Evos 9sec 2jz build - 9's, 8's, and 7's done going for 6 sec pass now!
  On 7/22/2011 at 7:59 PM, GrtRat1 said:
Wow man, you've come aloong way...
...and long way to go. LoL
Worked on my rear suspension last night and got these guys put together: 250lbs hypercoil springs, five way adjustable struts, good used 280z strut tops, and brand new 5" coil over sleeve/nut from A-1 Racing
7-22-2011002.jpg?t=1311368708
7-22-2011007.jpg?t=1311369044
All together
7-22-2011009.jpg?t=1311369088
7-22-2011011.jpg?t=1311369127
7-22-2011013.jpg?t=1311369204
I really like this picture
7-22-2011015.jpg?t=1311369242
7-22-2011017.jpg?t=1311369310
Front end suspension is next on the list.
Edited by Ivan280zt
What is holding the threaded sleeve onto the strut?
Is it just sitting on there, or do you eventually weld it on?
What would happen at full extension of your suspension? (Though I don't expect that would be too much of an issue in this car, not using it for rally etc).
Ivan,
I'm really liking the finish on your suspension parts that you say have been powder coated black, is the 'stipple' effect is a result of the blasting giving the pieces a textured surface? Any details on what colour the powder coater used etc would be very appreciated, if you can coax the information out of him, the pieces done like that look PERFECT in my opinion, certainly a lot nicer than gloss. Any details would be much appreciated.
Factory weld that used to hold factory spring pearch is whats preventing sleeve from going down any further.
  On 7/23/2011 at 6:28 PM, camerashy said:
Ivan,
What my powder coating guy is using is eastwood texture finish black powder coat.
  On 7/25/2011 at 4:03 PM, Evan Purple240zt said:
Car is looking great buddy. How many years has this thing been down now?
Evan,
Hey bud not really sure how long it has been down but I would say somewhere since mid to late 2007. I have been working on it on and off since mid 2008.
  • 1 month later...
  On 8/1/2011 at 10:36 AM, IbanezDan51 said:
Beautiful car!
Will the R200 diff be man enough for the power?
It should be good enough for a while.
Since engine bay is not done yet I have some pics of short block coming together just to keep this thread going to keep myself motivated...
This is short block after about 2-3 hours worth of cleaning with paint stripper, wire brush, brake clean, and map gas torch lol then 3 coats of high temp semi gloss black paint. Block looks much better in person picture just came out like poop because of the flash.
9-11-2011017.jpg?t=1315758631
9-11-2011019.jpg?t=1315758619
Got these parts powdercaoted in wrinkle black and cast aluminum and they are soooo clean in person.
9-11-2011011.jpg?t=1315758666
9-11-2011012.jpg?t=1315758655
9-11-2011014.jpg?t=1315758643
Arp rod bolts ready to go in.
9-11-2011020.jpg?t=1315758607
Rod bearings and crank jorunals all look great. Arp rod bolts all in.
9-11-2011023.jpg?t=1315758599
9-11-2011024.jpg?t=1315758590
All brand new oem parts: water pump, TT oil pump,timing belt tensioner/pulley, TT crank pulley with trigger wheel, all new bolts and nuts, TRD 160deg thermostat.
9-11-2011028.jpg?t=1315758571
Eagle electric 200amp alternator.
9-11-2011026.jpg?t=1315758579
9-11-2011030.jpg?t=1315758562
Wrapped up until engine bay gets done.
9-11-2011038.jpg?t=1315758532
Edited by Ivan280zt
For the better part of the past month my buddy Richard has been working on my engine bay. From start to the finish of the whole engine bay shave job there is easily 100-120 hours of labor between two of us. Richard really outdid himself guy is just pure perfectionist! Here are pictures of his work.
Starting to bondo and sand down whole engine bay.
8-23-2011011.jpg?t=1316300006
8-23-2011013.jpg?t=1316299998
8-23-2011017.jpg?t=1316299988
8-23-2011019.jpg?t=1316299980
8-23-2011025.jpg?t=1316299971
8-23-2011027.jpg?t=1316299961
Here is everything with light coat of etching primer so that surface would not rust.
8-23-2011030.jpg?t=1316299951
8-23-2011033.jpg?t=1316299927
Then some more sanding...
8-23-2011038.jpg?t=1316299916
Z wrapped up to prevent overspray.
8-23-2011031.jpg?t=1316299940
Thats it for tonight I will post part two in day or so.
Edited by Ivan280zt
