big-phil Posted November 8, 2008 Share Posted November 8, 2008 I'm building another motor, forged pistons, H beam rods, ported P90 head, lightened flywheel. Anywho on this new motor I wanted a more sequential injection setup. I bought a Haltech E6K, with Loom, and laptop on e-bay. Chris (turbo240z) and myself hooked it up thursday. The main reason I went with the e6k is because its what Chris runs. He knows it inside and out, so I felt comfortable switching. We took my e6k, hooked it to his car, downloaded his program into it, and started his car on my haltech. Then uploaded his tune to my laptop. We had to lean out the fuel maps, I have RC750cc's Chris has RC550cc's And its running without a hitch. I will be posting my megasquirt, relay board, loom, and some supra 440cc injectors soon for sale. Quote Link to comment Share on other sites More sharing options...
garvice Posted November 8, 2008 Share Posted November 8, 2008 Way to go, I recently got a Motec to replace my Megasquirt. Still in the installing stage, but I know I wont regret it. What CAS are you using? I have taken the optical disc out of a RB30 distributor and put it in place of my L28 optical Disc. Lines up perfectly (Thanks for standardizing Nissan). Quote Link to comment Share on other sites More sharing options...
slownrusty Posted November 8, 2008 Share Posted November 8, 2008 Phil - Coool! Was Chris running the L28ET distributor with the E6K? Also what new engine management system will he now be running? Yasin Quote Link to comment Share on other sites More sharing options...
big-phil Posted November 8, 2008 Author Share Posted November 8, 2008 yes he uses the dizzy. we both now have e6k's Quote Link to comment Share on other sites More sharing options...
slownrusty Posted November 8, 2008 Share Posted November 8, 2008 Cool, then I can quiz you both if I get some issues installing my Haltech on my engine! Hope thats OK. Also you running stock coil igntion or MSD? Regards - Yasin Quote Link to comment Share on other sites More sharing options...
big-phil Posted November 8, 2008 Author Share Posted November 8, 2008 slownrusty said: Cool, then I can quiz you both if I get some issues installing my Haltech on my engine! Hope thats OK. Also you running stock coil igntion or MSD?Regards - Yasin no problem. I'm running the msd 6a with a MSD blaster hvc 2 coil. Quote Link to comment Share on other sites More sharing options...
Tony D Posted November 8, 2008 Share Posted November 8, 2008 All those 'high grade' Aftermarket Vendors out there need to be very careful about dissing Megasquirt---here are a couple of prime examples of 'starter systems' where someone started with a Megasquirt, and eventually moved on to another system. What differences / improvements / problems have you encountered with the swap, compared with the MS, Phil? Quote Link to comment Share on other sites More sharing options...
big-phil Posted November 9, 2008 Author Share Posted November 9, 2008 all the problems I've ever had with megasquirt turned out to be my fault. The latest problem I had with resets was fixed by me shielding the signal wire from the dizzy. Megasquirt seems to be very sensitive to "NOISE"? The haltech is easier just because the tach wire, out puts, are all there in the wire harness. Megasquirt is easy also but you'll need to "build" the outputs. I do like megasquirts virtual gauges, and tunning. Maybe because I'm so used to it? The Haltech e6k is a DOS based program, so it does'nt have the bling MS does. The semi sequential injection makes the motor run very smooth. I'm still in the tuning stage, so I have not been able to beat on the motor yet. The MAIN reson I bought the haltech was because thats what Chris (turbo240z) is running. His car is the real deal. A ride in his, then in mine, and you can't help but want to do whatever he did. I always carried my laptop in the car with me when having MS. I was worried it would get some "NOISE", then reset, and I'd have to reflash the firmware. Mind you I've drivin my car for over a year with no problems, then take off the manifold or something, then I would have problems. Shielding the signal wire from the dizzy is key to having a worry free MS system, I think. Quote Link to comment Share on other sites More sharing options...
scottyMIz Posted November 12, 2008 Share Posted November 12, 2008 sweet!! we are getting more and more guys.....slowly lol i love my e6k also and i have only had one problem with it and it was when i was trying to run my rb25 with the rb25 casIt ran flawlessly on my l28et. I got the prob ironed out now and she is a very happy camper Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted November 12, 2008 Share Posted November 12, 2008 Hot Damn keep us updated Quote Link to comment Share on other sites More sharing options...
stevejones Posted November 13, 2008 Share Posted November 13, 2008 Hi Phil, Small world I guess. I bought this car last week http://forums.hybridz.org/showthread.php?t=132313 drove it one time.... and noticed 1) At lower speeds it runs rich (I think) 2) When the turbo kicks in there are some noises I am not familiar with (turbo, blowoff, but mainly a large squealing noise) 3) It is VERY fast I went straight to youtube to go find some turbo Zs just to listen to the sounds it is supposed to make, and ended up watching your Z vids. Good stuff! Hopefully the squeal is just the AC unit but I have 2 leaky injectors, so I will fix them before I go again. Anyway, do you still have the megasquirt? If so can you let me know how much you want for it? Thanks, Steve Quote Link to comment Share on other sites More sharing options...
Careless Posted November 13, 2008 Share Posted November 13, 2008 squeel on boost sounds like an exhaust leak right from the turbine housing or a leaky wastegate/dump pipe. Quote Link to comment Share on other sites More sharing options...
stevejones Posted November 13, 2008 Share Posted November 13, 2008 Thanks for the info! I will have a look/listen to see where it is coming from. Quote Link to comment Share on other sites More sharing options...
big-phil Posted November 17, 2008 Author Share Posted November 17, 2008 try to determine if its a sequel, or the air being pumped up? Quote Link to comment Share on other sites More sharing options...
wigenOut-S30 Posted November 17, 2008 Share Posted November 17, 2008 Good deal Phil, Now you and chris get that thing tuned up and take it back to the dyno.. Get vids of course lol.. I finally ordered my new turbo!! so I hope to be back on the road pretty soon!!! Quote Link to comment Share on other sites More sharing options...
datsun 1/2 dozen SD Posted May 2, 2009 Share Posted May 2, 2009 i am new to haltech i just got a e6k does anyone know where to get the short flying lead harness? and how much does it cost Quote Link to comment Share on other sites More sharing options...
big-phil Posted May 2, 2009 Author Share Posted May 2, 2009 alamo autosports in Arlington Texas sells them http://alamoautosports.com/ Ask for Brice, and tell him Big-Phil, Or Philip with the turbo 280z sent you. Not sure how much they are? Quote Link to comment Share on other sites More sharing options...
datsun 1/2 dozen SD Posted May 3, 2009 Share Posted May 3, 2009 thanks i appreciate it Quote Link to comment Share on other sites More sharing options...
Snailed Posted May 15, 2010 Share Posted May 15, 2010 On 11/13/2008 at 5:43 PM, stevejones said: Thanks for the info! I will have a look/listen to see where it is coming from. a leaking silicone coupler can squeel under pressure. Quote Link to comment Share on other sites More sharing options...
