twistex Posted January 19, 2006 Share Posted January 19, 2006 well finally put up a video of my car reving up a little bit. the motor has triple sk racing 45mm carbs, big cam, big valves, header, knifedge crank, lightend flywheel, long rods ka pistons 90mm , this engine can see 8k np! hope you enjoy. link here ! http://video.google.com/videoplay?docid=-2382048404444900926&q=240z The original video was like 150 meg avi i wish i could put the whole video but i couldnt get streetfire to work right ! Quote Link to comment Share on other sites More sharing options...
Silent Posted January 19, 2006 Share Posted January 19, 2006 mmmm beefy Quote Link to comment Share on other sites More sharing options...
ZetoZeto99 Posted January 19, 2006 Share Posted January 19, 2006 DrOoOoOooool Quote Link to comment Share on other sites More sharing options...
twistex Posted January 19, 2006 Author Share Posted January 19, 2006 yeh man .. sounds nice .. i had a full walk around video of car as it was idling but to hard to get it to upload to these free file places! anyways yeh i cant wait to take it out on the road! i need coilovers first! Quote Link to comment Share on other sites More sharing options...
Tony D Posted January 19, 2006 Share Posted January 19, 2006 Flywheel Assy sounds heavy. What is it lightened to, and how much is your pressure plate/flywheel total weight? Mikuini Manifold, right? Niiice! Quote Link to comment Share on other sites More sharing options...
twistex Posted January 19, 2006 Author Share Posted January 19, 2006 well see i have a fidanza alum flywheel 9 lbs i think but right now i have like a 11 lb or 13 lb lightend flywheel. car isnt fully tuned yet .. i have a centerforce clutch on there right now with a 280zx trany from a 83. well see i may end up just putting a rb25det into this z who knows. plus i have 2 other cams that are bigger that the one in it right now. just a mild on is it right now for when i use to have fuel injection on it. that manifold is a mikuni style yes, that i port matched to the 1.5 intake ports on head.. i uploaded a bigger longer video on video.gooles site .. they have to aprove it before i can get the link to post. i will keep you all informed! Quote Link to comment Share on other sites More sharing options...
v80z Posted January 19, 2006 Share Posted January 19, 2006 Watch out for that CF clutch. I ahd a similar setup in my race car for a while. It is a street clutch. I went into turn 1 one time and forgot to blip the throttle. With my locked rear end and the 10" slicks the spring steel that the pressure plate was mounted on collapsed and shredded the inside of the bell housing. I sent it back to CF for rework. They replaced the 2 pieces of spring steel with 3 pieces on each of the 3 mounting posts. Needles to say the next Time I forgot to blip on a downshift it happened again. This is of course at about 7K rpm. After that I bout a 10,000 rpm brand 5.5" double disc mounted on an aluminum flexplate. Much better. Stood up to every error I threw at it. It was a bear to get adjusted right however it lasted. Quote Link to comment Share on other sites More sharing options...
Mack Posted January 19, 2006 Share Posted January 19, 2006 waitaminute.... are you implying that you are using the LD28 BLOCK as well as the crank? just VERY curious,. as someone on this board swears they arent god for much more than a 2mm obvverbore..... NIce vid at any rate! should be a real screamer! Quote Link to comment Share on other sites More sharing options...
briann510 Posted January 19, 2006 Share Posted January 19, 2006 Nice sound! video of our 3.2 stroker in our link. Quote Link to comment Share on other sites More sharing options...
twistex Posted January 19, 2006 Author Share Posted January 19, 2006 the ld28 block has thicker walls .. plus i sleeved mine incase i ever screw up a sleeve i can just put a new one in! diesel blocks are built bullet proof i hear. see most people run turbo block .. but can only run the 5.75 240z rods .. the ld28 block is .25 taller then the turbo block. so i can run a 6 inch rod Quote Link to comment Share on other sites More sharing options...
1 fast z Posted January 19, 2006 Share Posted January 19, 2006 LD28 block, is 83mm bore, and I sonic tested TWO blocks, and without sleeves, you can ONLY do a 2 mil over, that will only get you two a ~2.95 liter. So your saying you did a 7 mill over bore, on cylinders that are only .160" thick STOCK? Yea, this only worked cause you sleeved it, CANT be done without sleeving it mack, TOLD YA! Quote Link to comment Share on other sites More sharing options...
Mack Posted January 19, 2006 Share Posted January 19, 2006 I figured there was some sort of heavy *** modification involved, or maybe a 2MM overbore and some of our "special rods or something, with an offset grind, HA ha! How much did it run you to get it sleeved? I've always been curious about this. I've got a shortblock LD28 sitting around as well as an L20B front cover. just itching to be used. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted January 19, 2006 Share Posted January 19, 2006 Sexxxxy...I had turn down the volume at the office! Quote Link to comment Share on other sites More sharing options...
twistex Posted January 19, 2006 Author Share Posted January 19, 2006 yeh I see .. I built this motor 8 years ago got alot of the machining I got done through friends at machine shops.. i built the whole motor for 2500! friend ground the cams, and my head is based off the rebello head with 181 intake valve and 150 exhaust. this motor has been basically brought back from sitting for over 8 years. I have 3140 miles on the motor before I stoped driving it with fuel injection. so anyways I basically used the ld block for the taller deck to fit the longer rods in. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted January 19, 2006 Share Posted January 19, 2006 That's the answer to the stroker L series IMO. Taller block, longer rods, better rod ratio. Very nice! Quote Link to comment Share on other sites More sharing options...
olie05 Posted January 19, 2006 Share Posted January 19, 2006 twistex, I forgot to ask you, how is the hood clearance with a quarter inch higher block? Does the valve cover come really close to the hood? -Oliver Quote Link to comment Share on other sites More sharing options...
RedBeauty84ZX Posted January 19, 2006 Share Posted January 19, 2006 I am sure this is a remedial question, but whats the difference between the LD28 and L28 and what was the LD28 used in? Quote Link to comment Share on other sites More sharing options...
olie05 Posted January 19, 2006 Share Posted January 19, 2006 RedBeauty84ZX said: I am sure this is a remedial question, but whats the difference between the LD28 and L28 and what was the LD28 used in? I will answer this only because this has not been discussed as much as the topic of the diesel crank, but you should really do a search. The diesel block is found in datsun diesel Maxima 1982 and 1983 (maybe 1981?). It has a quarter inch higher deck height than the normal gasoline L-series blocks. this allows for a longer rod in conjunction with the wider stroke. The other guy on this board is DAW, who converted a diesel short block for use with gasoline. -Oliver Quote Link to comment Share on other sites More sharing options...
Mack Posted January 19, 2006 Share Posted January 19, 2006 actually, its more like 3/4" higher deck height. I *think* the LD28 has a deck height of 227.5mm, where as our L28's have a 207.9 deck height. The LD28 has teh EXACT same deck height as an L20B 4 cylinder. 3/4" might make adifference, but I doubt it. Quote Link to comment Share on other sites More sharing options...
twistex Posted January 19, 2006 Author Share Posted January 19, 2006 basically it is the same as a l20b that how the timing cover will work. anyways i dont have clearance issues with the hood but i would say i wish i could push the motor back about 6 inches more towards the firewall! but didnt wana bother with motor mounts and resizing drivline! Quote Link to comment Share on other sites More sharing options...
