Guest ON3GO Posted August 27, 2003 Share Posted August 27, 2003 guys im in a stump, i need brake lines... i have the wilwood NDL calipers in the front, with silvia/240sx rear brakes... and a 280ZX turbo brake master cylinder, slave cylinder.. i need brake lines bad.. anybody have any clue... i need them fast too, got something going on to get this car done this month. thanks! mike Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted August 28, 2003 Share Posted August 28, 2003 please somebody help me out. i was told i need custom brake lines because of my wilwood front brakes and my silvia rear brakes.. also have 280ZX turbo master cylinder and slave cylinder.. im in a stump.. im leaving very soon and need to buy them today! or ASAP!. anybody? Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted August 28, 2003 Share Posted August 28, 2003 Looks like you will have to make them. Go to NAPA, they have metric brake lines, pre-made in different lenghts. All you have to do is bend them where needed. They also have standard lines, and metric to standard, standard to metric, fittings. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted August 28, 2003 Share Posted August 28, 2003 What do you need? Solid or flexible lines? or both? Give Earls a call, here in Los Angeles. The manager actually races a Z, so he knows them well! http://www.earlsperformance.com/html/index.htm Tim Quote Link to comment Share on other sites More sharing options...
zcarnut Posted August 28, 2003 Share Posted August 28, 2003 A much better website for Earl's products is their UK site: http://www.earls.co.uk/ You can even download their catalog. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted August 28, 2003 Share Posted August 28, 2003 well no luck at NAPA, discount auto, auto Zone, or a local speed shop.... damn. i dont even no the right size fitting for the wilwood calipers or the size for the stock brake lines.. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted August 28, 2003 Share Posted August 28, 2003 ah its 1/8 - 27 NPT inlet... so i gotta get that size fitting but cant find one at all!!!! Quote Link to comment Share on other sites More sharing options...
johnc Posted August 28, 2003 Share Posted August 28, 2003 Make them yourself! Buy a double flare tool, a tubing bender, the fittings, etc. Practice a lot with the flare tool until you can reliably make a good double flare. Then start on your car. Expect to screw up a few lines but eventually you'll get them done. Quote Link to comment Share on other sites More sharing options...
denny411 Posted August 28, 2003 Share Posted August 28, 2003 You may want to have someone at a local garage give you some pointers on how to use the double flare tool. They are really simple...IF you know what you`re doing, but can be a real pain if you don`t. Quote Link to comment Share on other sites More sharing options...
Twentyfourouncer Posted August 28, 2003 Share Posted August 28, 2003 Have you tried http://www.pegasusautoracing.com? They have a lot of brake fittings and adaptors that may help you. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 28, 2003 Share Posted August 28, 2003 I believe what you are looking for is a female inverted flair 10mmx 1.0 thread to a #3 male these are avaliable in straight to 90 degree versions. This thread size is with in a thousandth or two of your fitting and will work fine. I've had these on my car with out problems for 7 or 8 years. Call Barnette performance @ 404-522-1320 and tell them what you are doing and check to see if they confirm my info. Its been along time since I put those lines together but I think those are the right numbers. They also sell 1/8 inch to #3 fittings, both ends male, but it depends on if you need the female inverted flair or not. Good luck, Mark Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted August 29, 2003 Share Posted August 29, 2003 Ok, so i'm guessing you can buy steel or aluminuim tubing and use this "double flare" tool to make brake lines anywhere on your car? say... from a master cylinder to a proportioning valve? -Ed Quote Link to comment Share on other sites More sharing options...
JMortensen Posted August 29, 2003 Share Posted August 29, 2003 Yep, you can make whatever you want. Put that prop valve where you can reach it, make brake line sculptures that pass thru the cabin, whatever. My advice would be to buy a tubing bender as well, as it is pretty easy to kink the tube if you are trying to do a really sharp bend. The key for me was chamfering the end of the tube. I kept trying and trying,then I READ THE DIRECTIONS on the tool, and after chamfering the end, I couldn't go wrong. I used a drill bit for that, BTW. Jon Quote Link to comment Share on other sites More sharing options...
Guest cbrunberg Posted August 29, 2003 Share Posted August 29, 2003 Try taking your Mastercylinder and calipers with you to the parts store and go through their fittings selection to find the right fitting sizes. Write them down and buy the appropriate brake lines and follw Johns instructions. It's not that bad. It's just hard to guess about the fitting sizes. Carl Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted August 29, 2003 Share Posted August 29, 2003 well that was alot of money.. to get the right size fitting then to a line connected to a fitting to connect to a fitting onto the stock line was 80 bucks!!!!!!!!! nobody sells fittings for those calipers and i had to rig it up to work cuz my stock lines/fittings wont come off... pure rusted shut! oh well least i get that done.. man o man. i could have put a nice down payment on a new STi and have low monthly payments... oh well.. ill just beat them in my old Z. Quote Link to comment Share on other sites More sharing options...
Jeff Posted August 29, 2003 Share Posted August 29, 2003 Remember when you had some extra money and people were telling you to hold on to it for the little things? These are the little things everyone was talking about, ain't life a bitch. Quote Link to comment Share on other sites More sharing options...
