Leaderboard
Popular Content
Showing content with the highest reputation on 06/08/26 in all areas
Thanks for asking. It was equipped with a full cage and harnesses but after taking all of that out, I am going back to a "comfortable sporty". I am too tall to be in a full cage equipped car safely (don't wear a helmet all the time). The seals on the rear are so bad I feel like I am slowly dying even after 10min of driving. I am replacing the rear light and deck seals. Cleaning all the switches and electrical, replacing the interior and getting the heater controls working. I would like to drive it this summer to a few Datsun meets and then tear down the carburetors and front end for rebuilds this winter.2 points
Was not implying that the only way to get work done on a project is to not have a wife and daughter!!! I can see how that could have come across. Mine is 14 and will be a freshman this year. Ive got 4 years..... Then who knows. As she has gotten older I've been telling the stories of her helping me in the shop when she was little. Her stepping into a drain pan full of oil in ugg boots that I promptly threw away with out telling mom, Me hearing a pppsshhhh noise and I turn around to see her with a my blow torch pointed at her face, Praise the Lord she didnt click the igniter She would have been around 2 also at those times.2 points
I also finished cutting the new Tar paper that will go on the interior floors and trans tunnel. I have a laser cutter at work. This is a Nissan part and still available as blank sheets. Unfortunately, even though it is correct, it is expensive at $100.00 USD per sheet. It took 6 sheets for the entire interior. This is the material on the laser After the metal is ready, I will epoxy coat it first then apply the sheets. Unlike OEM that had bare metal under it, this should be substantially better at keeping water from getting under it and rusting the metal1 point
Another productive weekend. Unlike my Turbo chassis that has a late 71 build date, this car having a mid year build date has protection plates over the seat belt pockets. But of course they were used by the PO to jack the car and dented them up. I drilled out the spot welds and removed them, allowing me to straighten the dents and blast underneath them. Before: After: All sprayed with weld thru primer and ready for plug welding back on.1 point
1 point
It's been a while. I moved from NC back to OH for work. My tools and vehicles have been locked up in a storage unit while we are in the process of buying a home. I took the car back to my parents' carport to try to get some work done. However, there were a lot of little things to do. There is a fuel smell on refills, exhaust fumes leak into the cabin, the carbs need tuning, and my shitty rust repair needs some work. Because there was so much to do, it made sense to me to pull the engine. Since I was pulling the engine, it made sense to me to just swap in an RB25. So I pulled the RB from the parts car, pulled the L24, and started fixing all my previous work. My welding has gotten a lot better, but it still has a long way to go. The thicker sway bar and improved suspension was tearing the frame rails apart where the sway bar attaches. So I drilled and tapped some thicker steel and 3/4 boxed the frame rails to try to prevent the same damage in the future. I scuffed up the engine bay, threw some primer at it, and painted it the same white as the rest of the car. I also pulled the dash, stripped the paint, put on some rust preventative paint, and added sound deadening. Next steps: I need to drop out the stock rear end and get an R-200 with an LSD in it. I have a new universal harness to go in it and new gauges in a crack-free dash. I need to figure out what brakes I want to upgrade to. I also need to figure out if I'm going to reuse or replace all the brake lines, fuel lines, and gas tank. I also need to chose what ECu I want to use. Right now, I'm leaning towards a Haltech Elite 1500. Finally, I need to rebuild the RB25 with the oiling upgrades and get it and the RB25 transmission thrown back in the car. I'm spending more hours at work in my new role, but I'll try to post updates. Photos-3-001.zip1 point
Thanks for the replies and comments. Time is always an issue, however Im at the age now where my daughter is 26 years old and working full time. Been married 30 years so the wife is obviously understanding of my hobbies. Hopefully continuing to make progress regularily. Hoping more people come back to the forum and participate in the community. Here is a picture of me and my daughter when she was probably 2ish years old, same car Im working on now. I need to get her back in the shop for a new photo - Time flies1 point
Nice, what are your plans. Get her up and running, full restoration, something else?1 point
1 point
