280Z Garage Sale
Kash
Misc. Z Parts for Sale.  Assume all parts are from my 1978 280z unless started otherwise.  All parts are used (except for a few as stated) and priced well below cost to me but open to BO or package deals…can provide more pictures of specific parts if an email address is provided.  See link for available pic’s…will be loading up the remainder by this weekend.
https://postimg.org/gallery/1kr7vy04s/
https://postimg.org/gallery/3dypy0ap8/
Headlight cover $40.00
280z console lamp set w/ bulbs $15.00
Rear Tail lights w/ Reverse lights $75.00
280z marker light set $15.00
280zx marker light set $15.00
280zx turbo boost sensor $5.00
280zx turbo distributer $50.00
280zx intake manifold cooling fan timer  $5.00
280zx lightweight AC Compressor (direct replacement for 280z) $50.00
280z AC Compressor $25.00
240z side emblems (a few broken tabs but will come with 2 sided tape to affix) $15.00
240z Wood Steering Wheel in great shape (no horn pad) $75.00
Complete like new 280z Steering wheel (great for resto project or to keep as spare) $100.00
280z ignition lock and key (misc. door/ truck locks w/ keys as extras) $50.00
Relay box with relays $10.00
OEM Air Tank for your resto project $10.00
OEM Spare for your resto project $40.00
Hybrid 3 speed Honda Wiper motor with Arms $40.00
On car adjustable aluminum camper (F & R) and tension rod Set with tool $75.00
All four shock tubes $100.00
Rear Control Arms (L & R) $60.00
Diff mount cross member and Support (modified to prevent clunk) $10.00
280z differential mustache bar w/ polly bushings $40.00
Complete N47 Cylinder Head taken from running engine $75.00
Disassembled p90a head $75.00
280z solenoid vacuum valves and Bottle $5.00
Horn Pad $5.00
Radiator $40.00
Front Toyota Monoblock 4 piston Disk Brake System w/ braded lines (cross drilled rotors) $125.00
Miata Seats w/ Z tracks (direct bolt on and looks great) $200.00
Walbro fuel pump $50.00
Power Antennae $40.00
Full E-Brake System $50.00
Interior panels and leather(et) trimmings $100.00
Door Panels Cards (great conditions) $125.00
Full 280z 3 in exhaust system (from downpipe to Magnaflow muffler) $125.00
15x7 Aluminum Mesh Rims w/ center caps $150.00
280z steering column $25.00
Full set or 280 gages (no clock but includes boost gage) $100.00
Full set of OEM 280z shock mounts (F & R) $50.00
ABS Steering Coupler (new), unit 1 $20.00
ABS Steering Coupler (new), unit 2 $20.00
Headlight combination Switch, unit 1 $40.00
Headlight Combination Switch, unit 2 $40.00
280z gas tank cover $10.00
280z Hood $50.00
280z Facial Mask/ Bra (new in box) $75.00
Inspection Lamp $10.00
OEM Jack Kit $40.00
Speedometer cable $20.00
Brake & Clutch booster/master cylinder heat Shield (w// manual boost gage adjuster) $20.00
Do not hesitate to contact me via cell or PM.
Ken
(847) 345-1215
Status updates added below:
Headlight cover $40.00: SoldZetsaz/Ca
280z console lamp set w/ bulbs $15.00:
280zx turbo distributer $50.00: Sold, Jeff/ Fa
280z AC Compressor $25.00: Sold, Andrew, Tn
240z side emblems (a few broken tabs but will come with 2 sided tape to affix) $15.00: Sold, Solidrock
240z Wood Steering Wheel in great shape (no horn pad) $75.00: SOld, Alex
Complete like new 280z Steering wheel (great for resto project or to keep as spare) $100.00: SOLD
280z ignition lock and key (misc. door/ truck locks w/ keys as extras) $50.00: Sold, Solidrock
Hybrid 3 speed Honda Wiper motor with Arms $40.00: Sold, Chris/WA
All four shock tubes $100.00: Sold, Kevin/Canada
Rear Control Arms (L & R) $60.00: SoldJsteg
280z differential mustache bar w/ polly bushings $40.00: SOLD
Disassembled p90a head $75.00: SOLD
Horn Pad $5.00
Radiator $40.00: SOLD
Front Toyota Monoblock 4 piston Disk Brake System w/ braded lines (cross drilled rotors) $125.00:
Power Antennae $40.00:
Interior panels and leather(et) trimmings $100.00: SOLD
Full 280z 3 in exhaust system (from downpipe to Magnaflow muffler) $125.00:
280z steering column $25.00: SOLD
Full set or 280 gages (no clock but includes boost gage) $100.00: Sold, Kevin/Canada
ABS Steering Coupler (new), unit 1 $20.00: Sold, Alex
ABS Steering Coupler (new), unit 2 $20.00: 1 Sold
Headlight combination Switch, unit 1 $40.00:
Headlight Combination Switch with High/Low beams dim switch $60: Sold, Dan/Fa
280z gas tank cover $10.00: Sold, Solidrock
280z Hood $50.00: Sold, Solidrock
Inspection Lamp $10.00: Sold, Zetsaz
OEM Jack Kit $40.00
Brake & Clutch booster/master cylinder heat Shield (w// manual boost gage adjuster) $20.00: Sold, Zetsaz
280z Engine under tray $75: Sold, Zetsaz
280z Washer Bottle $15: Sold, Zetsaz
280zx Turbo intake boot $40: Sold, Jeff/Fa
Power Steering Tensioner $15:
On car adjustable aluminum camber (F&R) and tension rod set $75.00: Sold, Jsteg
Light weight A/C Aluminum bracket with belt tensioner $35.00
280z front Control Arms w/ ball joints, steering knuckles, aluminum bump steer spacers, tension rods with polly bushings $50.00: Sold, Jsteg
280zx Turbo coil and igniter $30.00
280zx Turbo igniter $15.00
300zx Coil $20.00
1987 300zx Turbo ECU $50.00
Please let me know if got any update wrong or if I missed anyone.
Ken
Edited by Kash
  On 8/18/2017 at 8:59 PM, az240z said:
Interested in the 280z console lamp set w/bulbs, 280z steering column, and 280z mustache bar.  Shipping to 85308
Hi,
I will get you a quote ASAP.
Ken
Edited by Kash
  • 4 months later...
Horn Pad $5.00
OEM Jack Kit $40.00
300zx Coil $20.00
Ken
Expand
10
Ken,
How much for the gas tank?
  • 2 months later...
  • 7 months later...
Hey, I'm new to this site and was wondering how much you have left. I was hoping you might still have the front mask/bra, do you have the hood release cable and handle,
would you happen to have a 5 speed shift knob with red insert. Just a wish list for me. Thanks for just reading.
