Evos 9sec 2jz build - 9's, 8's, and 7's done going for 6 sec pass now!
Just got caught up on the last two years of this build (last 8 pages or so).
My head hurts. . .
Great now you can stop asking me how everything is coming along every time we talk lol.
Got the car back on the ground and rolling around!
12-12-2011010.jpg?t=1323740166
Shiny parts!
12-12-2011008.jpg?t=1323740181
12-12-2011005.jpg?t=1323740194
DEAR BABY JESUS CAN'T WAIT FOR THE BODY WORK!!!
12-12-2011004.jpg?t=1323740215
Got my fuel rail from FSmoto great quality and great service from top notch guys! Also got the 11mm top hats for my ID1000's from my local shop TopDeadCenter (TDC).
12-12-2011018.jpg?t=1323740149
12-12-2011021.jpg?t=1323740133
Fuel rail looks all fancy in there.
12-12-2011025.jpg?t=1323740106
12-12-2011023.jpg?t=1323740120
Q45 throttle body all cleaned up and primed looks nice and simple.
12-12-2011030.jpg?t=1323740065
12-12-2011029.jpg?t=1323740085
I think thats all I have for now no more updates until after holidays.
Edited by Ivan280zt
  • 4 weeks later...
Its been few weeks from last update so I figured it would be good time for one.
Brand new brake master cylinder.
1-6-2011004.jpg?t=1325898725
Remanufactured brake booster (primed and spray painted came out pretty nice).
1-6-2011006.jpg?t=1325898703
They make such a nice couple.
1-6-2011008.jpg?t=1325898688
Spray painted throttle body not as baller as Richards painting but it will do.
1-6-2011015.jpg?t=1325898674
1-6-2011016.jpg?t=1325898662
Under intake manifold.
1-6-2011019.jpg?t=1325898648
5 bar aem map sensor.
1-6-2011024.jpg?t=1325898625
Made -4 turbo oil feed line.
1-6-2011028.jpg?t=1325898605
Vacuum line for Tial Bov.
1-6-2011034.jpg?t=1325898586
1-6-2011036.jpg?t=1325898570
Ingressol Rand boost solenoid.
1-6-2011041.jpg?t=1325898552
Catch can all done and mounted. I think that I might add extra bracket on catch can so it can be more sturdy.
1-6-2011042.jpg?t=1325898529
1-6-2011044.jpg?t=1325898511
1-6-2011045.jpg?t=1325898491
1-6-2011048.jpg?t=1325898473
1-6-2011051.jpg?t=1325898450
1-6-2011057.jpg?t=1325898436
Dipstick bracket made.
1-6-2011065.jpg?t=1325898420
1-6-2011070.jpg?t=1325898405
Going to start on fuel system tomorrow so more fun for me...
Edited by Ivan280zt
I mounted my aem boost solenoid on the firewall pretty much in the same spot and its is loud as hell, you might want to rubber isolate it at least.
I am planing on for sure just need to finish few more small brackets and then it's off to powdercoating then I will do final mounting.
Looks amazing. A word of advice, I used the same tubing on my car from the boost controller to wastegate etc and the the tubing that came any where near the turbo or exhaust completely melted on my first drive. It was suppose to be high temp tubing too.
I have some heat insulation left over I might as well go and get it on there better safe then sorry!
  • 3 weeks later...
Got around to doing my fuel system it came out pretty nice and I am fairly happy with it.
Bosch 044 pumps mouted with all the fittings.
2-4-2012001.jpg?t=1328406971
Very tight fit.
2-4-2012003.jpg?t=1328406961
Mounted right next to the fuel cell.
2-4-2012019.jpg?t=1328406949
2-4-2012020.jpg?t=1328406928
Got these fuel filters from summitracing one for each pump.
2-4-2012032.jpg?t=1328406895
I ended up mounting my FRP between starter and engine mount it came out really good.
2-4-2012071.jpg?t=1328406657
Return line from fuel rail to the FPR.
2-4-2012023.jpg?t=1328406909
Dual -8 feed with filters before pumps.
2-4-2012041.jpg?t=1328406870
Dual -8 into single -10 feed line.
2-4-2012042.jpg?t=1328406857
Talk about tight fit!
2-4-2012044.jpg?t=1328406837
Second line is -8 return.
2-4-2012046.jpg?t=1328406824
-8 return line
2-4-2012060.jpg?t=1328406735
2-4-2012063.jpg?t=1328406715
Under the car.
2-4-2012047.jpg?t=1328406812
2-4-2012048.jpg?t=1328406792
Weldon fuel filter (I will run driveshaft loop around it so it will serve as a shield for filter and as a driveshaft loop).
2-4-2012054.jpg?t=1328406778
2-4-2012056.jpg?t=1328406756
-10 feed line to the rail.
2-4-2012065.jpg?t=1328406675
From the top looks clean and no clutter of lines running around.
2-4-2012064.jpg?t=1328406692
Test fitted some 15" Weld's from another broke ass non running Z... : )
2-4-2012074.jpg?t=1328406639
I think that I am going to start building my brake lines next so more shopping for me.
Edited by Ivan280zt
  • 2 months later...
Man talk about overdue update!!! I did not do much over the last two months I guess working mostly six days a week does not leave much time for car work. I was able to finish my brake lines today everything came out good except rear brake line (soft line to hard line) fittings are leaking on both sides which I had feeling would happen since they did not feel like they fitted very well. I will look into that issue next weekend I guess.
3/16 brake line with -3AN fittings and banjo bolts on master cylinder. I think that I have about 12-14 hours of labor in whole setup. I could have done it much faster but I was just taking my time with it since I wanted to do this only one time and I wanted it to look nice and clean.
4-1-2012029.jpg?t=1333309879
4-1-2012039.jpg?t=1333309864
-3AN bulkhead fitting
4-1-2012052.jpg?t=1333309834
4-1-2012056.jpg?t=1333309820
4-1-2012059.jpg?t=1333309781
Line lock "mounted" on the crossmember. I have to build bracket for it that will keep it about 1-1.5" higher than it is in picture so it would be about same height as 2jz crossmember.
4-1-2012062.jpg?t=1333309763
4-1-2012065.jpg?t=1333309745
4-8-2012017.jpg?t=1333933724
I mounted (with zipties lol) proportioning valve under the car since I only plan to adjust brake bias one time and lets be real this is not road race car so I dont need it inside of the car.
4-8-2012001.jpg?t=1333933897
4-8-2012003.jpg?t=1333933881
4-8-2012004.jpg?t=1333933867
4-8-2012006.jpg?t=1333933847
4-8-2012007.jpg?t=1333933833
4-8-2012008.jpg?t=1333933811
4-8-2012011.jpg?t=1333933788
4-8-2012013.jpg?t=1333933767
4-8-2012014.jpg?t=1333933747
Thats it for the brakes I just need to see what is the deal with two of the adapter fittings and then brakes should be ready to be bleed of air.
Did I mention that my new wheels came in?!?! :D They are weld rt-s series front wheels are 15x3 1.5"BS and rear wheels are 15x9 4.5BS (crap they might be 5.5BS not sure anymore lol). Front tires are Nexen 3000 and rears are some junk hoosier 275/50-15 that I got from F&D autocare for free and Bob was nice enough to mount them for me THANKS BOB!!!
4-8-2012020.jpg?t=1333933698
4-8-2012023.jpg?t=1333933677
4-1-2012023.jpg?t=1333309923
4-1-2012027.jpg?t=1333309902
Man I really like how this back looks now!!!
4-1-2012048.jpg?t=1333309854
No clearance issues with big brakes at all.
4-1-2012005.jpg?t=1333310002
4-1-2012006.jpg?t=1333309981
Next on the list are fender flares to be mounted then it will be time for engine management wiring.
