Is an 85 R200 the same as an 83 R200
danc
Chances are that the ring gear bolts are 12mm instead of 10mm in the earlier cars. It may be a 4 pinion unit, which would be a bonus, as the spider-gears would be nearly bullet-proof. As for bolting it in, there would be no difference except for the above-mentioned input flange.
Doug
Chances are that the ring gear bolts are 12mm instead of 10mm in the earlier cars. It may be a 4 pinion unit, which would be a bonus, as the spider-gears would be nearly bullet-proof...
According to Nissan, the four pinion open R200 was only used in the 1987 and 1988 Z31's non-turbo's. However, I've only seen them used in the 1988 300ZX.
