wecvusmc Posted April 8, 2008 Share Posted April 8, 2008 Would anyone using Haltech be willing to send me a base map to get me started with getting my Z-Car running? Here are my specs: 83 Turbo Engine with NA Cam, E11v2, 550CC Injectors, Stock Turbo dumb Ignitor and Coil, Intercooler, Garrett GT30R Turbo, Stock 83 280zxT Distributor. My 76 Turbo swap is almost ready to start and a map would be greatly Appreciated! William Quote Link to comment Share on other sites More sharing options...
scottyMIz Posted April 10, 2008 Share Posted April 10, 2008 i might have a base map for you let me look in the archives pm me your email Quote Link to comment Share on other sites More sharing options...
Len Posted April 11, 2008 Share Posted April 11, 2008 Are you using Halteck now Scotty? Good to see your post its been years... But that could be my fault ...this is first time I've been on in nearly a year. Quote Link to comment Share on other sites More sharing options...
scottyMIz Posted April 11, 2008 Share Posted April 11, 2008 yep had it for a while i ran it on the l28 and now its running the rb. There are very few ppl running them on rb engines specially here so its sad to say but i prolly know the most about the e6k with an rb here. I dont know much about the e11 but i am sure it's pretty much the same thing just newer with more options. I tried iming u a bunch of times....... you never reply Quote Link to comment Share on other sites More sharing options...
matthunter1448 Posted April 14, 2008 Share Posted April 14, 2008 i got one send me a email or something and i'll send u mine if u want i have a e6x 87 3.0 v6 turbo 550cc injectors holset hy35 and 35mm external wastegate Quote Link to comment Share on other sites More sharing options...
Chemicalblue Posted April 14, 2008 Share Posted April 14, 2008 I wouldn't use anyone else's map, Most of the time it wont even get you close. All you need to do is verify timing (timing lite) and make sure the injectors are off while you are doing this. After you are sure timing is correct, cut the fuel to 0 and slowly work your way up until it fires. This will save you allot of time and frustration. hope this helps Quote Link to comment Share on other sites More sharing options...
Guest alyssa Posted March 10, 2009 Share Posted March 10, 2009 Guys, I'm at a total loss here with a really stupid issue! I'll try to keep this short without reciting the haltech manual, trouble shooting guide, haltech forum, etc. BUT, I've searched top to bottom and cant solve my issue: When going ONline I can only get my F10x to connect 99%. According to Haltech this issue is directly related to using a serial to usb connector or any faulty connection method. Regardless, if I use my serial/usb or serial/serial connector I can only load 99% and then get prompted for a password. I've tried loading a handful of different maps, different com port settings, etc. I even created a map from scratch specifying NULL PASSWORD but I still get prompted. I'm really at a loss here. I bought this F10x slightly used and the previous owner swears there was never a password protected map of any kind on it...I'm running a Windows XP machine with all of the latest usb and or com port drivers. Also, I'm running Halwin v 1.26 and have tried my old v1.2...same result. The latest thing I've tried is a Keyspan usb to serial adaptor. This was suggested by Haltech support. F$%k!ng did nothing! I'm pulling my hair out because I still get to 99% complete when connecting the F10x to my XP Laptop. Every thing is in sync with my com ports, etc. It just keeps asking for a password and goes into data only mode after 99% complete connecting. I really need to tune my car this weekend; any suggestions!? Please help, its very much appreciated. Quote Link to comment Share on other sites More sharing options...
Chemicalblue Posted March 10, 2009 Share Posted March 10, 2009 You may have to get a serial card and not use a adaptor. Its sometimes cheaper to buy an old laptop from a used electronics supply that has one on it (or borrow one). If the guys at Haltech have recommendation it usally means that 100s of people have call in with the same issue and that fixed it. Let us know how it works out Quote Link to comment Share on other sites More sharing options...
Guest redkeg_1 Posted June 10, 2009 Share Posted June 10, 2009 Dose anyone out there have any kind of maps for the old F9 fuel controller? I have got it running the L28e or should i say did have it running. Quote Link to comment Share on other sites More sharing options...
B00STDZ Posted June 20, 2009 Share Posted June 20, 2009 I have purchased the new Haltech Platinum sport 2000(the updated e11v2). Anyone have any base l28et fuel maps? Scotty do will yours work with the platinum 2000? Quote Link to comment Share on other sites More sharing options...
B00STDZ Posted June 25, 2009 Share Posted June 25, 2009 Well? Still looking... Quote Link to comment Share on other sites More sharing options...
Chemicalblue Posted June 26, 2009 Share Posted June 26, 2009 Im running a PS2000 as well. Just load the map from the E11, check it over and your good. Quote Link to comment Share on other sites More sharing options...
B00STDZ Posted July 3, 2009 Share Posted July 3, 2009 Im running a PS2000 as well. Just load the map from the E11, check it over and your good. Do you have a base map I could use? Quote Link to comment Share on other sites More sharing options...
NismoC32 Posted July 5, 2009 Share Posted July 5, 2009 Also looking for a PS2000 base map for a L28ET engine. A map and info on the setup of the engine it is programed against will give some valuable info on understanding how the mapping process works. The most important info is: fuel pressure (idle), injector size, engine volume etc. Quote Link to comment Share on other sites More sharing options...
My Z is a piece of history Posted May 22, 2011 Share Posted May 22, 2011 anyone have a l28et map for haltech f10x? Quote Link to comment Share on other sites More sharing options...
monster626 Posted July 3, 2011 Share Posted July 3, 2011 if you are useing a sport 1000 or 2000 you can use the quick tune function to aid you in getting a base map make sure you have your set up in the computer correct you must have a wideband installed you will also have to set you afr map set your base timing to what ever you want 10 degrees or 15 degrees free rev your engine up every 500 rpm and use the Q key for that one cell of the W key for that cell the one above it and the two to the right. by the time you get up to approx 3000 rpm you can take your ms values and linierize them to the right a couple more cells.......you should be able to drive the car at low speeds to use those keys to get air fuel corrected. after you get air fuels you can tune for timing..........i do not recommend just guessing at this.....find a shop with a load bearing dyno to do this for you .....it is very easy to set up the top end for boost/fuel/timing it is a whole other thing to set the drivability where you get both power and fuel economy Quote Link to comment Share on other sites More sharing options...
Nizm0Zed Posted March 2, 2012 Share Posted March 2, 2012 Thread bump! Does anyone have a E6X L28ET base map that I could perhaps have a copy of? My engine is a L28ET, 440cc GTR injectors, GT3271R, waste spark ignition. The big thing is the fuel maps, im pretty much ok to change any other settings to suit what I have, but im having a bit of trouble getting my head around the fuel side of things. I dont need it to run perfectly, its going to go to a workshop for a full tune. Unfortunately for my wallet, if it doesnt start/run/rough idle it'll cost me more for them to tune it as they have to spend longer on it initially. If anyone can help, MASSIVE thanks. Quote Link to comment Share on other sites More sharing options...
the_dirtking Posted March 8, 2012 Share Posted March 8, 2012 Ill try to send you mine, send me your email Quote Link to comment Share on other sites More sharing options...
ryan95i4 Posted June 28, 2013 Share Posted June 28, 2013 (edited) Bumping this, Im to that point and would love to just look over someone else's setup to compare to where I am. Especially interested in anyone's maps that is using one of the platinum series ecus. If anyone would be willing to send me their maps, I would be forever appreciative! rmcdon at gmail dot com Thanks!! Edited June 28, 2013 by ryan95i4 Quote Link to comment Share on other sites More sharing options...
clear2me Posted August 21, 2013 Share Posted August 21, 2013 Hello i am looking for haltech F10x maps my car 280zx l28 turbo 680cc injector T3 turbo 17 psi any help pleaze Mohammad Quote Link to comment Share on other sites More sharing options...
