9
Everything posted by Michael
The causes of the Z’s aerodynamics problems (lift, high drag) are multiple and in my considered opinion, can not be entirely “fixed” unless you are willing to undertake extensive sheet metal modifications. In the front, the the g-nose does help somewhat, but its curvature was designed more for aesthetics than function. Your idea of smoothing underbody flow is conceptually a good one, but keep in mind that proper design of venturi-type ducts requires consideration of pressure recovery, crossflow inside the duct, entrance and exit conditions, transient effects, .... It can be done, but you need to think of the entire vehicle configuration – and that’s best done with a clean-sheet-of-paper design. I recommend following the original BRE-type approach: urethane air dam in the front, small upswept spoiler in the rear. Each sells for around $100 (for example, at Motorsport). Those two pieces are the 70% solution for street-driving purposes. For all-out racing, the modifications will be driven more by class rules than by optimal performance. For getting better steering feel in “exciting” street driving, seriously consider those two parts.
Alternative discussion: when the exhaust valve is fully open, the static pressure just downstream of the valve is some number larger than atmospheric pressure. At the exit of the exhaust pipe, the static pressure is atmospheric. The difference between the two numbers is the back pressure. That difference results from restrictions and friction losses in the cylinder head exhaust port, the headers, the exhaust pipe, muffler, etc. The issue of whether “some small amount of back pressure actually helps low-end torque” keeps going back and forth. David Vizard makes a convincing argument in his books that zero back pressure is the best back pressure. What helps low end torque is exhaust scavenging (pressure pulses in certain portions of the exhaust system dynamically assisting the emptying of some cylinders) – something that’s lacking in open headers. In other words, an exhaust tract with zero backpressure also has zero opportunity for exhaust scavenging, so tolerating some back pressure is a necessary evil in order to allow for exhaust scavenging.
I think that the best reasons that one may wish to deviate from the JTR mounting scheme are (1) to obtain even further engine setback, and (2) to mount the engine directly to the frame rails, rather than to the steering crossmember. The latter is especially useful if you plan to frequently mess with the front suspension, where you would no longer have to worry about the engine mounts if you remove the steering crossmember. As for further setback, well, some situations may not necessarily benefit, others could use all the rear weight bias they can get; for example, if the engine front accessories can’t clear the steering rack. If you’re willing to dent/cut/reshape the firewall to accommodate further setback, welding doubler plates to the frame rails and then welding mount bosses to the doubler plates is a natural solution. In my case, the setback is especially aggressive, and the mounts sit approximately at the location of the tension/compression rod inboard ends – that is, locations where the frame rails are already reinforced.
Johnc, Regarding my earlier post - the idea was that since engine power to displacement ratio decreases rather strongly with increasing engine size, the larger engines appear to be less “efficient”. In going towards larger displacement, engine power to weight ratio generally also decreases, but much more gradually. So when comparing power to displacement, the smaller engines look tremendously better, but when comparing power to engine weight, the smaller engines look only marginally better, and in some cases (such as for older cast-iron inline engines in compact sedans, vs. cast-iron V8s of the same era) no better at all. Since the car itself doesn’t care about engine displacement – it only cares about engine weight, support accessories’ weight, and hood space – one has to wonder why power-to-displacement has become the standard metric of efficiency. And of course these various comparisons are apples-to-oranges, because given the trends in manufacturers’ philosophies, the smaller engines will have technical innovation on their side. In the typical modern OEM street application where accessories such as air conditioning and power steering have come to be considered essential, the larger displacement engines have an additional advantage: big engines do have bigger and heavier accessories, but not by much. The starter, alternator, water pump etc. in my 454 aren’t much bigger than the corresponding stuff for the 2.2L L4 in my 1974 Toyota Corona, just to give one particular example. So the difference between “bare” and “fully dressed” – for the larger engines – is less that it is for the smaller ones. Wringing out high hp numbers from a small-displacement engine is impressive, but not necessarily meaningful, for street applications. I wish that OEMs such as Toyota and Honda would apply their prodigious engineering resources to design large-displacement, low-rpm, thinwall-casting aluminum V-block (not necessarily V8) engines. But that just won't happen, because such an approach would contradict these manufacturers design culture.
I’m with Petew and Drax240z: the lens is the heart of any camera (well, maybe not pinhole cameras), and a point and shoot can’t compare to an SLR. Lens interchangeability, through-the-lens metering and through-the-lens viewing (especially important for close-focus photography), provision for remote flash, depth of field preview (very useful for technical photography, such as documenting Z construction1),.... But digital SLRs are still too expensive. In the 35mm film world, you can get a decent SLR body and a single-focal length 50mm or 35mm lens for around $400 from one of the mail order stores based in New York City (look in magazines such as Popular Photography). But digital SLRs are still $1500+, from what I've seen. My experience with film point and shoots was that the single-focal length cameras are superior, such as the Yashica T4 or the Olympus Stylus Epic. The Epic has a max aperture of 1:2.8 – very nice! P&S zooms run into severe problems at the longer focal lengths – principally, very small aperture, and all sorts of aberrations. I have not, however, been able to find any single-focal length digital P&S cameras (I mean NO optical zoom at all). The other problem with most digital cameras is “latency” – press the shutter button, and the camera fires after a delay, instead of “almost immediately” (in my Nikon N90s, it’s something like 40 milliseconds, if I recall correctly; maybe even less). That makes it difficult to shoot action shots, or to shoot in low-light situations, where you relax your stance after you think that the shot is over, and allow the camera to move – but it hasn’t taken the picture yet, so the result is blurry.
This brings up an interesting point: we typically compare engine efficiency in terms of power produced vs. cylinder volume displaced, or overall vehicle efficiency in terms of miles per gallon. But we know that vehicle acceleration depends mainly on power to weight ratio, and that for performance cars, a large part of overall vehicle weight is the engine and its supporting systems. So why don’t we normally compare engines in terms of power to engine weight? Large-displacement engines are not necessarily very heavy, while small-displacement engines aren’t necessarily light. Broadly speaking, you get more cubic inches per pound, so to speak, from a huge V8 than from a tiny L4. A 400 cubic inch engine probably won’t be 4 times heavier than a 100 cubic inch engine – in fact, the ratio may be closer to 2:1. So in terms of engine power to weight ratio, that lumbering low-tech cast-iron V8 doesn’t look so bad any more. I’m baffled by the concept of taxing displacement in addition to (or instead of) taxing fuel. Is a temperamental, high-revving small-displacement engine – making 20 mpg in vehicle XYZ – any more environmentally friendly than an engine in a lower state of tune, that displaces another liter or two, but weighs the same and gets the same mpg? Taxing displacement drives manufacturers to more complex designs, raising costs and reducing reliability. I wonder how things would have been different if Toyota and Honda built cast-iron, pushrod V8’s with 4500 rpm redlines. Those things would run for maybe 2 million miles, and go 100,000 miles between oil changes.
I overlooked in the above post.... replace the missing side of the box with a diagonal tube....
A surface panel is not necessarily acting as a shear web. Consider again the box (cube) example: remove one of the six sides, and the formerly stiff box is now weak in torsion. Katman, I have no experience designing competative race cars, but I've had the opportunity to dabble a little in airplane design here and there ... just a little. Monocoque structures are always reinforced with judicious selection of stringers, ribs and bulkheads. A stress-bearing skin and a tube structure underneath are complementary partners; they do not obviate one another. It is unfortunate that in most amateur automotive racing classes, and many pro classes, the "body" is just a shell, carrying aerodynamic loads but not suspension or drivetrain loads. If, in a street-type car, the "body" is the stock metal unibody, then indeed the resulting "tube frame" chassis will probably weigh more than the original OEM product ... all else being equal etc. etc. But more careful design practice allows one to lighten the unibody while compensating for strength with tubes. Assuming that intrusion of the tubes into the cabin is acceptable. Regardless, let's not argue about what's a monocoque chassis.
i need your guy's advice: i need to toast a turbo supra
Michael replied to a topic in Miscellaneous Tech
I used to have a '87 MKIII turbo Supra. Yes, they do weigh around 3600 lbs, and yes, they are pigs. I took it to Pomona Raceway once. My time was 15.9 @ 86, but by that time the turbo boost was down to around 5 psi, maybe slightly less. And did I mention that these cars are unreliable, especially considering Toyota's overall reliability? Head gasket blew at 89K miles, was showing signs of incipient failure again at 115K miles, at which point I sold it. The Supra was trying to be both a luxury coupe and a sports car; it largely failed at both. -
Spiirit, Are you planning on a big block for your Z? Hmm..., that would bring the BBC total on this list to around a half dozen - perhaps time for an additional forum?
Speaking of revolutionizing the industry – why don’t cam manufacturers alter their present practice, and start grinding the cam dot 180 degrees away from its current position?
Corvette Suspension: Is it worth it?
Michael replied to silicone boy's topic in Brakes, Wheels, Suspension and Chassis
Well, one reason for mixing Corvette suspension components with Z sheet metal – instead of just modifying the Corvette itself – is the same as the reason for swapping a Chevy engine into a Z in the first place: you choose the best aspects of two entirely different vehicles, and build a combination vehicle – a.k.a. a hybrid – that is superior to both. That said, I am not impressed with the C4 suspension design, nor do I believe that a ladder frame designed to accept C4 front and rear suspension, plus the Z unibody, plus a roll cage, plus all the tabs and gussets and protuberances necessary to hold everything together, will weigh less than a Z unibody with aftermarket bolt in-type suspension components and a tube frame integrated into the unibody, without the ladder bar frame underneath. So even with “unlimited resources” I personally would not prefer grafting in a complete Corvette suspension. What I do daydream about is a true custom suspension, double A-arm on all four corners, with a Ford 9” differential, wrapped in custom body panels. -
no no no, you guys have completely missed the original point… dark is faster than light (proof: open a desk drawer slowly; first its interior is dark, but eventually it gets lighter, until finally you can see the contents; therefore, dark is faster than light). So the dark car will be faster than the light car. Also, if you use a supercarburetor with cold fusion, you will get 250 mpg and the exhaust will consist of pure water. A further modification, especially common in the Southeast, features a special exhaust catalyst that converts the exhaust water into alcohol, which can be plumbed back into the cabin, assisting the driver. But keep in mind that the 250 mpg figure is for the black car. The white car will only get maybe 240 mpg, unless more exhaust is diverted into the cabin.
An idealization of a unibody car is a box, closed on all sides but hollow inside. Provided that every side of the box is closed, and loads are only applied at edges and corners, the structure is pretty stiff. But the advantage of the tube frame is that (1) now the box can have diagonals inside it, and (2) tubes can be placed strategically in anticipation of where the loads are applied, and what sort of loads they are. With that in mind, you can hack away metal that used to form the sides of the box, and still retain the same or greater strength. If the metal hacked away weighs more than the tubes that you added, the resulting structure of course weighs less – and vice versa. In practice, the tube frame causes additional weight gain when trying to integrate the tubes with the unibody. Things like 6”x6” steel pads welded to the sheet metal, where tubes terminate – they’re pretty heavy. Also, the decision of where to remove sheet metal from the stock unibody is difficult. Cut away the wrong unibody components, and the structure can become severely compromised. And no one wants to cut the sheet metal forming the car’s exterior. Then there’s the issue of how to mount stock components, such as dashboards, for which the unibody has integrated mounts, but which a tube frame won’t. Make additional mounts = pick up more weight. So I agree with Katman in the comparison of unibody vs. tube frame for true “stock” comfort and features. But if we change the perspective and instead compare street/strip cars or casual racers, or cars with severe modifications in other areas (such as engine swaps requiring custom mounts), the tube frame wins. The more radical the car, the bigger the tube frame’s advantage. Regarding the NASCAR cars – over and over again I hear that those chasses aren’t nearly as stiff as they appear to be. Safety is the primary design goal, not stiffness. Nor are those frames light; 3400 lbs for a car with a small block, gutted interior and plastic/composite body panels sounds like an awful lot!
Once you remove everything from the shell, it’s difficult to stick to the plan of full reassembly. The desire to save weight by leaving out “unnecessary” components, to leave exposed areas of sheet metal where additional attention to fighting rust is required, or to make room for roll cage attachment points, will conspire to turn a once-stripped car into a permanently-stripped car. It becomes a race car, or a race car-wannabe. 20 years... what can I say? That has become a life’s labor.
Comparing what’s currently available commercially, Milwaukee is the brand to beat. Milwaukee is currently updating their product line. Stores such as Home Depot have them on clearance sale. A few weeks ago I bought a 8.5 Amp quick-change model for $50.
Question for Chassis Gurus
Michael replied to Scottie-GNZ's topic in Brakes, Wheels, Suspension and Chassis
I have a similar mod to my radiator support on my ’78 280Z. The lower crossmember remains, but the rest of the radiator support was removed with a sawsall and the spot-welded guts were ground away from the inner fenders. A 3/4" tube with clevices on each end supports the radiator and electric fan on top, while down below a similar tube is welded to the frame rails, supporting the bottom of the radiator and reinforcing the front sway bar mounting locations. The lower tube is also braced to the stock lower crossmember. The upper tube’s clevices connect to tabs welded to reinforcement pads, themselves welded to the inner fender sheet metal. There’s a strut tower crossbar and diagonals from the top of the strut towers going back through the firewall, meeting at a dash bar. Also, I cut away the heavy-gauge reinforcements used on the 280Z to support the front bumper struts. While the weight savings claimed from bumper surgery is, in my view, somewhat exaggerated, removing the aforementioned metal saved about 5 pounds. I second what was said regarding the sheet metal forward of the strut tower and sway bar mount. It’s not important, if the strut towers are themselves adequately braced, and the sway bar mounting hard point is not compromised. Of course, front-end collision crash protection suffers, but that’s probably not your primary concern. Rigorous assessment of whether cutting sheet metal forward of strut towers is entirely harmless would require some controlled loading/deflection test. Has anyone done this? Short of that, my brief experiences driving the car showed no steering deadband, front end vibration/looseness or rattles. -
The 454 big block formerly in my Z (and for the past 18 months on an engine stand!) came with small oval port heads; it’s from a 1978 Suburban. In an effort to decide whether aftermarket aluminum heads are the best approach for my purposes, of if the stock heads can be modified with reasonable success, I “ported” one of the heads with an electric grinder and a Dremel. Results were measured on a “superflow” flow bench at the local machine shop. I did not take measurements of the stock heads, but here is a comparison of the data in Chevy High Performance (available on their web site) with the after-porting results: lift int_stock int_ported exh_stock exh_ported 0.200 125 129 87 95 0.300 183 196 111 125 0.400 215 242 130 146 0.500 233 259 144 162 0.600 235 269 150 182 Both data sets are at 28” water, with no pipe on the exhaust ports. This is for stock 2.07”/1.72” valves with stock (rather poor) valve job and 3/8” valve stems. The Superflow data set include numbers for effective flow area, flow coefficient and a number called “valve velocity”. In the opinion of the guy at the shop, a 454 with ~9:1 compression, a cam “with around 230 degrees duration [at 0.050”]”, Edelbrock Performer RPM intake and 750 cfm carb will make around 420 hp, with around 520 ft-lbs in the 2000-3500 rpm range. The next day I commenced disassembly of the short block. Since none of the cylinders had appreciable ridges (carb cleaner took care of what little carbon deposits there were), the rods came out with minimal persuasion. Rodless, the crank is easily spun by hand. Oil passages in the rod journals were mostly clogged, but the journals themselves have no scratches or deposits of bearing material. So perhaps by next spring I’ll have a running engine again!
Looks good – especially how the roll bar is pushed as far outboard as possible. In your second photograph – why not weld the roll bar/diagonal junction to the unibody sheet metal (at the front-bottom corners of the valence windows)? Then the roll bar doubles as a “B pillar” for the unibody – and the unibody acts as a shear web for the roll bar.
Performance difference between I6 and mild V8?
Michael replied to a topic in Gen I & II Chevy V8 Tech Board
The problem with the torque vs. hp argument (build for hp, use gearing for torque) is the fact that the engine has to spool up to reach the rpms for its “sweet spot”. Engines built for high power, without priority for high torque, almost universally have a power band that favors high rpm. In a racing situation, the driver can plan ahead, by revving the motor before he drops the clutch, pre-positioning the engine in its favored rpm band and preselecting the appropriate gear. In a street situation, off-idle throttle response (and torque!) is what produces the seat-of-the-pants acceleration. I agree that in a controlled racing situation, a mildly improved L6 can achieve similar results to that of a stock V8. But in a street situation, leaving the stop light at 900 rpm or suddenly flooring the gas without downshifting at 25 mph in 3 rd gear, there is no comparison! With an automatic transmission on the street, the difference is even greater, because it takes an appreciable amount of time for the transmission to “realize” that it needs to downshift. The gearing argument is moot if all that the driver desires is a burst of acceleration on-demand. -
Decided to part out my baby - everything must go
Michael replied to Lewis Maudlin's topic in Gen I & II Chevy V8 Tech Board
Lewis, Regarding the strut housings - if you have all four, and they aren't bent (many Z's have a 2 degree (or more) runout on the kingpin inclination angle), I'll pay $100 for the set. But first I have to make sure that the late 260Z is the same as the 280Z. Thanks. -
In California the pick-a-part yards probably consume most of the stock parts business. The first Z that I owned was a ’72 rustbucket (back when I lived in Pasadena). I was overwhelmed with my purchase – it was useless as a candidate for daily driving, let alone a conversion to V8. When I couldn’t sell it, I tried parting it out. After about a year of advertising on recycler.com (a very useful Los Angeles-area automotive classifieds site and newspaper), I sold most of my parts, for a total of about 50% of what I originally paid for the car. I cut up the shell with a sawzall and threw the pieces into dumpsters – literally (well, I kept the firewall VIN stamp). After I moved to the Midwest, the situation changed completely. Here, Japanese cars are rare, and old Japanese cars are extremely rare. If parts do come up for sale, they’re rusted, bent or otherwise worthless. I’ve been looking for a decent set of 280Z strut/spindle assemblies since 2001 – no catch yet. Next time I’m in LA, I’ll visit the pick-a-parts in Monrovia, pull off a set of strut assemblies and mail them back to my address in Ohio.
1000 lbs/Tourque, what rear-end (for road racing).
This may or may not be an appropriate place to make this comment.... but I think that the consensus here is that an incremental approach is preferable. Begin with a stock Z. Replace the suspension bushings and brake pads. Then go to an SCCA club-racing event. Get to the point where you have outgrown the car as a competitive driver. Then consider the first round of upgrades. Maybe a typical Chevy small block, or a Ford, or a turbo L6. But such mods kick you into highly competitive racing categories. So if competitive success is more important than raw performance, consider building an ITS car. Here the path diverges: build a race car to class rules, or build a fast car for personal driving pleasure, regardless of what the race sanctioning bodies mandate. Achieve a solid 300 hp. Install a roll bar, strut tower braces, better brakes, a stronger differential. Then replace the mild small block with a hotter one. Or add turbos, or nitrous, or go with a big block. Reach 500 hp, 600. Perhaps that would be enough. Perhaps the troubles of managing all that power –living with it, not just yearning for it – will attain the point of diminishing returns. But perhaps not. Then keep going up – to 1000 hp, if that’s the next step. When I began my project, I was blessed with a rare opportunity to get professional labor at minimum wage. That’s how I ended up with a tube-framed car set up for a big block. 1000 hp? No, maybe around 400. But even that proved to be too daunting of a step. You may be substantially better prepared than I was – technically, financially, emotionally – but reach too far too fast, and chances are high that something will snap. The last thing that you want is a festering money pit, abandoned in frustration and disgust. Or an ambiguous dream that always stays one step ahead of what's achievable. Isn’t it interesting that rarely do we see posts from guys with 500 hp cars who want 700 hp, or guys with 700 hp cars who want 1000 hp? If you’re that close – if you have done the homework and made the investment to achieve a certain threshold of performance – reaching the next threshold is a logical step. What to do next becomes almost self-evident. Irksome details will still crop up, but the general roadmap is clear. -
Lewis, I need McPherson strut housings (all 4 corners) – stock will do just fine. I don't need the brakes, or springs. I’m in Dayton, Ohio – evidently about a 3 or 4 hour drive from you. -
Has Anyone built a full-tube chassis v8 240z?
Besides those mentioned already, there are several full tube frames on this board. Perhaps the most thorough belongs to “japtin”. Ron Jones has a similar variant. Mine is essentially a tube frame, though it’s welded into the unibody and uses the unibody panels as shear webs etc. It was built on a jig. The car was sawed into three pieces, the frame was welded into the unibody, and then the unibody was welded back together. The tradeoff in this approach vs. a true tube frame is less welding and design work for the frame, but more sheet metal work. A true tube frame differs from a “ladder” subframe (such as Chris Alston or Art Morrison) that slides “underneath” the unibody, then gets a roll cage added. A true tube frame doesn’t have frame rails per se; a jungle-gym-looking framework supports the engine, driveline, suspension and seats. The roll cage helps to bear the suspension and driveline loads. The retail cost of designing and building a tube frame is around $20K (mild steel – maybe $30K in chromoly). Of course, if you have access to specialized tools, a race car shop and mentors to assist you, things would be different. But if you’re shooting for a 1000+ hp road racer, $20K is probably not such a large expense. Chassis sold in catalog stores such as Jegs are just kits – collections of tubes. Welding them together is left up to the customer. The kits are generic, and will require extensive customization to fit to any particular vehicle; rest assured that none of the catalog stores will have a kit customized for the Z. When I shopped around for such kits, about 5 years ago, salesmen would tell me, “Datsun Z, right? Hey, that’s just like a Chevy Vega. I mean, Ford Pinto. Oh never mind, they’re all subcompacts. Our kit fits all of them”. An alternative approach might be to concentrate on weight reduction, rather than all-out horsepower. What power to weight ratio were you shooting for?
