Another Intake manifold CFD thread (big pics)
hughdogz
Hey guys, I'm still working on a design for a custom intake using those group buy flanges.
I'm still learning how to use CFD simulation, so it is still a learning experience for me.
I want to minimize having to do custom bends, but it looks like I'll have to do something to avoid vorticies, even at such a small velocity.
For my first attempt, I just guessed on the boundary conditions, 200 mm/s fixed velocity at the outlets, and the inlet is "free".
After reading MONZTER's thread, he was getting ~4000 mm/s and I want half the HP (flow) as him, so Im re-runing it again at 2000 mm/s.
Here is the CAD model, to do a CFD I have to model the inside (which is kind of wierd but that's the way it works).
The simulation has 30 time steps, to ramp up the flow and give the solver an easy time at converging. Here is zero velocity at time step 0:
Velocity contours at full speed:
Here you can see the big vortices / swirl that I need to get rid of (the big one and the one near the first runner):
I re-ran the model at 2000 mm/s and it is about the same. 2 & 3 are the only ones getting a good shot of the flow.:
velocity_streamlines_8.png]
seems like you would be best off to angle the throttle body so the back wall (i guess you'd call it that) is straight, to try and 'aim' the airflow along the back wall of teh plenum, and reduce the low pressure zone, and cavitation just after teh throttle body.
Good point. I appreciate the input Nizm0Zed. :icon14: That is what I'm going to try to do with the next version.
I turns out that I didn't have the runner spacing correct, so I had to fix that. :lol:
Also, I didn't have the right element selected for the boundary layer, for the first runs it takes a lot longer to run with the right one.
Ugh...I need a Cray!! The FEA computations are taking too long. :redface:
[Edit: A little better, but now it looks like I'm generating swirl after the flow hits the "back corner" of the intake]
no worries chief, but,
DISCLAIMER! I was drunk when i worte that, so if its doesnt work, dont blame me.....
looking at your new design, perhaps tighten up the plenum, so teh wall runs paralell to the runners, upto about half way between teh second and third runners.
Looking at that, it seems to be cavitating because there is too much space to fill?
Maybe its worth a shot trying to help the air distribute more evenly amongst the groups of cylinders (1/2, 3/4, 5/6). Maybe you could play with some flat guides placed around the inlet, maybe as marked in red as in the pic below.
I doubt they'll work to be honest, but I've always been curious. If they show any promise it might be worthwhile experimenting with various lengths and directions/shapes of the guides as well.
Dave
Dave is on to something with his "guides" idea.
In commercial HVAC duct design we use turning vanes (like what Dave calls guides) to better direct the airflow through duct work and to keep the air attached for less static pressure.
Perhaps a small vane near each runner inlet and maybe one or two others strategically placed in the plenum would help. The size and shape of the vanes would be critical for improving airflow over the relatively broad range of airflow velocity you see in an intake manifold.
Here is rev 4:
I think I should make the taper less and adjust the inlet angle more towards the "back wall". Also, I'll try using a straight section instead of a curved one.
I really need my 64-bit workstation. Doing this on a 32-bit laptop with 3GB RAM really limits what you can do...
Interesting thread and awesome program!
What would happen if you tappered the runners... say your using 1 5/8" runners... what if you used 1 5/8" at the head and 1 3/4" at the plenum and increased the overall volume of the plenum.
My logic here.... tappering the runners should naturally create vacumn and enlarging the plenum volume would decrease the velocity of the air coming in. I'm thinking that this would maybe make the runners suck the air in more evenly than the air being slammed into the runners ? I really don't know just curious on this one.
-Ed
Either way... props on crunching the numbers!
That is really nice software. Just out of curiosity, if it's not too hard to model, try throwing one of those crappy turbine blade intake thingys that supposedly swirl the air on the way in. See what your computer spits out.
Another idea is to make it like a header...bring the runners together in a cluster at the intake. I know the "equal length" rule will be tough to keep though.
Thanks for the input guys!
Hi Cygnus, on my next go-around I'm going to try to make the inlet come in parallel to the runners (like an RB25). Also, I'd like to revisit Helix's guide / diverter idea, extending them almost to the runner entrances. I could also try closing up the plenum some more, so the flow is forced to have a straight shot to runner six...
Here is the turbine blade model (not sure if they are right). I threw in five "swirl-ators". I just went by some crappy pics of swirl effect throttle bodies off Ebay. I'm not sure they were much help, what do you think?
Let me know if you wanna try your hand at an rb25det intake, I have a spare stocker laying on the floor I can measure for you.
Sure! That shouldn't be too difficult to do. Pics and general measurements would work great. :icon14:
http://home.comcast.net/%7Ehughhenderson/pics/Intake_CFD/swirl-ators.png
http://home.comcast.net/%7Ehughhenderson/pics/Intake_CFD/swirl-ators_2.png
http://home.comcast.net/%7Ehughhenderson/pics/Intake_CFD/swirl-ators_3.png
http://home.comcast.net/%7Ehughhenderson/pics/Intake_CFD/velocity_streamlines_12_rev5_swirl.png
i think hes talking about the "Turbonator" or some variant of it, theres a few different rip offs of one another some go across the diameter of the intake tube and some dont.
http://www.tornadofuel-saver.com/?gclid=CM3N4obDvJkCFR0SagodOkJT7w
http://www.turbonator.com/Contact.htm
http://www.vorteccyclone.com/index.html
the turbonator link is on contacts because on their home page theres a really annoying guy yelling at you the instant the page loads and i cant find a way to stop it before i wanna smash my speakers
Ahh...Yes those look a lot different than what I tried to make. I was going by one of these:
09c8_1.JPGhttp://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=swirl+throttle+body&_sacat=See-All-Categories
