Where can I find a Grill like this?
Southpaw
Nah, you can easily cut it with tin snips or carbon wheel.
Expanded Metal, like you would find at Home Depot or other hardware stores is easy to cut with snips. If you want to use the good stuff; stainless steel double crimped wire mesh like used on Jags and other high-end cars, then you will need to use an abrasive wheel or something similar. Here is a link to one of many companies who sell crimped wire mesh: http://www.wiremesh-wanda.com/wire-mesh/wire-mesh.htm. Check ebay too.
