tamo3 Posted March 4, 2018 Share Posted March 4, 2018 Hi, I'm having issue on clutch. Even though replace to new Clutch slave cylinder, the cylinder pin push out clutch folk all the way to the end. Do I need to replace clutch pressure plate? Quote Link to comment Share on other sites More sharing options...
Leon Posted March 4, 2018 Share Posted March 4, 2018 Looks normal to me, it's a self adjusting slave just doing its job. Have you been able to drive the car yet? Quote Link to comment Share on other sites More sharing options...
tamo3 Posted March 4, 2018 Author Share Posted March 4, 2018 Thanks Leon for quick reply. I'm still trying to figure out this and brake line. So, when engine start running, will this clutch folk push in the clutch slave cylinder? When I step on the clutch pedal I don't feel any traction at all. Quote Link to comment Share on other sites More sharing options...
seattlejester Posted March 4, 2018 Share Posted March 4, 2018 Clutch pedal is fairly light depending on your pressure plate of course, even with an uprated one I don't feel too much resistance. I'm not sure there is supposed to be that much movement in a well bled clutch slave. If I recall you did the KA transmission? Is there something with that, like maybe you are supposed to use the KA fork or slave? Quote Link to comment Share on other sites More sharing options...
Leon Posted March 5, 2018 Share Posted March 5, 2018 If you used a stock clutch, the pedal will be lighter than expected as mentioned above. I also agree that you might still have some air in the line. Frankly, I wouldn't worry about it unless you know you have an actual issue. The worst that will happen is you start the car and can't put it in gear because your clutch isn't disengaging. Quote Link to comment Share on other sites More sharing options...
tamo3 Posted May 15, 2018 Author Share Posted May 15, 2018 Thanks for the feedback. I've been working with brake issue. Just realize I used wrong bleeder size cause the problem. I'm afraid of the clutch though away bearing size is the wrong size since I replace my tranny to FS5W71C(240SX tranny). Does anyone swap tranny to 71C and replace the though away bearing? Quote Link to comment Share on other sites More sharing options...
NewZed Posted May 15, 2018 Share Posted May 15, 2018 The front case that you installed on the 71C gears is from the 71B. It contains the clutch fork pivot ball. So as far as distances go for the clutch, everything works just like a 71B transmission. The throwout bearing collar has to match the pressure plate height. Not the transmission. Quote Link to comment Share on other sites More sharing options...
cgsheen Posted May 16, 2018 Share Posted May 16, 2018 (edited) You have the wrong collar for your clutch package. If it were correct, the fork position would be pushing the slave cylinder push rod all the way back in (like you're showing you can do with your fingers in the video) - or nearly so. You need a longer collar for your throw out bearing. NewZed hit the nail on the head - the collar needs to be correct for the clutch package (pressure plate height (or thickness)) Edited May 16, 2018 by cgsheen Quote Link to comment Share on other sites More sharing options...
tamo3 Posted July 24, 2018 Author Share Posted July 24, 2018 On 5/15/2018 at 7:56 PM, cgsheen said: You have the wrong collar for your clutch package. If it were correct, the fork position would be pushing the slave cylinder push rod all the way back in (like you're showing you can do with your fingers in the video) - or nearly so. You need a longer collar for your throw out bearing. NewZed hit the nail on the head - the collar needs to be correct for the clutch package (pressure plate height (or thickness)) Is there anywhere I can find information on how to find out correct length of the collar? Quote Link to comment Share on other sites More sharing options...
NewZed Posted July 24, 2018 Share Posted July 24, 2018 (edited) It's not the collar alone that matters. It's the collar (or sleeve as Nissan calls it), and the pressure plate. Together. Start at #35 here and it will make more sense. Maybe. https://www.classiczcars.com/forums/topic/44389-l28-is-toasting-my-240z-clutch/?page=2 Here's another interesting one - Edited July 24, 2018 by NewZed Quote Link to comment Share on other sites More sharing options...
