Guest Cusp Posted August 12, 2002 Share Posted August 12, 2002 This is a link to Jeff P.'s custom 3" exhaust system designed for the 280zx turbo. JeffP.'s custom exhaust Has anyone tried to adapt one of these setups to a turbo 240z? I've been looking at the exhaust systems they sell in V.B. to see the length/shape differences from the 240z to 280zx exhaust designs. It's pretty close, but it looks as if the exhaust for the 280zx has to bend under the axles, whereas the 240z's does not. I'd be interested to hear if this has been tried, or if it's cheap enough fro me to just try it. Maybe Jeff knows if it will fit. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 12, 2002 Share Posted August 12, 2002 That's awesome, Jeff! And here I was thinking I'd have to be the first to have a custom 3" made for the ZXT. My "exhaust guy" was just as amazed as I, that's a really nice system. Have you made a SS prototype? I'm very interested in buying your system. I will be running a full T4 turbine (p-trim), and I like the expansiveness of the DP design. Exhaust will be the last step of my swap, please keep us informed on progress design. -980mak Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted August 13, 2002 Share Posted August 13, 2002 For my 280Z, the three inch exhaust is MUCH simpler than a 280ZX. From my down pipe it is a straight length of pipe with 2 90* mandrel bent pieces at the end. I have not actually built this yet, but I am running the exact thing in 2-1/2" right now. Quote Link to comment Share on other sites More sharing options...
scottyMIz Posted August 13, 2002 Share Posted August 13, 2002 i'm running 3" from my dp to the back and it fits fine.I'll have to get some pics i had the local muffler guy do it for me. Quote Link to comment Share on other sites More sharing options...
Jason81NA,82RBtt Posted September 4, 2002 Share Posted September 4, 2002 It too easy to just have someone make a 3in for the Z rather that try to make one fit from a ZX. The reason that he is selling a 3in for the ZX is that most shops won't even try to install a 3in system in a ZX.I know I tried!!! Good Luck JasonRB260ZX Quote Link to comment Share on other sites More sharing options...
fl327 Posted September 13, 2002 Share Posted September 13, 2002 single 3 works good in early z body, dropped trans w/o dropping pipe, fell in love with the system then, now if only i could do the same with the diff... Quote Link to comment Share on other sites More sharing options...
awd92gsx Posted September 13, 2002 Share Posted September 13, 2002 anybody else notice the "Turbo Diesel" badge on the back of the z? Quote Link to comment Share on other sites More sharing options...
R0N Posted September 13, 2002 Share Posted September 13, 2002 Bill, when I first saw it I said huh? Then I remember he is using LD28 crank. Well it's sort of true Quote Link to comment Share on other sites More sharing options...
jeffp Posted September 20, 2002 Share Posted September 20, 2002 Yea that turbo diesel has caught a few people's eye. I thought it was cool, so I put it on. It is true the engine is stroked with a LD28 crank and that is why I put it there. Tell you guys what, if someone was willing to let me have their car for a while(has to be a turbo application) I would be willing to make a custom mandrel 3" system for the 240 cars. The problem with all of it is that my bender has to make a minimum run of 15 sets to make them after I have designed the proto system. Maybe there are enough turbo 240's out there to make it worth all the time and effort. I csn terll you one thing tho, the system flows excellent snd it sounds excellent also. Quote Link to comment Share on other sites More sharing options...
David K Posted September 20, 2002 Share Posted September 20, 2002 Quote Originally posted by jeffp:I csn terll you one thing tho, the system flows excellent snd it sounds excellent also. Hell yes i can vouch for that! Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted September 20, 2002 Share Posted September 20, 2002 i have a 3" mandrel bent system under my 77.it only takes 2 90's .i put the muffler under the cat heat shield .any good muffler shop can do it .it bolts to stock zxt head pipe flange.when its smog test time i bolt on system with a cat converter.i used a 3" magnaflow muffler -it has no baffles.its quiet and sounds good. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 29, 2003 Share Posted April 29, 2003 I am looking for a custom 3in system for a 77 280zt usng mandrel bent piping since my car is dropped about 2in the system that the local muffler shop did hits every bump it passes over Quote Link to comment Share on other sites More sharing options...
280Zen Posted May 9, 2003 Share Posted May 9, 2003 I just wish there were more folks wanting the 3" system for the 280zx, I've been working my butt off saving money to get in on the run of 3" exhaust that JeffP was offering. but since there were not enough folks that wanted the "whole" system I guess just the downpipe part is being offered. Quote Link to comment Share on other sites More sharing options...
BRAD D Posted May 10, 2003 Share Posted May 10, 2003 I have two 90deg bends and two 15deg bends to go in the transmission tunnel, it helps clear big transmissions. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted July 29, 2003 Share Posted July 29, 2003 awd92gsx said: anybody else notice the "Turbo Diesel" badge on the back of the z? I did. Quote Link to comment Share on other sites More sharing options...
