DaEvil
Everything posted by DaEvil
  1. LOL I saw that too.... I think he is confussed a little
  2. you need to fill the blocks with concrete and off site them some short pieces of steel would also help
  3. did you get the out put shafts with it ? They are special for the VLSD
  4. I had an Automatic in my Z but its nothing like the 6 speed . I had both 3.54 and 3.70 I prefer the 3.70 it make 6th more usable. A sports car just don't seem right with an Automatic IMHO
  5. How much HP are you looking at,whats the car going to be used for and how much money are you going to spend = rearend
  6. try Vintage Air Conditioning......Do a search for it here also
  7. DaEvil
    Spooky
    MAKE SURE YOU READ THE STORY FIRST THEN WATCH THE VIDEO Strange but interesting. This is a car advertisement from Great Britain When they finished filming the ad, the film editor noticed something moving along the side of the car, like a ghostly white mist. The ad was never put on TV because of the unexplained ghostly phenomenon. Watch the front end of the car as it clears the trees in the middle of the screen and you'll see the white mist crossing in front of the car, then following it along the road. If you listen close, you will also notice a strange sound (so turn on your speakers). Spooky! Is it a ghost, or is it simply mist? Or did you miss it altogether? You decide.
  8. They is no question in my mind after having both motors the LS1 is far superior over the SBC
  9. Hey here is the link http://cgi.ebay.com/ebaymotors/R200-4-375-Gear-Pinion-NOS-Datsun-240z-280z-280zx-510_W0QQitemZ8004607148QQcategoryZ33731QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  10. I just saw on ebay a ring and pinion set for a r200 it was 430 something I'll try and find the link
  11. I was looking on Ebay and saw this HybridZ And wondered whos it is ? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4575196716&fromMakeTrack=true
  12. good job !! You thought starting your V8z was a rush ... Wait till you drive it for the first time Enjoy
  13. it can get a little confusing. First you said you got a R 200 from a Q45 from the JY did it come with the output shafts ? You will need them and that would also determine if you are going to need 5 or 6 bolts flanges. It is a VLSD correct ?
  14. DaEvil
    T 56 Question
    I found the info on LS1tech. Its 17 teeth .
  15. Can someone give me the tooth count on the exciter gear. I'm tring to calibrate the cable X thing Thanks
  16. DaEvil
    Q45 Vlsd!
    I just did the swap in my 75 Z I put a VLSD (the guts) from a 96 300z I think. I used the vlsd out put shafts ,made my own adapters and cut and resplined my axles http://forums.hybridz.org/showthread.php?t=103221&highlight=resplined
  17. Pleasanton stoneridge mail the Z get together
  18. It settled down now I'm just doing some final adjustments and then a ride around the block. Are you going to P-town tomorrow ?
  19. here are 2 more pics I hope that helps
  20. Well It fired up last nite , I don't think it turnned of one time and it was running. I was late and dark so I shut it down . I have to go do a quick job then I'm back to check it over and then a drive. It seemed to idle faster then it should anyone have any ideas ?
  21. NO they never got hot enough to where they lost their hardness
  22. Yes I cut each one LOL and used carbite cutters because of the hardness
  23. I'll take some pics tomorrow and maybe that will answer some of your questions. I used grade 8 bolts no studs
  24. yes its easy , I used my old ring gear just unbolted it. I had to make small bushings or spacers the old bolts were 10mm and the new onds were 12mm when i bolted it up to the new unit
  25. Cool Dale,:2thumbs: I am right behind you !! I got what you got left plus run my fuel line. Then keep my fingers crossed and see if it fires
