DuoWing Posted September 9, 2010 Share Posted September 9, 2010 (edited) Hey I've been searching around and couldn't find this information. I have an early 87' Z31 Turbo GLL. It's got a production date of later 86, but the owner's manual and the title label it as an 87. I'm being told that apparently the pre-4/87 Z31s didn't have the FS5R30A. I'm also being told that apparently the 4/87s and on besides having the LSD also had larger/heavier duty axles? As far as I thought all the 87's were the same except that 4/87 and on they gained the LSD and a slightly larger rear sway bar. Is there any info I'm missing? Also I'm trying to figure out if my tranny is a FS5R30A for sure or not. When I took it out to change the clutch, I had to remove the shifter by undoing a c-clip/crimp ring(whatever you call it) holding it in place. The rubber boot couldn't be removed from the shifter, plus it matches the pics of the FS5R30A as well as the mount on AZ-ZBum's site and it seems to follow the directions in the FSM. Were there any 87N model year cars that still had the T5? Were the tranny mounts for the T5 and FS5R30A any different? Any info is appreciated. Thanks guys! Edited September 9, 2010 by DuoWing Quote Link to comment Share on other sites More sharing options...
Dave@SBClutch Posted September 16, 2010 Share Posted September 16, 2010 My book says the changes started in September of 1986. Hope that helps. Quote Link to comment Share on other sites More sharing options...
BunnySlippers Posted September 19, 2010 Share Posted September 19, 2010 AS far as the transmission goes, this is what the shifter looks like on a T5 And in this pic it's a T5 on the left (note the 3 piece housing) and a Nissan V71C on the right (note the 2 piece housing) It's pretty easy to tell a T5 apart from a Nissan trans. I can't recall what the rear end differences were. I had an 87 before, but it saw NA so none of that applied to mine. I do have a document detailing the engine differences if that's of any use to you. Hope this helped a little. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted September 19, 2010 Share Posted September 19, 2010 4/87 for the stronger turbo stuff, everything below it will have the t5 and an open diff. Quote Link to comment Share on other sites More sharing options...
reddzx Posted September 24, 2010 Share Posted September 24, 2010 (edited) I currently own a 4/87 build 87 turbo and a 10/86 build 87 turbo, also have owned 2 other 4/87 and 5/87 turbo's in the past. All manual trans 1987 model year turbo's have the 30A trans. They all have the same sway bars and axles. 4/87 and later cars have the CLSD and the W series engine along with the T-3 turbo. 88 turbo's started using the T-25 turbo and the 88-89 turbo 30A trans had a taller 5th gear ratio. Edited September 24, 2010 by reddzx Quote Link to comment Share on other sites More sharing options...
Mikez31ss Posted September 24, 2010 Share Posted September 24, 2010 I currently own a 4/87 build 87 turbo and a 10/86 build 87 turbo, also have owned 2 other 4/87 and 5/87 turbo's in the past. All manual trans 1987 model year turbo's have the 30A trans. They all have the same sway bars and axles. 4/87 and later cars have the CLSD and the W series engine along with the T-3 turbo. 88 turbo's started using the T-25 turbo and the 88-89 turbo 30A trans had a taller 5th gear ratio. What Tim said. Everything from 9/86 up had the 30a. Only 3 slight changes made to the 30a over the last three model years. You sir have a 30a. And a nice looking car. You should have made a trade with me instead of thinking about Steve's 260 Quote Link to comment Share on other sites More sharing options...
Pdfflyer Posted August 23, 2011 Share Posted August 23, 2011 Please refresh my memory. I have searched the archives and still have a question on the ECU Changes on Z31 Will an '85 ECU work on an '87 car ? Both are turbo cars with a 5 speed, without digital dash, and have original equipment as far as AFM, and factory equipment sensors. The ECU I am considering is an A18-636 654 which already has a JimWolf Tech upgrade for the injectors Will I have to change any other components under the hood ? to use the earlier ECU. I distinctly remember, the automatic ECU to be usable in a 5 speed car, although not preferred. Is there any other ECU Changes to be concerned about? Regards, and Thank you PDF Quote Link to comment Share on other sites More sharing options...
JSM Posted August 23, 2011 Share Posted August 23, 2011 Please refresh my memory. I have searched the archives and still have a question on the ECU Changes on Z31 Will an '85 ECU work on an '87 car ? Both are turbo cars with a 5 speed, without digital dash, and have original equipment as far as AFM, and factory equipment sensors. The ECU I am considering is an A18-636 654 which already has a JimWolf Tech upgrade for the injectors Will I have to change any other components under the hood ? to use the earlier ECU. I distinctly remember, the automatic ECU to be usable in a 5 speed car, although not preferred. Is there any other ECU Changes to be concerned about? Regards, and Thank you PDF 84-86 Turbo ECU use Low impediance injectors w/ 8 bit processors 87-89 Turbo ECU use High impediance injectors w/ 16 bit processors Quote Link to comment Share on other sites More sharing options...
88300zx Posted October 3, 2011 Share Posted October 3, 2011 Open up the ecu and locate the e-prom, if it has 28 pins, it is a newer ecu, if it has less than 28 pins it is a later ecu. If it is a newer one you will have to use dropping resitors, if it is not you won't. Quote Link to comment Share on other sites More sharing options...
reddzx Posted October 17, 2011 Share Posted October 17, 2011 ECU Model numbers Federal Turbo 5spd NMC/JECS 1984 23710-02P02/A18-617370 1984 23710-02P03/A18-635374 1985 23710-02P60/A18-635650 1985 23710-02P61/A18-636654 1986 23710-19P02/A18-654M30 1986 23710-19P03/A18-654M34 1987 23710-21P01/A18-680M90 88/89 23710-26P00/A18-A04M94 88/89 23710-26P01/A18-A04M46 AUTO TRANS NMC/JECS 1984 23710-02P12/A18-618371 1984 23710-02P13/A18-636375 1985 23710-02P70/A18-636651 1985 23710-02P71/A18-636655 1986 23710-19P12/A18-655M31 1986 23710-19P13/A18-655M35 1987 23710-21P11/A18-681M91 88/89 23710-26P10/A18-A05M95 88/89 23710-26P11/A18-A05M47 CALIF TURBO 5spd NMC/JECS 1984 23710-02P06/A18-619372 1984 23710-02P07/A18-637376 1985 23710-02P65/A18-637652 1985 23710-02P66/A18-637656 1986 23710-19P07/A18-656M32 1986 23710-19P08/A18-656M36 1987 23710-21P06/A18-682M92 88/89 23710-26P05/A18-A06M96 88/89 23710-26P06/A18-A06M48 AUTO TRANS NMC/JECS 1984 23710-02P16/A18-620373 1984 23710-02P17/A18-638377 1985 23710-02P75/A18-638653 1985 23710-02P76/A18-638657 1986 23710-19P17/A18-657M33 1986 23710-19P18/A18-657M37 1987 23710-21P16/A18-683M93 88/89 23710-26P15/A18-A07M97 88/89 23710-26P16/A18-A07M49 FEDERAL NONTURBO 5spd NMC/JECS 1984 23710-01P00/A18-613500 1984 23710-01P10/A18-631504 1985 23710-01P60/A18-631660 1985 23710-01P61/A18-631664 1986 23710-18P02/A18-650M20 1986 23710-18P03/A18-650M24 1987 23710-21P61/A18-676M80 88/89 23710-25P00/A18-A00M84 88/89 23710-25P01/A18-A00M42 AUTO TRANS NMC/JECS 1984 23710-01P10/A18-614501 1984 23710-01P11/A18-632505 1985 23710-01P70/A18-632661 1985 23710-01P71/A18-632665 1986 23710-18P12/A18-651M21 1986 23710-18P13/A18-651M25 1987 23710-21P71/A18-677M81 88/89 23710-25P10/A18-A01M85 88/89 23710-25P11/A18-A01M43 CALIF NONTURBO 5spd NMC/JECS 1984 23710-01P05/A18-615502 1984 23710-01P06/A18-633506 1985 23710-01P65/A18-633662 1985 23710-01P66/A18-633666 1986 23710-18P07/A18-652M22 1986 23710-18P08/A18-652M26 1987 23710-21P66/A18-678M82 88/89 23710-25P05/A18-A02M86 88/89 23710-25P06/A18-A02M44 AUTO TRANS NMC/JECS 1984 23710-01P15/A18-616503 1984 23710-01P16/A18-634667 1985 23710-01P75/A18-634683 1985 23710-01P76/A18-634667 1986 23710-18P17/A18-653M23 1986 23710-18P18/A18-653M27 1987 23710-21P76/A18-679M83 88/89 23710-25P15/A18-A03M87 88/89 23710-25P16/A18-A03M45 Quote Link to comment Share on other sites More sharing options...
RMarek Posted September 12, 2024 Share Posted September 12, 2024 I have a 300ZX an 86 My problem is when it gets to about 2000 RPM it goes into a limp mode. I have tried a lot of things don't know but I will get it running then all of a sudden it does it again. then I try the same thing as I did and it didn't work any help or suggestions thanks Quote Link to comment Share on other sites More sharing options...
