Administrators RTz Posted December 6, 2007 Administrators Share Posted December 6, 2007 Finally released, our exclusive coil mounts and custom Magnecor wires... Please read this post in its entirety before ordering. If there is anything unclear, please ask. . . . . . . . . . . Block mounting points... Made from 3/16" 6061 Aluminum. Mount Price: $99 shipped anywhere in the US. If outside the US, PM for pricing. Available Magnecor wires... KV85 Competition 8.5mm, RED, Part #65285 ELECTROSPORTS SERIES 8mm, BLUE, Part #60285 ELECTROSPORTS SERIES 7mm, BLACK, Part #67285 Order direct @ (248) 471-9505 http://www.magnecor.com 1. Price does not include coils. 2. Mount will require rerouting heater hose. 3. The mounts come with a light DA sanded finish as shown in photo 2. They are ready for paint, or polishes with minimal effort. 4. Included hardware... stand-offs and S.S. bolts for mounting to the block. All extra hardware not included. 5. Coil Part Number: 12558693, or 2000 Chev. Suburban 5.3L 6. Connector Part Number: 12582189 (connectors only come in batches of 4, as a sub-harness) 7. Coils known to work with Wolf3D, Haltech, Motec, J&S, and Megasquirt. It's up to you to know if and how they will work with your specific EMS. Coil Schematic... Pin A... can be grounded to the block, but my recommendation is the head. Pin B... needs to be grounded at the same location as the ECU. Pin C... to ignition channel. Pin D... provide a good 12 volt power source (with key 'on'). Begin with 3.5ms dwell. Test and tune for best ignition performance. For ordering send a PM or post here. Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted December 7, 2007 Share Posted December 7, 2007 Any info on if you are able to use this setup with megasquirt? I'd love to go this route, but don't know what all is needed to do so. Maybe I can talk to Bo (ktm) about it since he's local to me. Quote Link to comment Share on other sites More sharing options...
ktm Posted December 7, 2007 Share Posted December 7, 2007 "5. Coil Part Number: 12558693, or 2000 Chev. Suburban 5.3L" This is a key distinction. I am running LS-1 coils out of a 2001 Firebird. The coil shape is slightly different. Specifically, look at the mounting tab on the coil. The truck coils tab is 90 degrees to the coil projector; my coil projector is inline with the mounting tab: I would imagine that you would not be able to use Ron's mount and my coil type. The coil projector may hit the plate. Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted December 7, 2007 Author Administrators Share Posted December 7, 2007 Any info on if you are able to use this setup with megasquirt? Yes... http://forums.hybridz.org/showthread.php?t=120533 http://forums.hybridz.org/showthread.php?t=127466 Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted December 7, 2007 Share Posted December 7, 2007 Wow that looks great! Evan Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted December 7, 2007 Share Posted December 7, 2007 Awesome! I may have to pick up one of those mounts when I get around to doing a COS setup. I think I'll try to custom shorten some wires though, $100 is a little rich for my blood. Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted December 7, 2007 Author Administrators Share Posted December 7, 2007 Trumpet, I believe you told me you intended to use MS. May I suggest you do a little research on wire brand first? I believe you'll find a large number of people have run into MS resets running some of the other popular wires. Magnecor has superior suppression qualities and have proven to be consistently compatible with MS's sensitivity to EMF/EMI. Do some searching on this forum and you'll find Magnecor has cured resets on more than one occasion. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted December 7, 2007 Share Posted December 7, 2007 Uh oh. Well thanks for the heads up, I'll look into it... and try to up my budget Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted December 7, 2007 Share Posted December 7, 2007 is there an msd replacement part for these coils that mount the same as OEM so they can work with your mount? I've been searching, maybe the picture shown is incorrect, but they look different. I've found these though... http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD%2D82468&N=700+4294925143+4294908216+4294924666+4294839969+4294907174+4294890813+115&autoview=sku Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted December 7, 2007 Author Administrators Share Posted December 7, 2007 I'm not aware of a direct aftermarket replacement. Your link 'suggest' they are, but the picture shows a different mount orientation (and there are various connector styles). Its common for Summit to use a generic picture, though. However, I'm not convinced you need an aftermarket coil. I know of a chap running 1500hp endurance V8's with OE coils. Thats 187hp per/cyl. So, if you keep your L under 1100 hp, you should be good to go I frequently pick them up at the JY and they can also be purchased from a dealer. Gilbert Chevrolet has the best prices so far. Quote Link to comment Share on other sites More sharing options...
ktm Posted December 7, 2007 Share Posted December 7, 2007 Justin, the LS-1 coils throw a hot spark. I know the coils you are talking about as I saw them at Summit as well. Ron, I hope you did not mind my little interjection regarding the coil type. Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted December 7, 2007 Author Administrators Share Posted December 7, 2007 Ron, I hope you did not mind my little interjection regarding the coil type. No worries Quote Link to comment Share on other sites More sharing options...
Careless Posted December 12, 2007 Share Posted December 12, 2007 Guys, for about the price of a good ignition box for a 6 cylinder, you can have one of Ron's custom mounts + LS1 coils, and suitable wires to wrap it all up, and have the ability to swap coils at ANY shop, and have the benefit of better spark, and OEM quality that powers some very high horsepower factory, and modified engines. Not to mention this setup will very likely (if not indefinitely) out perform whatever box it is that you got your eye on within this price range once all is said and done. you can't find a better custom made (or perhaps even off the shelf) product at a price close to what Ron is offering here. This is the same guy that brought you those nice mount designs too!!! and look how nice it is =D Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted December 12, 2007 Share Posted December 12, 2007 I sent a MO out the other day for his mount and bought some of the magnecor r100 (10mm) custom wires. Found some used LS1 coil packs w/ low miles for $55 shipped on ls1tech.com, 2 sets of coil pack harnesses $50 shipped on ebay... Now I can sell my MSD 6BTM box, MSD plug wires and MSD blaster coil. This setup is gonna look so much cleaner and perform so much better! Thanks Ron! Quote Link to comment Share on other sites More sharing options...
Careless Posted December 12, 2007 Share Posted December 12, 2007 I sent a MO out the other day for his mount and bought some of the magnecor r100 (10mm) custom wires. Found some used LS1 coil packs w/ low miles for $55 shipped on ls1tech.com, 2 sets of coil pack harnesses $50 shipped on ebay... Now I can sell my MSD 6BTM box, MSD plug wires and MSD blaster coil. This setup is gonna look so much cleaner and perform so much better! Thanks Ron! Do the LS1 coils work, or is it the suburban coils only? Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted December 12, 2007 Share Posted December 12, 2007 Do the LS1 coils work, or is it the suburban coils only? supposedley only the GM trucks have the coil packs ron made this mount for. there are two different type of GM LS1 coil packs from what I've been told. 1 for the trucks and 1 for the cars, ktm (as pictured above) had coil packs from a car that don't work with this mount. BUT what I've found is that the 1 Ron uses is common on the cars too. when searching for them, just make sure they look like the ones Ron shows. Quote Link to comment Share on other sites More sharing options...
deja Posted December 12, 2007 Share Posted December 12, 2007 I'm not running a L6 but have to say that really looks cool. Quote Link to comment Share on other sites More sharing options...
Chemicalblue Posted December 12, 2007 Share Posted December 12, 2007 I made a look-a-like mounting bracket (from Ron's design) in my garage with all the parts from my local hardware store,8.5 plug wires, etc. and it ran well over the price he is offering. Not to mention Ron's bracket is a much better design and much more cosmetically pleasing. Unbelievable Price! Tnx Ron I cant wait to tell the Z club. Quote Link to comment Share on other sites More sharing options...
DrEaM Posted December 13, 2007 Share Posted December 13, 2007 so i'm very interested BUT where will i be able to reroute my heater hose to? Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted December 13, 2007 Author Administrators Share Posted December 13, 2007 so i'm very interested BUT where will i be able to reroute my heater hose to? One method is to put a Tee fitting in the lower rad. hose, near the frame rail. Run the heater hose along the rail and up the firewall to the existing heater outlet. The yellow ZX in my first post is done that way. Another method I saw was a tight brass 90 elbow in place of the existing straight nipple. It pointed down and 'just' cleared coil #1. There are other options as well... being creative is what its all about, yes? Quote Link to comment Share on other sites More sharing options...
