Bartman Posted April 18, 2017 Share Posted April 18, 2017 Anyone here running Stanceparts air cups? Seems like a good idea to allow a low ride height and still have the ability to raise the car for obstacles, towing, etc. There is a video of this kit installed on a 240Z at the product website stanceparts.com. You normally ride without any air in the cups, so they claim it doesn't affect the handling of the car at all. Quote Link to comment Share on other sites More sharing options...
texis30O Posted April 18, 2017 Share Posted April 18, 2017 Thank you for allowing me to spend MORE money on my car..... 1 Quote Link to comment Share on other sites More sharing options...
Bartman Posted April 19, 2017 Author Share Posted April 19, 2017 Thank you for allowing me to spend MORE money on my car.....Just returning the favor (moonbeam kit) Quote Link to comment Share on other sites More sharing options...
Nelsonian Posted April 19, 2017 Share Posted April 19, 2017 HRRMMM, This would certainly help with lowered car + 3" exhaust against the hills and speed bumps around here. Interested to see more on it... Quote Link to comment Share on other sites More sharing options...
Rob L Posted April 19, 2017 Share Posted April 19, 2017 I would be interested ... will they drop the cost on a group buy for us ? ...might be something to contact them on if enough guys want it . Quote Link to comment Share on other sites More sharing options...
gnosez Posted April 19, 2017 Share Posted April 19, 2017 I might even be able to drive into a slanted ramp parking garage. Oh right, the exhaust tone will still set off car alarms. It does however look like a solution to a real problem. The air tank is a bit of an issue however. Quote Link to comment Share on other sites More sharing options...
seattlejester Posted April 19, 2017 Share Posted April 19, 2017 (edited) Not sure how well that setup would fit with any car running camber. My recollection is not too much room up there based off of how big the cups look in the pictures. Would be nice though if it works as advertised having lift to navigate those silly high speed bumps and such would be a awesome. Based off some little reading it looks like a piston/hydraulic ram type setup vs a bag which makes this way better in my book. It seems like you set at desired ride height and just lift the car for obstacles which means if they fail you aren't dragging just at your set ride height Also of note, tein had a similar system if I'm not mistaken. Edited April 19, 2017 by seattlejester Quote Link to comment Share on other sites More sharing options...
LLave Posted April 20, 2017 Share Posted April 20, 2017 Not sure how well that setup would fit with any car running camber. My recollection is not too much room up there based off of how big the cups look in the pictures. Would be nice though if it works as advertised having lift to navigate those silly high speed bumps and such would be a awesome. Based off some little reading it looks like a piston/hydraulic ram type setup vs a bag which makes this way better in my book. It seems like you set at desired ride height and just lift the car for obstacles which means if they fail you aren't dragging just at your set ride height Also of note, tein had a similar system if I'm not mistaken. I had that thought too. There is not much room in the top of the strut tower, if the device did fit in there, it would be seriously limited in adjustability. Quote Link to comment Share on other sites More sharing options...
seattlejester Posted April 20, 2017 Share Posted April 20, 2017 They have a Z car in the media section running it, the question would be how much modification was involved in fitting them I guess the next time someone has a wheel off they can measure. Specs say 110mm, which is a bit over 4 inches. I think the stock springs were 3.5 inches? With the perch maybe 4 inches? Seems like it would clear, getting the fitting in might require a bit of clearancing and if cambered over then potentially problematic. I have to say their website is very complete has all the info you want and such. Quote Link to comment Share on other sites More sharing options...
texis30O Posted June 20, 2017 Share Posted June 20, 2017 You have to purchase a smaller ( height wise ) spring. The springs come in varying sizes and diameters so that is not the issue here. I am waiting to see what happens this summer with a product that is supposed to launch. I agree that the compressor and tank are an issue for me. But I can always have one fab'd up and place it in the rear of my car. You just have to think things through..... Quote Link to comment Share on other sites More sharing options...
seattlejester Posted June 20, 2017 Share Posted June 20, 2017 I imagine this is primarily meant for adjustable coilovers. The concern was more so for the physical area available, given the stock assembly is about 110mm, running coilovers with the traditional 2.5 inch ID springs there should be quite a good amount of room inside the cup, the outside of the cup would be the question. Seems if it is about the same size you could get away with a couple degrees of camber and still have room. Might have to use a straight fitting instead of a 90 and drill through the shock tower. Would be interesting to see what is involved. Scraping frame is really not something I enjoy, but the downfalls of a bag are just too high for my personal tastes. Quote Link to comment Share on other sites More sharing options...
Autismisakiller Posted June 21, 2017 Share Posted June 21, 2017 Anyone have instagram and speak Spanish? Translating everything is a bit difficult. Looks like this is/was/may be the owner. https://www.instagram.com/yoshi_yokota/ Here are some more pics it's a 2jz swapped 240z https://www.instagram.com/p/xZUgH0Kdjv/ https://www.instagram.com/p/BBGi0FmKds0/ Quote Link to comment Share on other sites More sharing options...
