rags Posted August 14, 2005 Share Posted August 14, 2005 The Q45 R200 VLSD unit does fit in a long nose R200, I've done it. You will need to use the matched set of gears from the long nose because the 3.54's between the long and short diffs have different gear counts. Just swap the ring gear from the open diff to the VLSD and drop it in. You will still need to make custom axles because you still need to use the 6 bolt inner axles. Anyone have a lead on 88 300zx SS CV axles?? Joe Quote Link to comment Share on other sites More sharing options...
Corzette Posted August 14, 2005 Share Posted August 14, 2005 Rags, was the length of the modified axles the same as I would get from Ross by doing the R230 setup? If not, do you have the need length? Im gonna make the axles with 4 Q45 axles.Will Lash be a problem or just a drop in? Terry Quote Link to comment Share on other sites More sharing options...
quicker240 Posted August 14, 2005 Share Posted August 14, 2005 How come I'm always the last to know!? You are all gonna have to excuse me now while I go down and start tearing down some diffs in the garage.This info could have some serious money saving involved so I'll take a few pics as I go.I sure hope your right Rags! I could have a posi by Reynolds now. Quote Link to comment Share on other sites More sharing options...
Corzette Posted August 14, 2005 Share Posted August 14, 2005 Quicker240, let us know how it turns out! This would be the way to go if it works! Terry Quote Link to comment Share on other sites More sharing options...
rags Posted August 14, 2005 Share Posted August 14, 2005 Terry, I haven't gotten any of the adapters or axles yet so I don't know about the length. I've only done the swap in the rear so far. I have one set of Q45 CV axles, need to find another set and get some adapters from Ross. What I really want to do is find SS Z31 CV axles. Then I will only need Ross's adapters and I'm done! Does anyone know if the spline count is the same on a SS axle and a non SS turbo axle? Joe Quote Link to comment Share on other sites More sharing options...
Corzette Posted August 15, 2005 Share Posted August 15, 2005 Rags, I had a SS diff in the past and couldnt find any axles for them. They are elusive bast...irds. I ditch the SS and now have the Q45. I guess Ill put that in the R200 long nose and just upgrade the stubs to Ross's and get the adapters for the 6 bolt flanges too, with the moser axle upgrade. that will save alot of time on the front mount etc....do you have any pics of the Q45 R200 swap? Terry Quote Link to comment Share on other sites More sharing options...
quicker240 Posted August 16, 2005 Share Posted August 16, 2005 I'm gonna have to call BS on Rags here.Pulled the carriers from both diffs.The ring gear bolts on the q45 diff are easily twice the size of the r200 open diff ring gear bolts.I have pics to back me up,but I dont know how to upload them to the site.BTW,the ring gear count is 46:13 or 3.53:1 as far as the q45 diff is concerned.Anyone wants pics I can email them to you.Got all excited for nothing.Rats. Quote Link to comment Share on other sites More sharing options...
ULISES Posted August 16, 2005 Author Share Posted August 16, 2005 I couls upload them. Send them to TYPHOON_1978@HOTMAIL.COM Quote Link to comment Share on other sites More sharing options...
quicker240 Posted August 16, 2005 Share Posted August 16, 2005 diff pics uploaded into my user gallery.Someone could move them into this thread for future reference. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted August 16, 2005 Share Posted August 16, 2005 Why does that look like a R230 to me? Look at the difference in size of the open non lsd R200 ring gear, compared to the one on the viscious carrier... Quote Link to comment Share on other sites More sharing options...
Corzette Posted August 17, 2005 Share Posted August 17, 2005 Hmmm, that could be the problem....The R200 is what RAGS said he had done... Quote Link to comment Share on other sites More sharing options...
quicker240 Posted August 17, 2005 Share Posted August 17, 2005 This is for SURE a r200vlsd from a q45,I saw it removed myself.The rear diff cover has 2 bolts on top,not 3.And I have the Nissan parts breakdown for both the r230 and the r200v.Internally they are VERY similar but there is NO QUESTION here,these are both r200's.The picture is a little deceiving,but the housings are almost exactly the same size,except for pinion length,and the ring gears are the same size,except for the size of the ring gear bolts and holes.I'll be happy to photograph both ring gears against a tape measure if necessary for maximum peace of mind here,but the lsd is ABSOLUTELY a 200mm. Quote Link to comment Share on other sites More sharing options...
DaEvil Posted August 17, 2005 Share Posted August 17, 2005 I just did the swap in my 75 Z I put a VLSD (the guts) from a 96 300z I think. I used the vlsd out put shafts ,made my own adapters and cut and resplined my axles http://forums.hybridz.org/showthread.php?t=103221&highlight=resplined Quote Link to comment Share on other sites More sharing options...
rags Posted August 20, 2005 Share Posted August 20, 2005 Okay, looks like I'll have to take some pictures. There is no question that the Q45 uses the larger ring gear bolts that all later R200's use. It has been discussed many times that an early small bolt ring gear can be used on large bolt carrier. Some use bolt spacers and some do not. I chose to use them. Sorry for the late response but I was at the convention. Joe Quote Link to comment Share on other sites More sharing options...
Briguy280Z Posted August 23, 2005 Share Posted August 23, 2005 I am looking for a few things to finish up this project. Is the spline count the same with a 5 bolt flange vs a 6 bolt flange? Axle shafts--Where can i get these? Adapter Plates--5 bolt pattern 300zx na Bushings--to attach the ring gear so close but yet so far! Thanks Quote Link to comment Share on other sites More sharing options...
Guest Battle Pope Posted August 23, 2005 Share Posted August 23, 2005 Maybe this has been covered already, but why do I need 2 sets of Q45 axles? And what do i do with them once I have them? Quote Link to comment Share on other sites More sharing options...
rags Posted August 23, 2005 Share Posted August 23, 2005 Only the outer CV's are used. The inner ones have the input shaft attached to it so it can't be used. Joe Quote Link to comment Share on other sites More sharing options...
Guest Battle Pope Posted August 23, 2005 Share Posted August 23, 2005 So Why do I need 2 sets? How exactly does this pile of stuff go together? Quote Link to comment Share on other sites More sharing options...
Briguy280Z Posted August 24, 2005 Share Posted August 24, 2005 Each side of the cv needs to attach some how and Tim covered it pretty good in his pictoral thread. Pretty sweet tutorial- http://forums.hybridz.org/showthread.php?t=90068 Quote Link to comment Share on other sites More sharing options...
