ridin_Z_alb Posted March 11, 2008 Share Posted March 11, 2008 gonna kinda sound newbie which rb series engine has the most torque output to horsepower? i wanna know before i sell/buy anything i heard of rb26dett making over 600hp on stock internals but does it have 600 ft. lbs. of torque? Quote Link to comment Share on other sites More sharing options...
mattyice Posted March 11, 2008 Share Posted March 11, 2008 from what i have seen it makes slightly less torque, but that doesnt mean you should pick an engine purely just because it has torque Torque can suck when you get up to high amounts like you are talking about, on the street they do nothing but turn into burnout machines...thats how i feel i would say your best bet for torque vs HP in an RB is an RB30 block with an RB25 head Quote Link to comment Share on other sites More sharing options...
ridin_Z_alb Posted March 11, 2008 Author Share Posted March 11, 2008 mostly i'm looking for a good torque long torque curve im looking to drag race and throwing around ideas about engines mostly all the high horsepower rb26's i've seen are 700 hp with 550 ft. lbs. which seems kinda weak Quote Link to comment Share on other sites More sharing options...
mattyice Posted March 11, 2008 Share Posted March 11, 2008 550 ft. lbs is not even close to weak remember this is going in a car that weighs anywhere from 2400-2700 lbs... you will never see initial torque in an RB like you would in V8 engines, RB's need big turbos to make power like that and its going to take time for them to spool, drag racing will be different but look at RIPS car that has an RB30 block and an RB26 head i believe...its running 9 flat Quote Link to comment Share on other sites More sharing options...
Careless Posted March 11, 2008 Share Posted March 11, 2008 if you're shooting for over 550 ft lbs of torque and 700+ hp, don't even consider the RB25 head on an RB30. go straight to the RB26 head, or get a 2JZ. Anything below 500 hp, I think the RB25/30 head is perfect combo for RBs. Quote Link to comment Share on other sites More sharing options...
ridin_Z_alb Posted March 12, 2008 Author Share Posted March 12, 2008 don't the rb26 heads have horrible low to midrange torque because they don't have the vvt that the rb25 heads do? oh yeah thoughs numbers were from a import tuner i saw awhile back, said it had 700hp or something and had 550 ft lbs Quote Link to comment Share on other sites More sharing options...
mattyice Posted March 12, 2008 Share Posted March 12, 2008 they have VVT on the exhaust side and HKS makes a VVT kit for the intake cam that makes the power and torque INCREDIBLE Quote Link to comment Share on other sites More sharing options...
J Taylor Posted March 12, 2008 Share Posted March 12, 2008 If you want a setup with lots of torque, RB is not the way to go. Quote Link to comment Share on other sites More sharing options...
ZDrifter Posted March 12, 2008 Share Posted March 12, 2008 You want torque? Get a cummins. Havent seen that swap yet. Quote Link to comment Share on other sites More sharing options...
Careless Posted March 12, 2008 Share Posted March 12, 2008 they have VVT on the exhaust side and HKS makes a VVT kit for the intake cam that makes the power and torque INCREDIBLE yeah i've been looking into that kit. might snatch it up if it's a good buy. I haven't heard of anyone stateside that runs it though (or anyone speaking english, for that matter) and as far as i know, its VCT for nissan, no? I just looked at the HKS V-CAM setup A & B, and it has a low valve lift height, and it requires special pistons for the wide adjustment version (. It also requires a whole other processing device too, which would probably be fidgety with an EMS as a primary. The valve lift puts me off and it's 4000 Quote Link to comment Share on other sites More sharing options...
BirdmanZ Posted March 12, 2008 Share Posted March 12, 2008 The Rb motors have VCT on the Intake cam not the Exhaust. Quote Link to comment Share on other sites More sharing options...
mattyice Posted March 12, 2008 Share Posted March 12, 2008 are you sure? i always heard they were on the exhaust side and there was a mod to add it to the intake side (HKS system) HKS Nissan Skyline BNR34 (650hp) its crazy how much it changes the performance of the car Quote Link to comment Share on other sites More sharing options...
BirdmanZ Posted March 12, 2008 Share Posted March 12, 2008 http://forums.hybridz.org/showthread.php?t=100975 Read through this. Quote Link to comment Share on other sites More sharing options...
stony Posted March 12, 2008 Share Posted March 12, 2008 I made 433 FTLBS torque with 598 RWHp after 6 runs on the dyno, thru a powerglide with an rb26 Quote Link to comment Share on other sites More sharing options...
J Taylor Posted March 13, 2008 Share Posted March 13, 2008 My best has been 424 ft lbs with 594 hp through a th350....on 93 octane and a bone stock rb25. My l28 turbo did 420 ft lbs with only 388 hp through the T5. Quote Link to comment Share on other sites More sharing options...
Cal Poly Zmanaustin Posted March 13, 2008 Share Posted March 13, 2008 I made 433 FTLBS torque with 598 RWHp after 6 runs on the dyno, thru a powerglide with an rb26 Clint, No one likes a showoff....except me maybe. Wow, those are awesome numbers. When are you hitting peak boost? Quote Link to comment Share on other sites More sharing options...
stony Posted March 13, 2008 Share Posted March 13, 2008 Around 5500 rpm haven't really looked at that yet. Still trying to get a smooth torque line. once we get it smooth then its time to play with timing to try and get power sooner. Quote Link to comment Share on other sites More sharing options...
ridin_Z_alb Posted March 13, 2008 Author Share Posted March 13, 2008 If you want a setup with lots of torque, RB is not the way to go. mostly i was looking for a good balenced setup good torque to get off the line quick, and keep me ahead the rest of the way and to make the v8 guys have to explain to all their buddies why they lost to a import Quote Link to comment Share on other sites More sharing options...
240swapped Posted March 13, 2008 Share Posted March 13, 2008 i still don't understand why anyone would want more than 550 ft. lbs. in a z anyways. is there anything you can do to make it hook up with that much? i'd rather full throttle it down the track with 400 than have to half throttle it all the way down with 550+. i think it'd be too much work to get a good time out of the car, assuming you're trying to make a dyno queen/ET bragger. Quote Link to comment Share on other sites More sharing options...
ridin_Z_alb Posted March 13, 2008 Author Share Posted March 13, 2008 nah just a fast ass car that'll beat corvettes and such and v8 Zs haha Quote Link to comment Share on other sites More sharing options...
