Fuel rail - Max Hp from stock rail?
Robert
Hi,
I have a L24E that Ive turbocharged and Megasquirted with 440cc supra injectors. I do have a problem though, cause at what I think feels like about 300BHP, maybee a little more, the injectors are maxed out, and the engine screems for more fuel!!
Has anyone done 300+ BHP on stock fuel rail before?
My setup:
L24E stock internals
T04E turbo .63 exhaust
3" exhaust
Intercooler
Stock fuel rail
440CC injectors - Should support 400+hp
Walbro Fuel pump
Stock fuel pressure regulator (should be 1:1)
Megasquirt
100% DC @ 5000+RPM
Approx 300BHP
Hi.
Such small pressure drops should not lower the injectors to much, but lets say 400cc.. This still gives me an extremely high BSFC if my "seat of pants" ~300 BHP is correct. I could do a drag with a 300BHP car just to test though.
I did some diagnosis last night. I changed my fuel filter so theres no braking there, and I clamped the fuel return pipe on the rail to increase fuel pressure. Im going to take it for a test drive today and see if I can lower the dutycycles a little now.
Ive also E-mailed Topendperformance, and they, like you, claimed the stock rail handles 350hp easy. My only conclusion is that either the pressure regulator dont raise the pressure enough, or my walbro pump cant handle the demands.
Thanks
  1 fast z said:
Put a fuel pressure guage before the rail. If it is the rail (more than likely not) then you will see a huge fuel PSI before the rail. Then put the guage in the rail, and compare.
Ill try to get a gauge that I can hold up to the windscreen. That way I can see If the pressure drops at high RPMs. If so, the pump probably needs to be replaced...
A little update here:
I replaced my fuel filter, and clamped the fuel return pipe a little (to increase the base pressure in the rail). Also i opened up the "IN" pipe where the hose is clamped on, cause theres a smaller diameter on the pipe there. So, I took it for a drive, and the first thing I noticed was that It was close to impossible to start! Good sign..
Further on the AF ratio was a bit richer than normal, about 0.5-1 AF value lower I would guess. Unfortionatly my computer was not in the car, so I had no possibility to tune it, but I emptied a few gears, and the AFs, that earlier went up to 13s on 5000+ was now down on 10s!
Now I dont know how much extra pressure Ive applied here, but the injector CCs dont grow too much on higher pressure.. Also the fuel filter could have been clogged a little, and the narrowing on the "in" pipe probably restricted flow a little.
All in all, I think I got a little here and a little there. Im going to tune it tonight and hope to get the DC down to 80s, or at least 90s....
