- Today
cant figure out steering clunk/pop
JMortensen replied to kaibiagi's topic in Brakes, Wheels, Suspension and Chassis
I just remembered a clunk I had, and turned out it was the big bolts that go through the steer knuckles and into the strut. Might check those and make sure they're tight while you're under there. -
kaibiagi replied to kaibiagi's topic in Brakes, Wheels, Suspension and Chassis
Gotcha, I'll try removing one end link tomorrow and see how that effects things. I've removed it before when I was replacing the bushings and there is no damage to the frame where it attachs, rust or rips. Not sure if its an aftermarket bar or not. For some reason I only have a front sway bar, no rear. As for the rag joint, I believe its been replaced with polyurethane by the previous owner. I'm not 100% sure its poly, but the rag joint is definitely in good condition just from looking at it. All good, im not too worried about that but I figured I might as well ask while im here. -
You can just remove one sway bar end link and then it will flop along and not be doing anything and shouldn't make any noise outside of maybe bushings squeaking. Easier than removing the whole thing. If it stops and you think it's around the bar/frame mount, pull it all the way off and inspect the frame rails where it bolts on. Aftermarket bars tended to rip up the frame rails when these things were new and not rusty. How about the rag joint in the steering column? OG rubber, or did you upgrade that one too? Sorry, can't help with wiring part. -
kaibiagi started following cant figure out steering clunk/pop
kaibiagi posted a topic in Brakes, Wheels, Suspension and Chassis
Hey everyone, just looking for some advice on this problem my cars been having. 1976 280z, the steering will make a pop/clunk noise when I turn either right or left. Sometimes I dont have to turn too much to get it to clunk, and sometimes I have to turn the wheel almost completely over. It will only do this when the car is moving, and only at low speeds as far as I can tell. (It totally might do it at high speeds but i havent turned the wheel enough for it to do so at high speeds). If I turn the steering wheel from lock to lock while the car is not moving, there are no problems and everything functions normally, no matter whether the front wheels are on the ground or in the air. I have already replaced front wheel bearings (NTN), outer tie rods (Moog), ball joints (Moog), sway bar bushings and end links (poly), tc rod bushing (rubber) all other bushings are poly and in good shape. I don't think its the inner tie rods because it only happens when the car is moving. I'm thinking maybe I could have somehow fucked things up on the swayer (although it looks fine), so I might try to take that off completely and see if that affects anything. The other thing i could see it being is a loose bolt or something somewhere causing this, because there have been many other things loose on my car causing me issues. Anyone got any other ideas/advice? It could totally be something obvious that I'm just overlooking somehow. Other random thing: does anyone know where this blue wire plugs into and what the fusible link looking things are for in this picture? They are under the driver side dash and I can't find where to plug them in. My dash lights don't work and I'm guessing this is probably why. Can't seem to figure it out by looking at the wiring diagram.IMG_8650.pdf Thanks for the help! repost since I accidentally posted in faqs -
I’ve been using Megasquirt 3x on my 3.2 for a while now . I had a knock sensor module installed on my X board . For some reason I can’t get it to work . I have a feeling there is a defect in the pin out during install . I’m not good enough to troubleshot bad install of a module and I’ve been reading about the usefulness of a cheap audio version that could made for 50$ . Background - I had to tear down my 3.2 because I had remove the crank to clean up the snout from a bad balancer . When I popped out #6 I found a broken top ring and evidence of detonation . Admittedly I was aggressive with timing and it bit me . There were no signs of the broken ring and the pulled 225 rwhp on the dyno . In fact that cylinder showed the highest CR = 220 psi This engine trans package is very noisy . I had straight cut gears and Kameari chain tensioner and a loud exhaust . I thought I heard ping around 4300 and attributed it to a rattling shifter - oops . # 6 was the only cylinder with any damage . I also pulled coolant from #6 at the head with a bypass to help mitigate problems . This time around I want to make sure this doesn’t happen again . I followed this you tube video. i was skeptical but it really works well. I drilled a hole above the freeze plug around 5&6 . Plenty of met there and there is a flat boss area for the sensor to sit flat against the block . You can hear the valve train clearly but you can also hear the ping clearly . I ended up pulling 4 degrees out of total timing on 93 octane . Megasquirt 3 allows for individual spark trim and I am going to try and isolate the issue to number 6 if that’s the case . Anyways - it’s not as good as real time retard available on ECU’s , but it is very effective to show some limits .
Hey everyone, just looking for some advice on this problem my cars been having. 1976 280z, the steering will make a pop/clunk noise when I turn either right or left. It will only do this when the car is moving, and only at low speeds as far as I can tell. (It totally might do it at high speeds but i havent turned the wheel enough for it to do so at high speeds). If I turn the steering wheel from lock to lock while the car is not moving, there are no problems and everything functions normally, no matter whether the front wheels are on the ground or in the air. I have already replaced front wheel bearings (NTN), outer tie rods (Moog), ball joints (Moog), sway bar bushings and end links (poly), tc rod bushing (rubber) all other bushings are poly and in good shape. I don't think its the inner tie rods because it only happens when the car is moving. I'm thinking maybe I could have somehow fucked things up on the swayer (although it looks fine), so I might try to take that off completely and see if that affects anything. The other thing i could see it being is a loose bolt or something somewhere causing this, because there have been many other things loose on my car causing me issues. Anyone got any other ideas/advice? It could totally be something obvious that I'm just overlooking somehow. Other random thing: does anyone know where this blue wire plugs into and what the fusible link looking things are for in this picture? They are under the driver side dash and I can't find where to plug them in. My dash lights don't work and I'm guessing this is probably why. Can't seem to figure it out by looking at the wiring diagram.IMG_8650.pdf Thanks for the help!
- Yesterday
Something tells me, "No input file specified. " Thank you deja for posting the diagram.
- Last week
TrumpetRhapsody started following Gollum
BREAKING NEWS: We have started. Redid all my injector wiring, even though it mostly looked fine, I think a few of my crimps were bad on the signal side, causing them not to fire. Did an extra nice job, and all was well. Still wouldn't start. Decided to rotate back to TDC. Turns out, the last time I set to TDC, I thought my dizzy rotor was 180 off, so I rotated the shaft 180. It was correct where it was the first time, so I actually made it 180 degrees off. Just moved my plugs and it started right up. Can't work on it however, as my oil pump gasket gave out, I think I overtightened the pump. Of course something else happens and I can't tune it today. Oh well, at least it starts now. Will take this as an opportunity to turn my shaft to the correct orientation when the gasket arrives tomorrow. Thanks for the help NewZed, you were right, exhaust stroke, not compression. Will post in my build thread over in the L6 forum when I get the timing dialed in tomorrow. Excited to hear the turbo.
TR's 260z L28 Build Thread
Bringing this back from the dead! After my dyno session where you could see significant blow-by coming from the valve cover, the car progressively started producing blue smoke from the exhaust. I don't recall the exact timeline now, but around mid-2016 Flatblack helped me pull and disassemble the engine. We discovered two pistons with broken skirts, and one piston with broken ringlands. My head gasket was also hanging on by a thread, with very elongated bores. Since then other life priorities took precedence, and the car was basically untouched for 7 years. Mid 2023 I finally took the car in for paint, and got it back in October. Meanwhile I had the block cleaned up, found some used pistons, performed the coolant bypass mod on my P90 head, did the 240z tail light conversation, and last month finished reassembling the longblock. Sometime between 2013 and 2016 Flatblack sold his 280z, so we traded flywheel and clutch setups so I'd have more torque headroom. At some point his flywheel dowels went missing, so I'm waiting on replacements to get the engine stabbed back in and broken in over the next few weeks. Once I have everything complete, I'll post some reveal pictures of the new look! Short term I need to get a rollbar, some performance seats, and harnesses put in the car. I'll also need to get my MS2/Extra upgraded to the latest version, and apparently be a little more conservative with my tune. From there, I'll likely pursue installing the Snow Performance meth kit I've been sitting on for a decade, follow-through with the 280zx CV swap with the weld on adapters, upgrade injectors and swap to running E85, and look at swapping to a properly sized modern turbo to support my original 400whp goal. -
Velek started following Transmission body mount
I have a 260Z that I'm returning to stock, but the previous owner who was swapping a 350 into it cut the transmission body mounts off. It looks like a pretty simple part to copy if I could get the dimensions. I was hoping someone could help me with the measurements.
04-24-2024 UPDATE: Ok, so I went out to tighten up the valves, get rid of the looseness and get things "right" in the engine. Mission accomplished! The crows foot wrenches I bought do not work with the torque wrench, there isn't enough room, so I decided to tighten them by the Armstrong, "oougha dooga" method. Engine started up and runs great, purrs like a kitten! I then decided to Leak Test my gas tank, 99% good, the seam on the tank stated leaking...I got some JB Weld Steel-Stick and put it on the seam to stop the leak. I may have to put just a bit more on there, but the majority of the leak is gone. Thank goodness! I added some roll bar foam to the rollbar where my head rests, and I also have the crucifix I bought on my deployment to Afghanistan back in 2009 hanging from the rear view mirror now also. I also got it out and drove it just a little bit, it's so nice to have it running better and better every day. The rear drums are working well, but the e brake has to be pulled up high to work, so it's either adjust the handle form underneath, or replace the cable as it is stretched. 2 Videos are avaialble to watch if you desire. Click on "facebook" below for each video. Cheers! To watch videos, click on Facbook below for each video. (7) Facebook (7) Facebook
TrumpetRhapsody started following L28 Flywheel and Clutch Interchange
TrumpetRhapsody started following FlatBlack
Have you checked each injector's circuit? Power supply and continuity back to the MS board? If you have power supply and connection on the grounding side on all injectors at the board then your thought that the board is messed up is probably right. You probably know this but the injectors spray when the computer supplies a ground to the injector circuit. Voltage is always present at the injectors when the key is on, but they only spray when the circuit is grounded and current flows through the injector solenoid. There are several ways to check the circuit. At least you're making progress. p.s. the engine still should have started, then died, with ether. You might still have a problem after fixing the injector situation. One problem at a time though...
OK, here's some good new information. When turning the key to ON, Megasquirt primes the system, and is supposed to do a single injector spray. NONE of the injectors squirt when they key goes to on. When cranking, ONLY injectors 5 & 6 spray, like I thought. This extremely lean situation would explain the engine wanting to backfire out of the intake here and there with ether and barely wanting to still even start on ether.
Attached is a pic of the header I chopped up and made into a turbo inlet exhaust pipe. Could the bend be enough of a “blockage?”. I would assume the exhaust would find anywhere to escape, but I’m not sure about pressure and things like that. I can double check the whole system as well. Also, I have my vacuum block attached to a T fitting which goes to the brake booster and the vacuum port the booster was on. This block supplies my map vacuum the is internal to the megasquirt. Is this acceptable, or should they be separate? When I used starting fluid the other day, I feel like the car was wanting to backfire out of the intake. I popped out of the exhaust, but a time or two out of the intake. Either I used too much or maybe the bend in my inlet exhaust piping is messing things up. That to me seems like a pressure issue. I’m only 19, so I apologize for my constant questioning and unknowingness. I thank you again for the help. I love doing this and making this car my own. I’m glad I can save a car like this, I’m just frustrated how a weekend project turns into 5 weeks.
p.s. forgot one of the other big EFI problems that often catch people - intake system air leaks. Leans out the mixture and also kills the sensor signal to the computer. The computer adds fuel based on the air flow it is told is happening. Might even be a bad MAP signal. Signaling no air, meaning 'no fuel necessary". Or a shorted temperature sensor showing a hot engine, which also means less fuel needed. I'd go through the whole cold start sequence and look at what the computer needs to know. Make sure it's getting good information.
I would try starting fluid again. It's not satisfying as far as puzzle-solving, it feels like cheating, but it really will tell you if the spark is happening at the correct time, and the intake system is open. If you have a remote starter and a can of starting fluid you should be able to run the engine for minutes all by yourself. On a cold engine it's not a big deal, it won't hurt it. On a warm one you can get some detonation so don't overdo it. Beside that, don't overlook the exhaust side. Any chance the exhaust system is blocked? The air has to be able to flow all the way through. You said all you did was install a turbo. Turbo is part of exhaust.
happystang joined the community
I will check again, but the last 2 times I set the engine to TDC, I made sure it was compression stroke. With the transistor problem I had, and hearing stories from DIYAuto about Godzilla Raceworks poor installation of megasquirt upgrades, I'm tempted to chalk this up as a failure on their part again. I know I can't just keep blaming the program, as it could be an engine issue, but megasquirt shouldn't be this hard to get running. There is too much information that I've scoured and read up on for it to be this difficult. I don't understand how I can have the injectors clicking in test mode but broken when cranking unless GRW messed the fuel/ignition circuit installing the jumpers for the single coil drive. I appreciate the help NewZed, you are very knowledgeable. I will continue to tinker and recheck the basics, but this is getting on almost 5 weeks for this install. I'm half tempted to just buy a whole new ecu from DIYAutotune who has proven themselves, but that is banking ~$600 on the fact that it is a computer issue.
I have an RB swapped Z that I'm attempting to put a Vintage air kit in. The RB has a Calsonic compressor, model number 92600 10y00. I need the peanut fittings on the compressor w/ crimpable or threaded fittings so that I can connect them to the Vintage air AC lines. Does anyone know if Calsonic and Denso compressors use the same fittings. Is there an online shop somewhere that sells a bunch of AC stuff that might have something like this? I contacted vintage air, but they were no help.
Here's a basic that often catches people - maybe you have the ignition timing set to the exhaust stroke. The flash of your timing light. The timing mark on the damper pulley passes the pointer twice - once on compression and once on exhaust.
Pulling the spark plugs this morning, All look brand new, meaning no fouling or burning. I put them back in, pulled the plug wires, and cranked the engine a few times. When pulling them back out, none looked super wet, if wet at all, and only spark plugs for cylinders 5 & 6 smelled like gas. I then went into tuner studio and tested each injector, and I could hear all of them clicking. Weird. 2024-04-23_10.55.30.mlg
Thanks, i'll look in to that. Christian
Hi HybridZ universe! Been taking a break from the car for a bit, but starting to get more motivated here. Let's do our quick catch up first. ORP was an interesting event. We had positives, but the issue that wrecked the car in July surfaced it's head again. Turns out the ABS was overpowering the master cylinder seals on the front circuit and causing massive pressure losses. I had more pronounced but less consequential failure out there, but had good data to show what was wrong. I got my hands on some Tilton Type 79 master cylinders, developed specifically for the Audi LeMans teams who were seeing a similar failure in their master cylinders. I also had to upgrade the pedal box as these are bearing mount master cylinders. The plan was to run the car again at PIR, but that event ended up getting canceled, and so the car has sat since September. Slowly getting poked at, and trying to figure out where I wanted things to go. I made some aero mods to the fenders, and have been slowly cleaning up the firewall and some other areas. The big change I'm in the middle of here is with my ECU. I'm ditching the megasquirt and going Haltech. The LS never really ran right on the megasquirt, and when I started seeing some odd stuff starting it up for the first time this year, that was all the impetus I needed to ditch that. It'll be for sale shortly, expect to see it soon. Hoping to get to an event this year with the car, but really not sure when or where. For now, here's where we sit. I put it down on the ground for the first time since August last year.
If you have spark and timing is right it should start on starting fluid and run for a second. Not just a sputter but a solid burst of RPM. Any chance you left a rag in the intake tract? Could there be a blockage somewhere? Are you using a MAP sensor? Have you had a spark plug out and rechecked it? Maybe you're adding too much fuel and gas-fouling the plugs. Those are big injectors. Just some ideas. Get back to the primitive aspects of the engine. Fuel, air, spark.
Yeah, no problem. Ran awesome 3 weeks ago on the stock harness. I added the turbo, 82 zx dizzy, 370cc injectors, new plugs, and megasquirt. I kept the same ignition coil. I did no work internally on the engine. I only removed and replaced surrounding components. I find it weird I'm having so many issues trying to start it. It had no issues whatsoever. That's why I'm so focused on it being my settings for megasquirt. I have rpm signal in tunerstudio, so I'm certain my dizzy install is good. And I also have the CAS trigger wheel to clear signal up. I tested the injectors, and those are all squirting. New plugs are ngk and were marked as gapped for my Z, but I should check those to make sure. Anyone have Chickenman's email? I tried to pm him on here, but he hasn't been on.
It might help to describe more about the engine itself. When did it last run? Have you done any work on the engine? Your focus is on the MS system but maybe it should be on the engine.
Who's Online 2 Members, 0 Anonymous, 260 Guests (See full list)
