Careless Posted August 18, 2008 Share Posted August 18, 2008 all the best, i hope it's a good day for you when you get there. Quote Link to comment Share on other sites More sharing options...
stony Posted August 18, 2008 Author Share Posted August 18, 2008 thanks Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted August 18, 2008 Share Posted August 18, 2008 BTW, it sounds like your fuel pump may not be keeping up w/ demand. I had similar symptoms as you are having, added twin pumps and a voltage booster and viola... solved the problem. Your fuel pressure should not drop off like that, but stay at a 1:1 increase as boost increases. Be careful next weekend ... don't want you to hurt your motor. Mike Quote Link to comment Share on other sites More sharing options...
stony Posted August 18, 2008 Author Share Posted August 18, 2008 R2ing the current bosche with a weldon!!! shouldnt have any problems:grin: http://www.weldonracing.com/product.phtml?p=11&cat_key=6&prod=DB2015-A_(-12_inlet_and_-10_outlet) Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted August 18, 2008 Share Posted August 18, 2008 Excellent pump, but notoriously loud... I am sure you won't mind!! Probably don't have to tell you this, but make sure you have good wiring running to the Weldon pump (atleast 10 gauge) via a relay, as it will require plenty of juice on the big end Quote Link to comment Share on other sites More sharing options...
JustinOlson Posted August 18, 2008 Share Posted August 18, 2008 Were you using the bosch 044 pump previously? Justin Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted August 18, 2008 Share Posted August 18, 2008 Sweet.....DAWG!!!!! Quote Link to comment Share on other sites More sharing options...
stony Posted August 18, 2008 Author Share Posted August 18, 2008 JustinOlson said: Were you using the bosch 044 pump previously? Justin If that is the one available from germany special order then yes. If not then no i dont know what the model number is other then it was rated at 800HP Quote Link to comment Share on other sites More sharing options...
stony Posted August 18, 2008 Author Share Posted August 18, 2008 Z-Gad said: Excellent pump, but notoriously loud... I am sure you won't mind!! Probably don't have to tell you this, but make sure you have good wiring running to the Weldon pump (atleast 10 gauge) via a relay, as it will require plenty of juice on the big end My downpipe is 24 inches long and im running an open wastegate!!! So yea the pump being loud isnt going to bother me at this point ;> Quote Link to comment Share on other sites More sharing options...
stony Posted August 24, 2008 Author Share Posted August 24, 2008 Little update.... fixed my miss !!!! The igniter doesn't like getting hot. It may be going bad but moving it to to the firewall away from the engine seems to have fixed it for now. On the dyno tonight we made 507rwhp at 19PSI. we were baby stepping it up in rpm and we got to 7000 rpm> SOOOO 507 rwhp @ 19 PSI and 7000rpm. tomorrow we plan on finishing the tun to 26 PSI all the way out to 9000 rpm. The engine is wicked smooth now and is running like a top. I cant wait to get it out to the track again !!!! Quote Link to comment Share on other sites More sharing options...
stony Posted August 25, 2008 Author Share Posted August 25, 2008 today last dyno run before going to the track. Factoring in 30% drive train loss for the glide, Dana 60 and 31 inch tires thats in the upper 780crank HP the 75 shot on the brake literal smokes the tires on launch and gets 22PSI!!!!! Quote Link to comment Share on other sites More sharing options...
Careless Posted August 25, 2008 Share Posted August 25, 2008 <= waiting for video while eating peanut-butter and jealous sandwich. Quote Link to comment Share on other sites More sharing options...
Sparky Posted August 25, 2008 Share Posted August 25, 2008 Careless said: <= waiting for video while eating peanut-butter and jealous sandwich. Yeah, what he said! Quote Link to comment Share on other sites More sharing options...
stony Posted August 26, 2008 Author Share Posted August 26, 2008 Well here are some pics of the engine in it’s final state along with all the other stuff installed for the final dyno tune. Not sure if the marren pulse damper is doing anything, we bought it before we fixed the fuel problem hoping it would help. Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted August 26, 2008 Share Posted August 26, 2008 Lookin' good Clint... just awaitin' those track numbers/ vids Quote Link to comment Share on other sites More sharing options...
stony Posted August 27, 2008 Author Share Posted August 27, 2008 Will have some tomorro as long as the weather holds. Quote Link to comment Share on other sites More sharing options...
stony Posted August 28, 2008 Author Share Posted August 28, 2008 Well had a very good night tonight. Started out slow wanted to get a feel for it but by the 5th run i was ready to put the hammer to the floor. Best run of the night was a 9.33 @ 146 mph video is loading of one of the almost full boost launches. Will psot when its done. Quote Link to comment Share on other sites More sharing options...
stony Posted August 28, 2008 Author Share Posted August 28, 2008 First of the nine second runs. this was the first one that the turbo really started to spool. Quote Link to comment Share on other sites More sharing options...
fentin_fury Posted August 28, 2008 Share Posted August 28, 2008 that is very nice! sounds like it is running very good in the videos. Q Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted August 28, 2008 Share Posted August 28, 2008 Congrats. You are off to a good start. Still sounds like it is taking a long time to spool up. What RPM do you start squeezing the nitrous? Please tell me you plan on losing that hood scoop Quote Link to comment Share on other sites More sharing options...
