inline6 Posted February 20, 2011 Share Posted February 20, 2011 So, I'm spending a bunch on building a 3 liter bottom end. I bought a standard L28 crankshaft and had it sent off to Castillo's Crankshaft Service in CA to be worked on. Here is a pretty cool article in Turbo magazine about them and the work they do: http://www.turbomagazine.com/tech/0610turp_castillo_crankshaft_service/index.html I am having the crank offset ground, lightened, and balanced. I thought the note I got from them earlier this week was really interesting... The stroke on the stock crankshaft is not quite "stock". Read on: I read your info sheet to what you need on your nissan crank. Stock stroke is 79mm = 3.110, increase to 81mm = 3.188. I checked your crank with my stroke gage (Starret 0-5 inch travel). What it actually measures is: •#1 Rod 3.103 •#2 Rod 3.103 •#3 Rod 3.104 •#4 Rod 3.104 •#5 Rod 3.102 •#6 Rod 3.101 So, your lowest stroke is .009 short from 3.110=79mm. Your stock rod journal size is 1.967 std. Finish size for 3sgte rod is 1.8892/1.8898 from the Clevite book. So, actual difference is .078. That is exactly what I need to make the 81 mm stroke, but we are short on stroke from factory... Remember, the #6 rod is 3.101. So, if I add .063 to that, rough stroke is going to be 3.164: the .063 is the difference from stock journal size 1.967 to 1.904 which is .015" from finish size 1.889. I rough finish rod journals .015" oversize from finish spec, then I straighten the crank prior to final finish size because the crankshaft will bend upon stress relief. I might be able to get another .010" on stroke when finishing the journals... so it should be 3.174 stroke when finished. This will still be short .014" from 81mm = 3.188. So, I have read several posts here on hybridz.org indicating different amount that pistons stick up above deck (L28). Range has been .012" to .022" I think. Seems like if my crankshaft was off by .006" to .009" then we have found part of the problem. Variability of manufacturing tolerances is something I have known about - that it exists... but this hit home in a different way. I think center to center on the rods is likely to be more accurate to factory spec. than crankshaft grinding. Not sure what I base that on, just seems to mee like crank grinding wouldn't be as precise. Anyway, I thought I would pass this info along. Good thing I haven't ordered the pistons yet because the pin height (compression height) just changed. Quote Link to comment Share on other sites More sharing options...
260DET Posted February 20, 2011 Share Posted February 20, 2011 That is more variation than I would have thought was within factory tolerances. Perhaps the L cranks were made using equipment that is not as accurate as current equipment. Quote Link to comment Share on other sites More sharing options...
Tony D Posted February 20, 2011 Share Posted February 20, 2011 That's a production variance, for sure. This is one of those things you look for when building a performance engine. The closer you look, the more suprised you will be! Quote Link to comment Share on other sites More sharing options...
black240 Posted May 6, 2011 Share Posted May 6, 2011 oh boy... Quote Link to comment Share on other sites More sharing options...
Gollum Posted May 8, 2011 Share Posted May 8, 2011 (edited) And people make how much power on those wide production tolerances?! Obviously when building a motor closer and closer to the limits of intended purpose the more fine the detail comb needs to be, I just find it ironic how you can get super anal about certain things that WILL make a difference, yet it's always amazed me how much you can get away with not doing when you know WHAT you're doing. Edited May 8, 2011 by Gollum Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted May 8, 2011 Share Posted May 8, 2011 Maybe they short stroked cylinder 6 because they knew it ran the hottest. Quote Link to comment Share on other sites More sharing options...
