ktm Posted September 7, 2011 Author Share Posted September 7, 2011 (edited) I don't think that you can leave the potentiometer in place as I believe the lights are LEDs. I pulled mine earlier when I converted the stock gauges to LED lighting, that, and the potentiometer was not functioning throughout the range of motion. You can always tap the heater console lights into the potentiometer themselves and just wire up the Speedhut gauges separately. The lights on the Speedhut's are not that bright as to be a destraction. Edited September 7, 2011 by ktm Quote Link to comment Share on other sites More sharing options...
ZT-R Posted September 7, 2011 Share Posted September 7, 2011 When i remove the amp meter can i just cap off the white/red or should i hook them together? Im not running a volt gauge. Quote Link to comment Share on other sites More sharing options...
ktm Posted September 7, 2011 Author Share Posted September 7, 2011 You need to hook them together. The amp meter is the worst part of the 240z electrical system. If you look at the wiring diagram, that is how the battery gets its charge from the alternator in a 240z! Make sure this is a SOLID connection. I kept melting my butt connector and you would see smoke periodically. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted September 7, 2011 Share Posted September 7, 2011 Yea, I dont crimp anything, just soder and heat shrink. Quote Link to comment Share on other sites More sharing options...
ktm Posted September 7, 2011 Author Share Posted September 7, 2011 So do I, but with the dash and harness still in the car when I first installed a 280z voltmeter, soldering and heat shrink were not an option. However, when I installed the Speedhuts, I eliminated that connection. I've rewired my car as well since this install. That alone was well worth it. Quote Link to comment Share on other sites More sharing options...
spitsnaugle Posted October 14, 2011 Share Posted October 14, 2011 (edited) Quick question, did you have a noise problem with your tach? Mine was very bouncy above 3500 rpms. S130, did you figure out a fix for this? My tach as smooth as butter till about 3500 rpm as well, then it spikes all over the place. It even thought I was idling at 4k once after jumping around a bit. Anyone else that may know a solution I'd be quite happy to try it. Edit; I cut the purple wire loop on my lunch break. It removed the huge jumping/spiking over 3k, however the tach is jumping around 300-500rpm at all rpms now. Sorry for the semi-old-thread bump. Edited October 14, 2011 by spitsnaugle Quote Link to comment Share on other sites More sharing options...
David GArcia Posted April 17, 2012 Share Posted April 17, 2012 Where did you tap in to get an oil psi pressure reading? Did you just remove the original sensor and added the one that Speedhut supplies? If so then the engine temperature and oil psi readings are not being sent to the ecu after the install correct? Quote Link to comment Share on other sites More sharing options...
ktm Posted April 18, 2012 Author Share Posted April 18, 2012 I installed the oil pressure sender from Speedhut into the stock pressure sender location and used a 1/8-bspt to 1/8-npt adapter. I was running a standalone engine management system that did not require an oil pressure signal. My coolant temp was provided by a different sender than the one from Speedhut. Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted April 20, 2012 Share Posted April 20, 2012 I ran a 1/8 NPT tap into my block, where the original sender was, it has sealed fine for 4 years. The threads are very close to the same, but the NPT has a defined taper to it. Quote Link to comment Share on other sites More sharing options...
SDgoods Posted May 31, 2012 Share Posted May 31, 2012 damn those look awesome Quote Link to comment Share on other sites More sharing options...
Fire604 Posted June 4, 2012 Share Posted June 4, 2012 Has anyone used the Speedhut oil pressure sensor in the stock sensor's location with the stock ecu? What is the "work around" or modification needed to get a signal to the ECU? Any thoughts? Quote Link to comment Share on other sites More sharing options...
3ryce Posted July 4, 2013 Share Posted July 4, 2013 I plan on getting the just the tachometer for now, then the speedometer. They looks great! I like the other stock gauges tho. haha. I have a 72 s30 240z and have a msd ignition. Will I still have to use a tach adapter? Quote Link to comment Share on other sites More sharing options...
calpoly-z Posted July 4, 2013 Share Posted July 4, 2013 No tach adapter required with speedhut gauges. Just hook into the tach output on the MSD box. Quote Link to comment Share on other sites More sharing options...
EF Ian Posted August 7, 2014 Share Posted August 7, 2014 Is that the cobalt blue glow or standard blue? and do you think it would be possible to fit 2 5/8" gauges in the pods? Quote Link to comment Share on other sites More sharing options...
mxgsfmdpx Posted August 9, 2014 Share Posted August 9, 2014 Is that the cobalt blue glow or standard blue? and do you think it would be possible to fit 2 5/8" gauges in the pods? I think on page 2 of this thread he mentioned they are regular blue and that he thought cobalt blue would be too dark. But double check... Quote Link to comment Share on other sites More sharing options...
EF Ian Posted August 9, 2014 Share Posted August 9, 2014 Thanks, had a another good look through and found it, on page one though. Quote Link to comment Share on other sites More sharing options...
JesseDeanZ Posted February 19, 2015 Share Posted February 19, 2015 So I just ordered my speedhuts and I ordered 4 1/2 for speed and tach due to the hole being 5", Looking at yours I think I may wanna get a smaller size.... Anyone done a 4 1/2 in their z? Quote Link to comment Share on other sites More sharing options...
skerry Posted February 20, 2015 Share Posted February 20, 2015 I just put the 4.5 inch gauges in mine. They fit very well into the carriers but you will have to find a way to hold them in. I used a combination of pvc pipe and screws but the guy who sells them in the group buys forum said he used hot glue. Here are a couple pictures of them mounted into the carriers. http://imgur.com/RvUWuFc http://imgur.com/G0AumuF Quote Link to comment Share on other sites More sharing options...
rigez Posted February 20, 2015 Share Posted February 20, 2015 (edited) Is there a turn signal and hand brake lights an option for the speedo/tach combo? I just put the 4.5 inch gauges in mine. They fit very well into the carriers but you will have to find a way to hold them in. I used a combination of pvc pipe and screws but the guy who sells them in the group buys forum said he used hot glue. Here are a couple pictures of them mounted into the carriers. http://imgur.com/RvUWuFc http://imgur.com/G0AumuF Edited February 20, 2015 by rigez Quote Link to comment Share on other sites More sharing options...
rigez Posted February 20, 2015 Share Posted February 20, 2015 Ok I just checked their site. Got my answer... Quote Link to comment Share on other sites More sharing options...
