What fuel injectors for OER ITBs
ccc
first up, you need to get the physical size right- distance between the o rings and diameter of the o rings. if like my Fajs ITBs it'll be 61mm and 14mm.
then you have to get the electrical connector right - if your efi comes with a harness, it'll already have connectors, probably uscar or jetronic.
then you want to pick the right flow rate. 330cc will get you to around 50bhp/cylinder.
I have Bosch 0280156095 which were on european ford focus st170 10/15  years ago and so are quite cheap.
Edited by jonbill
  • 3 months later...
Thanks for the recommendations so far. Thought I had found ones that fit but no luck once they arrived.
Does anyone know how I can find fuel injectors based off physical size?
I measured out the fuel injector housing space and made this drawing of what I'm looking for. 16008726020331013860531611758223.jpg.2c90754760a5e526ff2d8b96fa07a6ac.jpg
I have vintage SK throttle bodies, basically the same casting as the OER.  I plan on an injector like this.
https://www.highflowfuel.com/i-35459212-genuine-bosch-ev1-36lb-390cc-fuel-injectors-0280158124-set-of-6.html
I am still trying to find the spray pattern for it.  Bosch made this model in 4 spray angles and 4 spray patterns.
My plan is a single cnc fuel rail.
I know people have used the RX7 injectors with success.
