1rad280 Posted September 27, 2008 Share Posted September 27, 2008 I found new wire that need to be hooked up the car start and runs but it take a little to get it started.After starting the engine it idles great and revs good but if I give it gas but it fuel smokes bad. Any Ideas? Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted September 27, 2008 Share Posted September 27, 2008 Uhh, what? English Please. Are you saying its running rich? Quote Link to comment Share on other sites More sharing options...
1rad280 Posted September 27, 2008 Author Share Posted September 27, 2008 It run rich only when I give it throttle it runs fine at idle and dont smoke.Im thinking fuel pressure regulator. Quote Link to comment Share on other sites More sharing options...
Tony D Posted September 27, 2008 Share Posted September 27, 2008 then I take it we are talking abuot black smoke then? Quote Link to comment Share on other sites More sharing options...
1rad280 Posted September 28, 2008 Author Share Posted September 28, 2008 The engine was just rebuilt and the smoke is black. Quote Link to comment Share on other sites More sharing options...
Powerglide Posted September 30, 2008 Share Posted September 30, 2008 http://www.dumbestgeneration.com Quote Link to comment Share on other sites More sharing options...
AK-Z Posted October 1, 2008 Share Posted October 1, 2008 The engine was just rebuilt and the smoke is black. Check your AFM, TPS and sensor connections. The ecu goes into limp mode when it gets a bad signal from a sensor. Quote Link to comment Share on other sites More sharing options...
jerryb Posted October 1, 2008 Share Posted October 1, 2008 Yup....it does seem to be getting worse but this forum is one of the best at slowing its spread. www.dumbestgeneration.com Quote Link to comment Share on other sites More sharing options...
jerryb Posted October 1, 2008 Share Posted October 1, 2008 I have an idea.......help us help you. Your question is far too general , lacks informative details and is poorly composed. Slow down your typing and read your post before you click on "submit reply". If it comes across odd to you, imagine how it appears to us. Its a matter of perception. A poorly thought out incomplete question will result in incomplete or no answers at all. Which wire did you find...which Z model....which engine...any modifications...etc......? Please don't take this as a personal attack...but as constructive criticism to help you move ahead more quickly.... I found new wire that need to be hooked up the car start and runs but it take a little to get it started.After starting the engine it idles great and revs good but if I give it gas but it fuel smokes bad. Any Ideas? Quote Link to comment Share on other sites More sharing options...
1rad280 Posted October 2, 2008 Author Share Posted October 2, 2008 Ok, let me start over, I rebuilt the engine about a month ago,completey going through everything.I added a mallory unilite dizzy,mallory coil,and a header.When I first tried starting the engine it was not getting spark to the plug, but I was getting fuel to the injectors.After finding the wires that I needed to hook up to get spark, I found the injectors were not pulsing.I realised the blue wire that goes to the coil made the injectors pulse when hooked it to positive. After getting the engine to start it idled great but when I gave it throttle it ran extreamly rich, filling the whole shop with (fuel) smoke. I really need help, I dont really think the blue wire that goes to the coil needs to be on positive but it ran. Could the fuel pressure regulator be bad?Has anyone ever hooked a mallory dizzy to a 75 280z or later? If so I need to know what wires where used?I also need input thank you and sorry. Quote Link to comment Share on other sites More sharing options...
jerryb Posted October 2, 2008 Share Posted October 2, 2008 Well done:mrgreen:...Im afraid I cant help you but Im sure there are others that can. Come on guys any suggestions? Quote Link to comment Share on other sites More sharing options...
gwnwar Posted October 2, 2008 Share Posted October 2, 2008 You do have manifold vacuum hose attached to the fuel pressure regulator?? Is 7th injector leaking/open.. Quote Link to comment Share on other sites More sharing options...
1rad280 Posted October 3, 2008 Author Share Posted October 3, 2008 yes, the hose is on the fuel pressure regulator.I guess I should check the cold start injector as well. Quote Link to comment Share on other sites More sharing options...
