christianmoller Posted August 1, 2024 Share Posted August 1, 2024 Those mirrors looks very nice, very close to the 1974 oem that i have on driver side. /C Quote Link to comment Share on other sites More sharing options...
toolman Posted October 2, 2024 Author Share Posted October 2, 2024 (edited) CREATING A HOT WHEELS 1/64 REPLICA OF MY 240Z While awaiting my Ford 8.8 Differential Conversion Kit, I decided to create a Hot Wheels Replica of my 240Z. Sure I made a lot of 1/25 scale model cars when I was a teenager. But I never made a 1/64 scale car. Maybe some other 240z owners might be interested in process. First, I started with a Hot Wheels version of a basic 71 Datsun 240Z. This car must opened up by drilling out the two Rivets that secure the body to the chassis. The body is stripped of all windows and prepared for paint stripping. Regular Automotive Paint Stripper can be used. This process should take only a half hour or so. The body shell is sanded with #400 sandpaper to provide smooth surface and eliminate any small burrs. Now, the most difficult portion of this job is the creation of opening doors, hood and hatch of this 240Z. As this car is a sports car, cutting the body must be performed carefully. I have used a regular hack saw blade to do the cutting. I would recommend to purchased a Hobby Saw(from Amazon). The Saw comes with blades small as 2mm and is much easier to handle in tight cuts. This pic shows the cutting of the Rear Hatch with a modified Hack Saw Blade. This pic shows a Pin Vise used to drill a .030 hole for the Hatch Hinge Pin. The Hatch Pin and Hatch Hinge shown. The Working Rear Hatch. Next time, Creating Opening Doors. Edited October 2, 2024 by toolman add text and pics Quote Link to comment Share on other sites More sharing options...
armorer Posted October 3, 2024 Share Posted October 3, 2024 Who's 8.8 kit are you using? Quote Link to comment Share on other sites More sharing options...
toolman Posted October 3, 2024 Author Share Posted October 3, 2024 (edited) Armorer, After much thought. I decided to use Incredible Extreme Muscle Car Garage one. He uses the Ford Super Duty 8.8 Differential which is much Stronger than the older Ford Explorer one. The kit uses Ford Mustang Suspension Parts( Hubs, bearings,etc) which readily available. His Box Structure for the differential makes the whole unit very strong. Watch his suspension work on that 8 second Green Z confirms this fact. Late Model Mustang used softer bushings in their rear suspensions. This caused many Mustang crashes because of being excessively soft. Drag Racers ended up in replacing all of the Rear Suspension Bushings in their cars. The Super Duty 8.8 differentials also has 34 splines vs 32 splines in Explorer ones. More splines gives additional torque strength. Broken axles can make the vehicle veer 90 degrees and cause a crash as there is no way to correct in time. Another reason to use a Super Duty 8.8 differential is it has a Torsion Limited Slip. Only a few Explorer 8.8 differential came with Limited Slip. I hope this info helps you make your decision. Edited October 5, 2024 by toolman add text and pics Quote Link to comment Share on other sites More sharing options...
armorer Posted October 4, 2024 Share Posted October 4, 2024 Toolman, I have his kit waiting for installation. Look forward to seeing your writeup on installation. I just got my LS3 & TR 6060 transmission. Will finally be starting my build late this fall. Quote Link to comment Share on other sites More sharing options...
toolman Posted October 14, 2024 Author Share Posted October 14, 2024 (edited) Creating Opening Doors and Hood- First thing in creating Opening Doors is cutting the Doors from the Die Cast Body. A Hobby Saw makes this easier if there curves involved besides just straight cuts, Notice the Shape of the Wire( paper clip can be used). The Straight End will attached to the inside of the Door Panel and Cruve Side willbe attached to the inside of the Fender( a flat side of plastic will drilled for the Hinge Pin to be inserted). This will the Hinge Pivot Point. The Body with Door Opening The Door Hinge installed first on the Fender The Horizontal Side of Hinge can be glued to the inside of the Door Panel. You can use masking tape to test fit the door before gluing this end of the Hinge on the inside of the Door Panel. Test Fit the Door by opening and closing the door and checking its alignment. You can carefully bend the Hinge till good alignment is achieved. The Hood Hinge is easily made by drilling a .027 hole in the headlight buckets on both sides of the Hood. Then a straight .025 wire is inserted between the Two Headlight Buckets. A Drop of Instant Glue can be used to fasten the Hood to this Pin. Test Fit the Hood and Bend the Wire carefully to get the Hood Aligned properly. The Car should resemble somewhat like this-Opening Hood and Doors with Hatch Open. Body Work-Rocket Bunny Flares Using Tamiya Epoxy Putty(available on Amazon) I formed the Putty into a Rough Shape of the Rocket Bunny Flares. Using a Sharp Knife, i sharped the Putty into Final Bodywork. Then Hand sanding with # 80 Grit Sandpaper. Then going to# 400 Grit to get the surface smooth. Priming the Car- Now, the Whole Car must be Primed inside and outside with Primer Filler. This will cover any left over scratches and small imperfections. Inside of Car Primered Outside of Body Primered. Next-Sanding and Painting Edited November 13, 2024 by toolman add text and pics Quote Link to comment Share on other sites More sharing options...
calZ Posted October 16, 2024 Share Posted October 16, 2024 You're a crazy man - in a good way. Quote Link to comment Share on other sites More sharing options...
toolman Posted October 28, 2024 Author Share Posted October 28, 2024 (edited) Painting the 1/64 scale 240Z- I masked off the Bottom of the car for the Bright Red Top Coat. I had to mask off the sections that would end up White. Next, After the Red Top Coar was sprayed and dried overnight, the masking paper was carefully removed. Now, the Red Section must masked off for the painting of the White Lower Section to be painted. At this point, the car should resemble something like this. While allowing the White Paint to dry 24Hours, I decided to work on the Engine Compartment. I had to fabricate the Aluminum Radiator. It made from Scrape Flat Plastic Sheet. I glued a tiny piece of fabric to give the radiator finned look. Then, I brushed it with Chrome Silver. Yes, the Radiator is Tiny. That small size of parts gave me the biggest headaches as parts were so easy to lose. Engine Compartment was also constructed with Flat Plastic Sheets. Note-Battery on the Left Side of the Firewall. The Radiator was mounted on the Fabricated Core Support which has the Holes on both sides of the Radiator. The Strut Tops were painted Red Metallic. Tweezers had to be used to installing all of the components (like brake master cylinder,etc) Brake Master Cylinder Finally, the LS3 motor (got from Ebay). but nobody made T-56 6speed transmission. So I craved on out of Balsa Wood. LS3 Motor detailed painted with Gloss Black on most engine components. LS3 AND T-56 Transmission installed in engine bay. Next-Detailing the Interior Edited October 28, 2024 by toolman add text and pics 2 Quote Link to comment Share on other sites More sharing options...
toolman Posted November 11, 2024 Author Share Posted November 11, 2024 (edited) Detailing the Interior- Installing the Battery into the Engine Compartment. LS3 Motor installed in car- Roll Bar installed and Chrome Rear Hatch Floor. using Tweezers to put in Door Handles and Window Crank on Left Door. Installing Door Pull on Door Panel on Right Door, Ebay supplied the 240z Morton Race 240z Decal Sheet for $10. After the Red and Blue Stripes with "DATSUN" were put on the cat then Clear was sprayed on. The Finished Car Pics- Top View 240z with Open Doors, Hood and Rear Hatch. Next- Ford 8.8 Differential Conversion Edited November 13, 2024 by toolman add text and pics Quote Link to comment Share on other sites More sharing options...
toolman Posted December 14, 2024 Author Share Posted December 14, 2024 (edited) Before I start I wish apologize for not having photos of my JDM Tour in Tokyo. I had about 20 pics to show but they got erased while correcting and lost all of them. Anyway while in Tokyo, I found a 5 hour Night Tour covering various Car Related Places to see. I chose the Shared Group Tour (about 6 to 8 people in a large Toyota van) and because it was a night tour, it didn't interfere my daylight plans. The cost of this particulate tour e $250 per person. It started at 4PM and ended about 9PM depending on traffic. Pickup Up point in my case was Toer Records in Shibuya. It was 300 yard walk from the Shibuya Train Station. At the end of the tour, you are dropped off near your hotel in Tokyo area. The First Stop was the Liberty Walk Store which is tiny 2store in a back alley on Tokyo. It was mostly Promotional Type of Store with t-shirts, hat, key chains,etc. Second Stop-AUTOBACS is a two building which houses a Parts Store (similar to our O'Reileys) on the Second Floor. The Top Floor held high end Racing parts(like Nismo, HKS,etc). Foreigners with Passports can get 10% discount off purchases. Their Book Section had car magazines, books,photo ablums,etc) ica 1/64 cars and all types of trucks and heavy equipment were on display... to purchase. Even had a STARBUCKS CoffeeShop. The Ground Floor, there was a Garage that could handle regular car maintenance or installation of even Turbo setup. Last Stop was the Daikoku Parking Area. This large parking is located in Yokohama Harbor. This parking area is next to where the Japanese Cars(Nissann Toyota,etc) are exported to US, Southeast Asia,etc. There was about 200 cars on the Friday Night that I went. Most of the cars there were the typical Street Racer types. Some JDM cars had UnderCar Lighting systems. A few cars had Full Body Wraps(Cartoon Girls Designs were popular). Majority of the cars were mostly on the quiet side probably because Toyko Strict Noise Regulations. There was one vehicle that caught my eye-it was White K Truck with an Extended Cab and Flat Bed. It had a Dual Floating Rear Axles( total of 6Tires and wheels). The rear axles move individually of each other. Unfortunately, the vehicle didn't stop and kept moving thu the parking area. People said the best night for car viewing was Sunday Night but I was leaving Monday morning, maybe next time. I would still recommend this Tour for Car Lovers to learn Japan Car Culture and see some unique vehicles. Edited December 16, 2024 by toolman text and pic corrections 1 Quote Link to comment Share on other sites More sharing options...
toolman Posted December 22, 2024 Author Share Posted December 22, 2024 (edited) I manage to find two pics that show Model Displays of Scale Motors at AutoBacs Store. Note -the prices of these motors are shown in Japanese Yen. To convert the price into US Dollars- just divide the Yen Amount by 150. The 150 is the Current exchange rate in Japan. One US Dollar is worth 150 Japanese Yen. These Motors have actual cranking movement driven by a small electric motor. Edited December 22, 2024 by toolman add text and pics Quote Link to comment Share on other sites More sharing options...
toolman Posted yesterday at 07:35 AM Author Share Posted yesterday at 07:35 AM (edited) Ford 8.8 Super Duty Rear Differential Conversion Kit for my 71' Datsun 240Z There are several different companies that have Ford 8.8 Differential conversion kits for S30 and later model 260 to 280z. However, most of them utilize the earlier model of Ford 8.8 Independent Rear Suspension from mostly 2005 Ford Explorers,Mercury Mountaineers and other SUV models. These differentials can handle 400HP and some even have Limited Slip in them. So they have been utilized in Drift Cars,Ford Trucks, JDM Cars and even BMW Racers. But, finding one is difficult because high demand and limited supply. Fortunately,a New and Stronger Version of the 8.8 came about-the# Super Duty 550 Differential with started to appear in 2015 Mustangs with Coyote Motors. This model can handle from 600 to 1000HP ( with beefed up). It weighs over 100 lbs and comes a Torsion Limited Slip. I ordered my Super Duty 8.8 from Summitt Racing for $1300with 3.55 Gears. + shipping. At the same time, I ordered the Sonan 8.8 Drive Shaft Adaptor from Summitt Racing for $179. They manufacture Two Versions of this Adaptor. One for Manual Trans and One for Automatic Trans. The difference is the number of splines on the Pinion Shaft. My 3.55 pinion takes the Automatic Trans Adaptor. It is constructed of Billet Aluminum and handle alot of horse power. This adaptor costs about $179. Next-Installation of Incredible Extreme 8.8 Differential Conversion Kit Edited 8 hours ago by toolman add text and pics 1 Quote Link to comment Share on other sites More sharing options...
