Leaderboard
Popular Content
Showing content with the highest reputation on 09/30/25 in all areas
  1. Wow, that's like something out of a Rube Goldberg cartoon! Great progress you're making....keep the updates coming!! 👍
    1 point
  2. I like the external slave cylinder. You may have to clearance the driveshaft tunnel a bit, and it will create another obstacle to routing headers. I'm using a Tilton hydraulic throw-out bearing. Works great and doesn't take up space in the driveshaft tunnel. The downside is that if it leaks then you have to remove the transmission to fix it...
    1 point
  3. Got a few goodies today, first I found a cool bracket that can allow me to use a hydraulic set up for the clutch, it’ll let me get rid of the weird mechanical set up someone rigged up. Second was an impulse buy, while getting the turn signal/light switch and relay they had this emergency power stop button and solenoid.
    1 point
  4. More work on the 4200 today. cleaned up the rest of the block and head, and then pulled the oil pan and cam cover. NO SLUDGE. very clean inside. I got the outside of the cam cover clean enough to at least get started on the modifications I will do to it (add an alloy oil fill to the back, add a breather port, shave off 2 original ports, cut off unnecessary brackets, weld up the original oil fill hole and probably lower it a bit as it is very tall . To fit under a Z car hood it has to be chopped about an inch......although a small rectangular hole in the hood with the polished cover sticking up can be made to look really cool. Yeah I had an adaptor snap on me, the crank bolt is SO tight, I will probably need heat and PB blaster and smack it a few times to shock the treads to get it off. I need to clean behind it and it needs to be cleaned up and painted.......I wonder if the heat will ruin it? Before I called it a day, my AR5 transmission arrived.....in need of a rebuild, the pilot shaft has wiggle room. pics follow:
    1 point
