-72 240z 1UZ-FE/R154 conversion
ROVdriver
Have been alot at work recently, so there havent been much progress... I am just finishing the R230 install, had to modify the MM kit to make it fit properly. Have assembled the driveshaft and the cv-joints, and they fitted very well. I installed 280z stub-axels from MM to match up the rest... They took a while to get.....
  • 2 months later...
  • Replies 63
  • Created
  • Last Reply
Top Posters In This Topic
Thanks, Toyota powered, like this one.... Can you find 510's in Europe?
Yes, the 4-door and wagons were common cars here in the days, but theres not many left.... They were named 1300, 1600 and 1800. But the 2-door was not sold in Norway, maybe further south in Europe.
Think i have to find me a 2-door from US, and ship over to Norway. My Z is also a US car, the previous owner is Rayapp here at the forum:)
  • 2 months later...
  • 4 months later...
It's alive!!
After a couple of weeks working on wiring the whole car, we had the first startup a couple of days ago.
Just some tidying up in the wiring mess now, and fix some fuel leaks... Then I will install fenders and front and start testing/mapping.
The sound of the engine with all trottles fully open is AMAZING! :)
  • 3 weeks later...
  • 3 weeks later...
When you "joined" UZ and the r154 did you use a full bell housing like this " http://www.ebay.com/itm/1uz-1uzfe-toyota-Bellhousing-R150-R151-R154-gearbox-/280979269056?pt=Motors_Car_Truck_Parts_Accessories&hash=item416bab65c0&vxp=mtr "
or did you use an adapter plate? I am collecting parts for this swap now :) !!
I bought a full bell housing with flywheel ant clutch from http://www.dellowconversions.com.au/
Sweet!
1UZ's are crazy reliable. My SC400 has over 300K on the clock now, and doesn't burn a lick of oil. I just recently supercharged it too using the Lextreme "Fish" bracket.
What are you using for engine management?
I'm using Megasquirt MS1 Extra with MS relay board
