maichor Posted August 19, 2003 Share Posted August 19, 2003 Well, I am almost done with the suspension. So, here is what I've got: 5 lugs, big disc brakes with e-brake, tough axles and VLSD diff. with monster 335/35/17 tires. I am using Cobra R wheels, Viper tires, 240SX subframe and suspension arms, 11+" vented rotors with calipers from an Infiniti J30 (bolt-on), and R230 VLSD Infiniti Q45 diff. (3.54). I wanted the 3.7 300ZTT but I picked up this diff for $100. Total cost I think has been relatively low. My two brothers, both mechanical engineering guys and my Dad are coming next week to help me mount my VR kit and to finish up all the odds and ends. So, hopefully, by September I will have a running, driving LS1 powered Velo Rossa. I will take time then to sort through all of my pictures and do a write up on the LS1, Suspension etc. Wish me luck! I only have a few pics up now but here they are. http://f2.pg.photos.yahoo.com/ph/maichor75104/lst?.dir=/Velo+Rossa-Zcar&.view=t You may have to cut and paste this link of old pics of my LS1 mounted. http://www.geocities.com/maichor75104/ Quote Link to comment Share on other sites More sharing options...
Tim240z Posted August 19, 2003 Share Posted August 19, 2003 Damn Those are some monster meats!!! Cool!! Quote Link to comment Share on other sites More sharing options...
fl327 Posted August 19, 2003 Share Posted August 19, 2003 good lord thats beautiful!!! any more photos of that sx rear suspension install? Quote Link to comment Share on other sites More sharing options...
jeromio Posted August 19, 2003 Share Posted August 19, 2003 What's your plan for the front suspension? Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted August 19, 2003 Share Posted August 19, 2003 Me likee.....that thing is gonna have some insane grip! Hope that 240sx diff. is up to the challenge. Like they say "Its not power that breaks diffs., its traction". Thats a wicked setup, would love to see the undercarriage. Too cool. Quote Link to comment Share on other sites More sharing options...
Wagz Posted August 19, 2003 Share Posted August 19, 2003 That rear suspension is going to be sweet! Can't wait to see a write-up on the install and pics of the final product. Quote Link to comment Share on other sites More sharing options...
maichor Posted August 20, 2003 Author Share Posted August 20, 2003 Thanks for the compliments and encouragement guys. Yes, I do have more pictures, lots of them, but I am very pressed for time and so I haven't uploaded too many yet. Things will calm down in a few weeks and I will be able to spend more time on the computer. Front suspension? Well, I am doing my best to fit the Cobra R 17 X 9's on with Z31 hubs. It will be close since I have about 2" of flare up there. The front tires are 275/40/17's, also from a Viper. I picked up the set of Michellin XGT's, used but not dead, on ebay for $50. Gotta love ebay! Factory specs say you should have 11 inch wheels for 335's I may move down to 315's until a rich uncle dies and leaves me $ for CCW's or some other custom wheels. Cobra wheels are the perfect offset to give max back spacing. As far as the diff handling the power. I don't know, but I have Q45 shafts which are larger diameter and the diff is not from the SX it is from the Q45, R230. If it breaks, I did my best. I may have to learn how to control that right foot! :flamedevil: Quote Link to comment Share on other sites More sharing options...
stony Posted August 20, 2003 Share Posted August 20, 2003 I'm assuming you pretty much had to backhalve the car to pickup the subframe mounting points? that is a wicked setup. Quote Link to comment Share on other sites More sharing options...
Bob_H Posted August 20, 2003 Share Posted August 20, 2003 I am really interested in some pictures of how you actually mounted the subframe to the car as it directly relates to some work I am doing to my Z. Any and all pictures, either posted on yahoo or e-mailed directly to me are greatly apprecaited. Thanks! Bob Hanvey rehanvey -at- yahoo.com (obviously replace the -at- with @) Quote Link to comment Share on other sites More sharing options...
pparaska Posted August 20, 2003 Share Posted August 20, 2003 That looks great! That's going to be one mean looking VR with those meats under it! I too am interested to see the pics of how the 240SX subframe was mounted in the 240Z. Quote Link to comment Share on other sites More sharing options...
maichor Posted August 20, 2003 Author Share Posted August 20, 2003 Obviously, this does require extensive modifications, I made a few mistakes, actually cut out too much of the unibody etc., but it is all working out. I didn't have to backhalve the car for the suspension points. . . but, that would probably have been easier! To position the subframe, I made a plate that bolts up to the mustache bar mouning points and has the subframe mounting points drilled on center to those holes. That put the subframe square and centered. As far as mounting the subrame, new reinforced areas had to be welded in for all 4 mounting points and the bottom of the tool carrier cubby holes had to be removed. Then, the unibody needed to be reinforced because I cut most of the original rear portions of it out. As someone mentioned, the best view will be from underneath. I do not have any pics of that. The car is my homemade rotisserie right now, so maybe this weekend I can flip the car up on its side and take some pics. Check back on this post after the weekend and I should have them up. I hope! Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted August 20, 2003 Share Posted August 20, 2003 Love those engine mounts too, did you make them? Quote Link to comment Share on other sites More sharing options...
maichor Posted August 20, 2003 Author Share Posted August 20, 2003 The upper portion is the stock aluminum Corvette tower. My two brothers and I spent one evening when we got together last Christmas in a friends machine shop to make them. It was so much fun, they are coming to Texas to help install the VR kit and get as much done as possible in a week. Quote Link to comment Share on other sites More sharing options...
H. Garcia Posted August 20, 2003 Share Posted August 20, 2003 Maichor, Great pics!!, I'm doing the exact same install in my 73 (including the LS1), but, I'm using the 300ztt subframe suspension and diff . Please post pictures of your progress, I'm not going to begin the fitting until sometime next month, so your input should be very helpful. Quote Link to comment Share on other sites More sharing options...
fastzcars Posted August 20, 2003 Share Posted August 20, 2003 WOW. 335's , that's insane I likee too. more pictures please. Quote Link to comment Share on other sites More sharing options...
maichor Posted August 25, 2003 Author Share Posted August 25, 2003 By popular demand, I added a few more pics. I should have pics of my permanent mounting setup soon. http://f2.pg.photos.yahoo.com/ph/maichor75104/lst?.dir=/Velo+Rossa-Zcar&.view=t Quote Link to comment Share on other sites More sharing options...
jeromio Posted August 25, 2003 Share Posted August 25, 2003 That is incredible. You are one ambitious dude. Quote Link to comment Share on other sites More sharing options...
maichor Posted September 3, 2003 Author Share Posted September 3, 2003 A few more pics were added Quote Link to comment Share on other sites More sharing options...
blueovalz Posted September 3, 2003 Share Posted September 3, 2003 Great work. I'm probably missing something here, so I'll ask; with such deep backspacing on these wheels, how will the spring/shock assembly be incorporated into this swap. It appears that the wheels will interfer (and not by a small amount) with the shock. Quote Link to comment Share on other sites More sharing options...
maichor Posted September 4, 2003 Author Share Posted September 4, 2003 Actually, the lower control arm has the tightest clearance. It is only 1/4"at the top of the suspension travel and ~1/2 at the bottom. The closest the spring gets to the wheel is ~9/16" All in all, the wheels fit very nicely. Quote Link to comment Share on other sites More sharing options...
