New here, looking to pick up a 280Z this weekend.
Sadeem28
Floors, under the battery tray, spare wheel well, exterior doglegs, and the hatch sill are the most common areas. You should also check if the frame rails are crushed or not. That's a relatively easy replacement, but it's good to check what condition they're in.
Expand
 Great info.. will make notes of it.
If you don't know what to look for I would suggest finding someone who does. An extra $100 spent here or lunch or beer or whatever is going to save you weeks of work down the line, and an objective voice to tell you to walk away may be worth far more than that.
https://zcarguide.com/datsun-240z-rust-inspection-guide-common-rust-areas/
http://zhome.com/Classic/CommonZRust/RustPrevention240Z.htm
Are good links. Keep in mind if some of those are gone it is most likely hiding other things. If the body has completely rusted through I would be highly suspect of the frame rails. Same with the battery tray if those are gone frame rails are most likely affected.
Expand
Appreciate the input. The guy ending up selling it before i could get there. Search is still on.
All,
I ended up picking up a 1977 datsun 280z yesterday with 63k miles and matching numbers. The rust is not that bad, the floor pan on the driver side has been patched up with rivets.
The guy tried to sand the paint and prime it and eventually realized that he couldn't do it.
The car kinda runs but doesn't stay on for more then 30 seconds. What to check for ?
What should I change to try and make it run ?
Oil and oil filter change ?
spark plugs ?
injectors ?
got all the service guide and owner manual downloaded ;)
Edited by Sadeem28
grammer
 Start with a complete tune-up including a valve adjustment. You can listen to the injectors click by using a screwdriver as a stethoscope. The pointy end touches the injector, the handle lightly pushing on your ear. There's a troubleshooting section in the factory manual that systematically goes through each elec. circuit. Most people reviving an old Bosch EFI have found it very useful. It's available as a download at classiczcars.com.
Expand
thanks, I have started gathering documents and tools that I may need. Got the battery out to charge it and noticed the battery tray has a lot of rust issues to the point it was crumbling in my hands.  Any recommendations on new smaller battery and maybe move it to the back ?
  On 6/18/2019 at 4:32 PM, Neverdone said:
https://skillard.com/products/braille-battery-box
if the sheet metal in the normal battery area is complete crap, might want to look into this as well
https://skillard.com/products/s30-battery-tray-area-patch
Expand
The full tray area looks like a better fit. Any recommendations on a battery ?
  On 6/18/2019 at 7:37 PM, seattlejester said:
My bet would be fuel related. I would say if you take off the return line and I bet it will dribble by the time it shuts off, most likely a clogged filter or gummed up lines.
Please be safe when working with fuel!
Expand
Yeah I was thinking fuel too because he was just going crazy and spraying starter fluid.
