slownrusty Posted August 28, 2006 Share Posted August 28, 2006 Sorry to do this to you guys, but this is my first time and I wanted to hear some feedback on my wipe pattern (talk about a "toilet theme"..LOL!) - this is for my new Web Cams Turbo Grind... What are your thoughts? Many thanks! Yasin Quote Link to comment Share on other sites More sharing options...
rags Posted August 28, 2006 Share Posted August 28, 2006 I'm bar far an expert, but that looks d*mn good to me! Joe Quote Link to comment Share on other sites More sharing options...
naviathan Posted August 28, 2006 Share Posted August 28, 2006 Yeah, Yasin, that's a nice clean wipe pattern. Dead center and wipes the whole pad. Looks great. Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted August 28, 2006 Share Posted August 28, 2006 I happen to like these WIPE PATTERN threads I've learned much from them! Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted August 28, 2006 Share Posted August 28, 2006 Its hard for me to tell what the valve side is doing there by looking at those pics. If the valve side is indeed equal to the pivot side, your good to go, but from what I can see, it looks like its wiping more to the valve side, which means you could use a thinner pad... I've always found it hard to get a good wipe using that kind of material on the rocker. I use a black permenent marker, or I've even sprayed them with flat black spray paint (it comes of easy enough when done), after I wipe off the rocker each time with carb cleaner, and that gives a clean wipe with no smearing.... Give that a go and you'll get a nice clean pattern to show. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted August 28, 2006 Share Posted August 28, 2006 Its hard for me to tell what the valve side is doing there by looking at those pics. If the valve side is indeed equal to the pivot side' date=' your good to go, but from what I can see, it looks like its wiping more to the valve side, which means you could use a thinner pad... I've always found it hard to get a good wipe using that kind of material on the rocker. I use a black permenent marker, or I've even sprayed them with flat black spray paint (it comes of easy enough when done), after I wipe off the rocker each time with carb cleaner, and that gives a clean wipe with no smearing.... Give that a go and you'll get a nice clean pattern to show.[/quote'] Agreed. It looks like it's smearing at the end, and really hard to see where it stops. A Sharpie won't do that and it will be easier to see where the wipe stops. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted August 28, 2006 Administrators Share Posted August 28, 2006 Yes. It is smearing, (a downside of the Prussian blue, just make it a real thin coat or use a sharpie as Mortensen suggested), but there is so much Prussian blue on both side of the rocker that the smearing isn’t “covering up” any possible “over wipe”, if you will. Your wipe pattern is just fine, run it. You could cheat it back little bit, but you wouldn’t “feel” any gains that would come from it. In looking at those pics, it appears that you could safely go with a .020” thinner lash pad if you were inclined to cheat the rocker ratio. Quote Link to comment Share on other sites More sharing options...
rztmartini Posted August 29, 2006 Share Posted August 29, 2006 would you reccommend using thinner lash pads or adjusting the rocker arm pivot (dont know what thats called) to cheat the wipe? Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted August 29, 2006 Share Posted August 29, 2006 would you reccommend using thinner lash pads or adjusting the rocker arm pivot (dont know what thats called) to cheat the wipe? The correct way is to use a thinner pad. If you try to do it by raising the pivot adjuster, you end up with no clearnce between cam lobe and rocker pad.... Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted August 29, 2006 Administrators Share Posted August 29, 2006 would you reccommend using thinner lash pads or adjusting the rocker arm pivot (dont know what thats called) to cheat the wipe? By using a thinner lash pad “AND†maintaining the recommended lash clearance, that will automatically raise the rocker pivot to achieve that same valve lash adjustment. I.e., to retain the same lash clearance at the cam, a thinner lash pad means a raised pivot, and vice versa. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted August 31, 2006 Author Share Posted August 31, 2006 Paul - many many thanks for your help and generosity so far! I really appreciate it. Best Regards - Yasin Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted September 3, 2006 Administrators Share Posted September 3, 2006 Paul - many many thanks for your help and generosity so far! I really appreciate it. Best Regards - Yasin Yasin, Glad we could help. If you need anything else, just let us know. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted September 4, 2006 Author Share Posted September 4, 2006 Paul - Did you receive my message (left on Friday)? Regards - Yasin Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted September 6, 2006 Administrators Share Posted September 6, 2006 Paul - Did you receive my message (left on Friday)? Regards - Yasin Yasin, Sure did. It was nice talking with you again. Glad we could be of assistance. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted September 6, 2006 Author Share Posted September 6, 2006 Paul - Thanks for the chat again! You are a great guy and patient too...I felt like a donkey after speaking with you...no wonder might wipe pattern looked so inconsistant! I'll post some more pics soon - hopefully representing something worthy of being posted! Chat soon - Yasin Quote Link to comment Share on other sites More sharing options...
