Wheeler Posted December 17, 2010 Share Posted December 17, 2010 I talked to Dave at Arizona Z cars about his 5 jug brake kit for the S30 Datsuns and he indicated that the kit pushed the wheels out "about .75 inch" further then stock. My question to him was what does he recommend for a rim size on an unflared Z, understandably he was pretty vague. Does anyone on this forum have experience with this kit, if so what rims (size) did you use? Any other thoughts or advice on these regarding proper rim size would be appreciated as well. Quote Link to comment Share on other sites More sharing options...
Rimal310 Posted December 17, 2010 Share Posted December 17, 2010 From my understanding, 0mm offest on an 8" wide rim sits pretty close the the fender. so if the kit will push the wheels out .75"(19.05mm) you would want to get an 8" with like a +20mm offset or maybe like a 7" wide rim with a 0mm offset or something...might be close to the fender. someone please verify or correct me if I'm wrong Quote Link to comment Share on other sites More sharing options...
zman21 Posted December 18, 2010 Share Posted December 18, 2010 If you now have the five lug setup, you have a lot more wheel designs to choose from compared to the 4 lugs. There are tons more options available. More people seem to be going with the larger wheels these days. 16", 17" & even some 18" tall rims on the older z cars. 17" seems to be a very popular rim size. As far as trying to calculate the rim width and offset that you need specific to your vehicle, you can go to www.bozeforged.com and check out the fitment guide to help you get all the proper measurements needed to fit a rim to your ride. According to the fitment guide located in Part 2, there are quite a few different measurements you will need to take to get the right fit. I hope this has helped you. Quote Link to comment Share on other sites More sharing options...
Wheeler Posted July 1, 2012 Author Share Posted July 1, 2012 Well, two years later I have the AZ five lug conversion kit installed (my car is still not running, but soon...) Anyone else have experience with what size rim works well with this kit? Any thoughts or experience would be helpful. Thanks Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted July 2, 2012 Share Posted July 2, 2012 Are you running coilovers or struts? Are you gonna stretch tires and roll the fenders? Rimal was right about the 0 offset on an 8 inch wide rim, and if it is about .75 inches that's +20 offset. But it depends on the questions above also, I've seen people fit a 9inch under the fender no problems slammed, cammbered and stretched. Don't know if that's the way you want to go. Quote Link to comment Share on other sites More sharing options...
Michael Posted July 2, 2012 Share Posted July 2, 2012 If I did the 5-lug swap (something that I'm contemplating right now), I'd love to run Weld 15"x10" Aluma-Stars in the rear, with something like 29.5"x11.5" drag slicks. But that will probably not clear the stock fender, the springs, or both. Quote Link to comment Share on other sites More sharing options...
rags Posted July 2, 2012 Share Posted July 2, 2012 (edited) 350Z wheels Edited July 2, 2012 by rags Quote Link to comment Share on other sites More sharing options...
Wheeler Posted July 10, 2012 Author Share Posted July 10, 2012 I have coilovers and the fenders are rolled. looking for a 16 inch rim, just not sure about offset. I can and will measure but would be nice to see what others have done and what works from experience Quote Link to comment Share on other sites More sharing options...
missinglink Posted July 11, 2012 Share Posted July 11, 2012 (edited) I have the same 5 lug kit and am running 17*9 inch rims with a +17 offset and 235 tyres. Coilovers. You can see from the pics that the front gaurds are flared, but the rims would fit with the std gaurd i think. Rims are aftermarket R32 GTR rims. Hope this helps... Edited July 11, 2012 by missinglink Quote Link to comment Share on other sites More sharing options...
Wheeler Posted February 18, 2013 Author Share Posted February 18, 2013 anyone else have actual rim / tires sizes used with the AZ 5 lug conversion? I measured today on my car and found I have about 2.875 from hub mounting face to the inner fender lip for clearance. I also looked up the section width for the tire that I want (225/50R16) which is 9.2 inches. So based on my math ((9.2/2)-2.875) = 1.7 inches of offset = 43mm of offset. This seems like way too much based on others experiences. The thing I did not factor was the negative camber gain as the suspension travels which would tip the tire in on top and buy some more clearance, which would allow a little less offset - but how much less (that would be hard to calculate)? For anyone else with this conversion, what size and offset rim did you use? Thanks Quote Link to comment Share on other sites More sharing options...
Never2BeFinished Posted March 28, 2013 Share Posted March 28, 2013 (edited) Im currently looking at AZC's standard front and rear brake kits (with 4 lugs), which i think has about 0 offset still. From my understanding,0mm offest on an 8" wide rim sits pretty close the the fender.so if the kit will push the wheels out .75"(19.05mm) you would want to get an 8" with like a +20mm offsetor maybe like a 7" wide rim with a 0mm offset or something...might be close to the fender.someone please verify or correct me if I'm wrong Rimal is right about the offset. I found a helpful website that can help you through comparing the stock s30 wheel size with the wheel(s) you're looking at. http://www.rimsntires.com/specs.jsp Be sure to click the wheel/tire size calculator/comparer link when the website comes up Edited March 28, 2013 by Never2BeFinished Quote Link to comment Share on other sites More sharing options...
Wheeler Posted June 12, 2013 Author Share Posted June 12, 2013 OK, to close this one out. I bought a set of 16x7 +40 rims with 225/50R16 tires and I am very happy with the fit. I think anything from +30 to +40 would fit nice with the AZC 5 lug conversion. Just need to figure out how to post a picture now.... Thanks for the help Quote Link to comment Share on other sites More sharing options...
