Guest NESS89 Posted November 4, 2008 Share Posted November 4, 2008 I finally got around to wiring up my push start button in my 73 240z. I removed my cigarette lighter since it didnt even work and installed the s2000 button in its place. Wired it all up and now my car starts with the push of a button. It also looks pretty sweet in my dash. Heres a garbage picture i took when i finished the install (it was dark and i took it with my phone). Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted November 4, 2008 Share Posted November 4, 2008 One step closer to being a supercar! Quote Link to comment Share on other sites More sharing options...
DavyZ Posted November 6, 2008 Share Posted November 6, 2008 I finally got around to wiring up my push start button in my 73 240z. I removed my cigarette lighter since it didnt even work and installed the s2000 button in its place. Wired it all up and now my car starts with the push of a button. It also looks pretty sweet in my dash. Heres a garbage picture i took when i finished the install (it was dark and i took it with my phone). Very cool That's the same place I want to do the same thing. Did you heist that from a junkyard or ebay? Looks good! Davy Quote Link to comment Share on other sites More sharing options...
Derek Posted November 6, 2008 Share Posted November 6, 2008 Here's where I got mine http://www.handa-accessories.com/s2000-03maint.html It's about 3/4s of the way down. Derek Quote Link to comment Share on other sites More sharing options...
Guest NESS89 Posted November 6, 2008 Share Posted November 6, 2008 I got mine from the same place as derek, youre also ganna need a boche 5 pin 30amp relay to wire it all up. Quote Link to comment Share on other sites More sharing options...
Derek Posted November 6, 2008 Share Posted November 6, 2008 Here's some more info http://www.revlimiter.net/mods/s2000_button.html Derek Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted November 6, 2008 Administrators Share Posted November 6, 2008 Installed the same S-2000 start button in my 240-Z race car. Wired it as the link above shows to control a relay for the starter and also the through glow light. Kept the button when I sold the race car. Quote Link to comment Share on other sites More sharing options...
deja Posted November 6, 2008 Share Posted November 6, 2008 This is my push button start. Its from a Viper, found it on Ebay. I connected it through the Camaro chassis wiring harness I used to replace my 280Z chassis wiring. It still uses the GM VATS system. The ignition key is next to the push button start and then my fuel pressure gauge. Quote Link to comment Share on other sites More sharing options...
Guest NESS89 Posted November 7, 2008 Share Posted November 7, 2008 Wow you guys have some awsome looking dashes. Mines just stock with the push start in it. Quote Link to comment Share on other sites More sharing options...
skib Posted November 7, 2008 Share Posted November 7, 2008 My fav. push start is the one in HughdogZ's 260z . Mabey he'll chime in and tell you about its fun features lol Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted November 7, 2008 Share Posted November 7, 2008 how do you wire it? i had never thought about doing this but it seems pretty cool. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted November 7, 2008 Administrators Share Posted November 7, 2008 how do you wire it? ... The pretty pictures are cool and all, but the text is also useful. Post #6, this thread... Here's some more info http://www.revlimiter.net/mods/s2000_button.html Derek Clicky the link.... hint hint... . Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted November 7, 2008 Share Posted November 7, 2008 The pretty pictures are cool and all, but the text is also useful. Post #6, this thread... Clicky the link.... hint hint... . haha What an idiot? thanks Braap. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted November 7, 2008 Administrators Share Posted November 7, 2008 haha What an idiot? thanks Braap. Its all good. I just couldn't let that opportunity to rib you go by... Quote Link to comment Share on other sites More sharing options...
Guest NESS89 Posted November 7, 2008 Share Posted November 7, 2008 http://www.oichan.org/mods/starter/starter2.htm this is the website i used to know which conectors on the button to use. You can follow these instructions except the part about wich wire from your ignition switch to pull out/cut. on the 240z its a black/yellow wire. Not yellow/black wire, thats for your wipers. (I accidently cut the wipers wire and had push button wipers until i fixed it.) Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted November 7, 2008 Administrators Share Posted November 7, 2008 http://www.oichan.org/mods/starter/starter2.htm this is the website i used to know which conectors on the button to use. You can follow these instructions except the part about wich wire from your ignition switch to pull out/cut. on the 240z its a black/yellow wire. Not yellow/black wire, thats for your wipers. (I accidently cut the wipers wire and had push button wipers until i fixed it.) Great link. Thanks. Push button wipers... Hmmm... Version of todays "mist" control.. Not a bad idea for an occasional windshield wipe without having to twist, then untwist... Quote Link to comment Share on other sites More sharing options...
rdsk8ter Posted November 7, 2008 Share Posted November 7, 2008 Im thinking of doing this myself but I want to pull my lighter out and put it in there could someone measure the switch for me I want to see if it will work in place of the lighter Quote Link to comment Share on other sites More sharing options...
Derek Posted November 7, 2008 Share Posted November 7, 2008 Im thinking of doing this myself but I want to pull my lighter out and put it in there could someone measure the switch for me I want to see if it will work in place of the lighter On my 73 I had to dremel the hole open a bit for the Honda switch to fit. Derek Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted November 7, 2008 Share Posted November 7, 2008 I just might do this. Except, I'd probably do it through the console compartment so it isn't noticeable to thieves. Quote Link to comment Share on other sites More sharing options...
TravRMK Posted November 7, 2008 Share Posted November 7, 2008 I just might do this. Except, I'd probably do it through the console compartment so it isn't noticeable to thieves. You still have to have the key in the run position for it to start. Can't theives see your keyhole there now. Quote Link to comment Share on other sites More sharing options...
