jessejames Posted June 26, 2007 Share Posted June 26, 2007 Hi there, what are your experiences with the vilidini and whitehead sr20 cradles? I spoke with Greg at whitehead he mentioned that with his cradle you have to adjust the hoodlatch other wise the valve cover will get scratched up by the hood latch. Is that true of the vildini cradle too? I'm planning on buying within the week. Any info would be helpful. Quote Link to comment Share on other sites More sharing options...
Cal Poly Zmanaustin Posted June 27, 2007 Share Posted June 27, 2007 Just call them...they are straight upfront about everything. Quote Link to comment Share on other sites More sharing options...
SR240Z Posted June 27, 2007 Share Posted June 27, 2007 if you want the engine to sit clearly behind the crossmember you will have to adjust to have the hood latch still be functional. Quote Link to comment Share on other sites More sharing options...
Lewis Maudlin Posted June 27, 2007 Share Posted June 27, 2007 if you want the engine to sit clearly behind the crossmember you will have to adjust to have the hood latch still be functional. By adjust, do you mean dent slightly? Quote Link to comment Share on other sites More sharing options...
SR240Z Posted June 28, 2007 Share Posted June 28, 2007 well what we did on the ones that kept the hood latch were to cut off the bottom half of the latch and then reinforce it ourselves so its not just a dented latch. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted June 28, 2007 Share Posted June 28, 2007 Anything part, piece, fabrication or work that has Whitehead Performance is going to be simply excellent. Regards - Yasin Quote Link to comment Share on other sites More sharing options...
dosquattro Posted June 30, 2007 Share Posted June 30, 2007 What are the prices on these cradles cause I can't find it on either of their websites? Quote Link to comment Share on other sites More sharing options...
Wedge Posted July 31, 2007 Share Posted July 31, 2007 Yeah im kinda curious about the price too ? Quote Link to comment Share on other sites More sharing options...
ShaggyZ Posted August 8, 2007 Share Posted August 8, 2007 What are the prices on these cradles cause I can't find it on either of their websites? bump. No word? Quote Link to comment Share on other sites More sharing options...
jessejames Posted August 30, 2007 Author Share Posted August 30, 2007 i called and he said around 350ish but he would get back to me. I'm going to call again this week. Quote Link to comment Share on other sites More sharing options...
savageskaterkid Posted September 5, 2007 Share Posted September 5, 2007 was 350 from whitehead or vildini? Quote Link to comment Share on other sites More sharing options...
greenmonster80 Posted September 30, 2007 Share Posted September 30, 2007 I got my cradle from Alex at Vildini just a couple days after ordering it. Price was $350 shipped to my door in 2 days. I have yet to drop my motor on it but that should be remedied Monday. Quote Link to comment Share on other sites More sharing options...
ktown z Posted October 15, 2007 Share Posted October 15, 2007 Is the sr20 cradle just for the engine or does it come with a tranny mount also? I am looking for engine and tranny mounts that are already made. The shop that i am having do all my work says it will be significantly cheaper if I can locate these items. Quote Link to comment Share on other sites More sharing options...
SR240Z Posted October 15, 2007 Share Posted October 15, 2007 We only supply the engine mount. The trans mount is then made depending on how far forward or back you mount your motor. Quote Link to comment Share on other sites More sharing options...
jessejames Posted October 16, 2007 Author Share Posted October 16, 2007 I picked up a motor cradle and a transmission mount from whitehead. It cost me $450 Cad. The motor cradle looks similar to the Vildini ones I've seen in pics. I've test fitted it in my car and its a tad small. This was a prototype that Greg at Whitehead made for me. If i have time i'll take it back and have him adjust it or I'll weld something on both sides to make it fit. I'll post pics this weekend. Greg's cradle uses the L24 motormounts NOT the sr20's. On a seperate note, i'm having issues test fitting the motor. The sr20 oil pan catches on the stock crossmember. Maybe the lean angle is wrong. I'll play with it more this weekend. Where has everyone else picked the motor up from. I took the hooks off the L24 and bolted one up to where the transmission meets the block, and the other one to where i could on the front. Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted October 20, 2007 Share Posted October 20, 2007 We only supply the engine mount. The trans mount is then made depending on how far forward or back you mount your motor. It'd be nice to see pics/info/pricing of some of the cool stuff you guys make on your website. Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted October 20, 2007 Share Posted October 20, 2007 Fyi, Both cradles use Lseries mounts. Quote Link to comment Share on other sites More sharing options...
Mr.INSANE Posted October 20, 2007 Share Posted October 20, 2007 The SR20 Cradle will also work with the CA18DET both engines use the same mounting points Quote Link to comment Share on other sites More sharing options...
