LS6 swaps: keep the DBW or convert to DBC
Depends if you have the computer or not already. if you dont, you just have to get a DBC throttle body and a F-body Camaro computer. They were DBC. Thats what i did. Im just a mechanical guy so it seemed easier but i"ve learned its not a big deal to do DBW if thats what you have. Im not sure what has to happen with the gas pedal for DBW but my guess is there is a simple solution for it if you research it.
Depends on computer you will use.... I went DBC for a few reasons - I wanted to use the Holley Terminator X - $1000 model... So i went DBC - Cheap and reliable and can be make to look nice on the install. DBW would be amazing also for a cleaner look. If staying stock computer and your engine you buy has a DBW setup - run DBW. So long as you have the pedal and what not.
