Nismo280zEd Posted September 24, 2003 Share Posted September 24, 2003 has anybody actually used the "economy camber kit" from MSA they have a $99 camber adjuster... (mount on top of the strut) would 1.5 deg be enough to correct a 1-2" lowered car? thoughts and comments on these? Quote Link to comment Share on other sites More sharing options...
Owen Posted September 24, 2003 Share Posted September 24, 2003 I've been asking that question for a couple of months and it seems no one has. I was at MSA the otherday and asked to see them. They are thick urethane pieces with slotted holes, one person pushes on the strut assy. while another tightens the mounting hat down. Must be a biatch to get the X number of degrees desired... Owen Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 24, 2003 Share Posted September 24, 2003 Don't people just slot the holes on the strut tower? Jon Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted September 24, 2003 Author Share Posted September 24, 2003 that's what i was afraid of... sounded too good to be true. I don't like the idea of my strut being held by plastic. Quote Link to comment Share on other sites More sharing options...
auxilary Posted September 24, 2003 Share Posted September 24, 2003 well, your current strut is held by rubber, so it can't be much worse:) Quote Link to comment Share on other sites More sharing options...
Synlubes Posted September 24, 2003 Share Posted September 24, 2003 well, your current strut is held by rubber, so it can't be much worse:) 30 year old rubber at that! I made my own non ajustable camber plates out of some 1/8 plate steel. They gave me 1 degree more negitive camber (than what I could get with the ajustable camber bushings) and 1.5 inch (or so) drop with out changing the suspension geometry. They were pretty simple to make. Quote Link to comment Share on other sites More sharing options...
Owen Posted September 25, 2003 Share Posted September 25, 2003 Yeah, the MSA ones are meant for people not wanting to cut their metal up. I wouldn't get them even though the appeal of a still-soft ride after the mod was done is nice. Owen Quote Link to comment Share on other sites More sharing options...
pallnet Posted September 28, 2003 Share Posted September 28, 2003 i have them on the front of my car. i had first put them on all 4 corners but, the rear was too low so, i put the old upper mounts back on. with my car being as low as it is, i still need a little more adjustment. i have only one complaint but, this will be the same with other camber adjustments. it's hard to make adjustments on the alighnment rack unless you lift the car. adjust, lower the car. check the camber and caster again to see where your at. sometimes, you have to do this like a handfull of times to get it as close to being right as you can. the product is good and lowers the car like .5"-1" from the mount alone.. Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted September 28, 2003 Author Share Posted September 28, 2003 how low is your car? measuring from the ground to the frame rails? front and back Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 30, 2003 Share Posted September 30, 2003 Pallnet, I find that with my camber plates it is damn near impossible to adjust with the car on a rack. Very easy to adjust with the weight of the vehicle on the ground. I thought it was interesting that you have a different experience. FWIW, Jon Quote Link to comment Share on other sites More sharing options...
Guest autocroos76 Posted October 1, 2003 Share Posted October 1, 2003 I have a 76 with the MSA camber adjust and like them. The local Monroe shop did the adjustment and they said it was easy. I also have the lowered springs and the computer print out showed everything within spec. Quote Link to comment Share on other sites More sharing options...
Mikelly Posted October 2, 2003 Share Posted October 2, 2003 Gee, Maybe we should write a tech article with part numbers for those who want NON-ON CAR adjustable control arms... You know, still have TONS of adjustment, but no turnbuckle, just a heim joint... Would cost less than $50 in parts... Any interest?? Mike Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted October 7, 2003 Author Share Posted October 7, 2003 i'm not sure if your being sarcastic or serious mike. -Ed Quote Link to comment Share on other sites More sharing options...
