goes here, or do I just install the washers/shims in this space? If I'm installing the shims, does anyone have the order I should put the shims to end up with stock alignment? Quote Link to post Share on other sites
EF Ian 11 Posted June 11, 2016 Share Posted June 11, 2016 Thats what the washer are for, they allow you to move the wheel forward or backwards in the well depending on where you want it, I moved mine back a bit over stock. Quote Link to post Share on other sites
gnosez 8 Posted June 13, 2016 Share Posted June 13, 2016 Did the same thing on our 240. Not the best set of washers/spacers. I ended up making my own in various thickness. Quote Link to post Share on other sites
seattlejester 32 Posted June 24, 2016 Share Posted June 24, 2016 If you do not have pillow ball mounts up top, do not move the spacing of the wheel compared to factory. The rubber bush only has so much compliance. gnosez is right, they just include generic washers. You can make or purchase solid spacers if you have the correct measurements. Quote Link to post Share on other sites
OKAaron 0 Posted July 4, 2016 Share Posted July 4, 2016 So if I'm using stock components up top, what configuration of spacers/washers should I use? Quote Link to post Share on other sites
kona41 0 Posted July 6, 2016 Share Posted July 6, 2016 So I am putting together my set up, and before I install the wheel bearings would love to know if I have the caliper bracket installed correctly in these photos. I have the recess of the bracket facing out. I have mocked it up with caliper, stub axel and rotor, but just want to be sure, because I am not sure how the hell I could get the bracket off and flipped with the stub axle installed. Photos in the google link below. I will post up more photos of the install of this kit. https://goo.gl/photos/NEMkmKpiGa1tEzx76 Quote Link to post Share on other sites
kona41 0 Posted July 6, 2016 Share Posted July 6, 2016 I am an idiot. wrong thread. lol sorry. Also installing t3 lca. can post photos . hahhaha. colour me a moron. Quote Link to post Share on other sites
