jacob80 Posted September 23, 2008 Share Posted September 23, 2008 Hey guys, I came across this on Ebay, will it work for putting a 240SX thorttle body spacer onto a turbo 280zx manifold? http://cgi.ebay.com/ebaymotors/_Car-Truck-Parts-Accessories__OBX-Throttle-Body-Spacer-93-98-Nissan-Altima-2-4L-240SX_W0QQitemZ160284011451QQadnZCarQ20Q26Q20TruckQ20PartsQ20Q26Q20AccessoriesQQadiZ2865QQcmdZViewItem?hash=item160284011451&_trkparms=72%3A543%7C39%3A1%7C65%3A12%7C240%3A1318&_trksid=p4506.c0.m245 Quote Link to comment Share on other sites More sharing options...
jacob80 Posted September 24, 2008 Author Share Posted September 24, 2008 I guess no one knows?... Quote Link to comment Share on other sites More sharing options...
jerryb Posted September 24, 2008 Share Posted September 24, 2008 25ft pounds of torque with a spacer....give me 4! ...if its too good to be true..... Quote Link to comment Share on other sites More sharing options...
jacob80 Posted September 24, 2008 Author Share Posted September 24, 2008 Yea, right. What do you guys think? Quote Link to comment Share on other sites More sharing options...
MansouR Posted September 24, 2008 Share Posted September 24, 2008 WAKE UP!! no way Quote Link to comment Share on other sites More sharing options...
jtmny1999 Posted September 24, 2008 Share Posted September 24, 2008 If its as thick as the picture shows you can use it as a linkage adapter for the 240sx TB. But performance wise I doubt it. Quote Link to comment Share on other sites More sharing options...
jacob80 Posted September 24, 2008 Author Share Posted September 24, 2008 If its as thick as the picture shows you can use it as a linkage adapter for the 240sx TB. But performance wise I doubt it. Ok, well Im not falling for all the performance crap they say, we just need one for the linkage. My other question is about the vacuum "port" if you will, the top part on these throttle bodies that have fittings on them on the outside, maybe Im describing it bad, but if you know what I mean, will this cover it up? If not, it would be a major vacuum leak. Quote Link to comment Share on other sites More sharing options...
lgoodson@pacbell.net Posted September 24, 2008 Share Posted September 24, 2008 Arizona z car has them and so does Pallnet Quote Link to comment Share on other sites More sharing options...
jtmny1999 Posted September 24, 2008 Share Posted September 24, 2008 I actually have the palnet spacer and 240sx TB on my old l28et motor maybe ill part the motor out, PM me I might just sell that. Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 24, 2008 Share Posted September 24, 2008 What vacume port? Are you talking about the water line on top (some)? I have some pics of mine.... Quote Link to comment Share on other sites More sharing options...
jtmny1999 Posted September 24, 2008 Share Posted September 24, 2008 What vacume port? Are you talking about the water line on top (some)? He might be talking about the 240sx TB, the one on the under side. Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 24, 2008 Share Posted September 24, 2008 Added pics. Quote Link to comment Share on other sites More sharing options...
Straight6Z Posted September 24, 2008 Share Posted September 24, 2008 All you need is one of thouse spacers and a Turbonator and you would be in buisness! Quote Link to comment Share on other sites More sharing options...
DevilZeto Posted September 24, 2008 Share Posted September 24, 2008 It can be done. Although i did some grinding on my manifold so i could get better flow off of it. Quote Link to comment Share on other sites More sharing options...
jacob80 Posted September 24, 2008 Author Share Posted September 24, 2008 What vacume port? Are you talking about the water line on top (some)? I have some pics of mine.... Well actually all 3 ports, it seems like when we put the throttle body on the right way with the TPS on the outside, the vacuum draw or whatever it is makes a huge vacuum leak, but im assuming the spacer will cover it, correct? Also, what do I do about the draw on the bottom? Plug it? Quote Link to comment Share on other sites More sharing options...
GeeZ Posted September 25, 2008 Share Posted September 25, 2008 Pallnet no longer has the spacer on his web site. Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted September 25, 2008 Share Posted September 25, 2008 Just put a rubber cap on the vacuum port. On the note of the spacer adding torque. Im not going to say it works but i do know that on 2cycle dirt bikes you can change the torque/HP by moving the reed cage closer or farther away. The farther away you put it the more torque. The closer you put it the more hp. Now we are talking a few foot pounds or 1 or 2 hp but there is a difference. Also that is on a 125CC dirt bike. I used to keep spacers in my tool box for different tracks. A long wide open track i would take the spacers out. But if it was a real short tight track i would put one or 2 in. These where total of 10mm max in thickness but you get the idea. Quote Link to comment Share on other sites More sharing options...
jacob80 Posted September 25, 2008 Author Share Posted September 25, 2008 Ok, I understand the fittings are able to be capped off, but I'm talked about the parts the fittings are attached to. Its like a raised piece in the intake. You know how the intake isnt a circle, its likea teardrop shape? Thats the part that isnt covered. How do we fix that? Quote Link to comment Share on other sites More sharing options...
jacob80 Posted September 28, 2008 Author Share Posted September 28, 2008 Does anyone know what I mean? Quote Link to comment Share on other sites More sharing options...
Noddle Posted September 28, 2008 Share Posted September 28, 2008 Does anyone know what I mean? Yes, the Egg shape inlet hole on the manifold, will this adaptor cover it, I don't think so, if you look at the bolt holes, and the inside diameter, its almost in line, and if you look at the manifold, it would not cover the egg shape hole at the top see included picture Nigel Quote Link to comment Share on other sites More sharing options...
