Diff mount broke again need advice
scottyMIz
guys i went to the track again to get some better times with 18 psi of boost and a better ic.Well i went up did a great burnout and then staged.Light turned green and boom clunk clunk clunk.I knew exactly what it was the diff mount that i just changed about 3 weeks ago broke again :mad: This thing is new it even still has the stickers on it it's so new.I'm stumped what do the big hp guys do to keep the diff planted and still have drivability?I know there is a solid one but man i don't want the noise of it.I had a strap on it tight it was aircraft cable but it keeps pulling it apart and i had it tight. :mad: I didn't have to worry about this last year the clutch must have absorbed it all.The clutch from timz is just insane when it grabs i love it just wish the diff would hold.Anyone got any ideas?
What about the Ron Tyler design?
http://www.hybridz.org/ubb/ultimatebb.php?ubb=get_topic;f=7;t=000774
I plan to use this design with slight changes. I plan to make it with fewer welds, just one bent piece from bolt holes to bolt holes with the reinforcing piece welded on the back.
However, I'm not running big hp. But still, this looks like the best layout I've seen.
Guest Anonymous
Dan..Thanx for the Hybrid link. Now that I have ink, the more notable posts get printed to stuff in the JTR manual. How did you manage bending the steel in your mount with only the red handled crescent wrench? LOL It is amazing what you can do with a single tool. Did you ever consider hooking the wrench up to a battery and making an arc welder out of it ? Stick a coat hanger on the end for rod. Would you wire the wrench to the positive or negative post?
all i did was bent a 1/8 flat metal bar over the rear....and bolted it to the two bolts on top of the rear and two bolts on the front crossmember....if you still have a r180 front member the holes are already there i used 3/8 header bolts and you`ll need i think 5.5-6" bolts for the rear.
quite a few are using this type of unit...just bend the bar in a vise...no welding keep it all one unit....no noise or vibration...won`t loosen up and chances are never break.it one of those things that people over engineer and it doesn`t need to be....mark
i like the other design better that someone made it works good.The one with two pieces of pipe welded into the mount on the car and use the old stock mount and drill holes and then put in rubber mounts and bolts all the way thru.That way if the rubber breaks you stull have a bolt running thru to hold you.Oh ya i also found that i broke the aircraft cable holding the diff down eek2.gif
I think you're refering to Simon DeGroot's design:
http://www.usq.edu.au/users/degroot/240z/pages/diffmount.htm
Of which I am a big fan. I copied it using some fence tubing and 280Z poly trans mount bushings:
http://240z.jeromio.com/diffmount.html
My write up is kinda sucky, so if you have any questions, feel free to ask.
Terry, why bother with an OE diff mount above the Diff? Use the GM Tranny Urethane replacement in the Ron Tyler design - it's interlocking and won't break under acceleration or decelleration (I've been testing both lately - coming down off of 5 grand in 3rd makes alot of nice noise - out of the pipes that is. :D )
The Ron Tyler design isn't solid - it uses a tranny mount to isolate the vibrations.
Has anyone taken the Ron Tyler design, but instead of being solid, build it tall enough so that an OEM mount can be placed between it and the differential (the OEM mount on top of the diff instead of below it)? This way the hard hole-shots will compress it instead of pull it apart, and you will still maintain the OEM "feel" you want,
Scotty, I copied Don manzo's set up. So easy and
dirt cheap. I took some 2x2 by 1/4 inch angle iron
and cut it the with of the front diff mount.I then
drilled and tapped 2 3/8's holes into the metal
part of the mount. Then drill your angle iron and
bolt it in. The 2" foot goes under the the cross
member and kills all pinion wrap! I just got it
done last nite and it work killer! Don's car runs
11.54 at 121 so I know this is a proven set up.
If ya want I will try and get some pics for ya.
Scotty - I broke my old mount just like you. I thought I was clever, and made a piece of angle iron just like z ya describes! So much for originality, but it's simple and it works.
well i used the design that i described but i used smaller pipe and then used hydraulic hose as the bushing(has metal brade in it)and then used bronze bushings and it doesn't move at all i had my lady get in and put on the ebrake and then go forward and back and the diff stayed right there.But when i changed driveshaft flanges from my other r200 to the 3.54 r200 i tried to tap the flange back on instead of tightening it on like i was suppose to so now i get noise when it's on decel and only when i let off the throttle before i push the clutch in.So tonight i'm gonna try to tighten it more just incase i didn't do it enuf before.But so far the mount has been proven on timz's car he runs the same design but with regular bushings and mine is just a modified version of it.I like the way it loks and lets me still have alot of room under there for the ebrake and everything.Thanks guys for the suggestions i'll update if it will hold my torque monster at the track next time i go. :D
OK, have to chime in with my version. Its similar to the angle iron approach, but instead, I folded up a "U" channel out of 1/4" plate to catch both sides. I also added a rubber pad between this bracket and the bottom of the cross-member:
I made the rubber pad from an old 240Z engine mount that I cut up with a hack-saw. Here it is mounted to the cross-member:
I carved away part uf the U-Channel to clear my 3" exhaust. Here is everthing installed (from the rear looking forward)
I also need to sign in on this thread, 3 years ago when the R180 grenaded I did the
R200 LSD swap and soon after I experienced the broken mount syndrome. I also did
the snubber with the 2X2 1/4" angle and have had no trouble since.
Guest Anonymous
Paul,, Now I am going to have to copy and print another good design since yours is the easiest for me to make. And Dave I just blew my colered ink cartridge on your simpler design
I have 4 of the 2X2 1/4" angle front diff mount brackets left from when I did mine. It seems that for some reason when I make a part I do a couple extra in case I mess one up. $5.00 each to cover shipping. These are easy to install without tearing the car apart. See the pictures 2 posts back.
V8-240Z@juno.com
